Old Boston Acoustics subwoofer repair, BJT alternatives
  • staze
    • Mar 2008
    • 41
    Working on an older Boston Acoustics HPS10SE, and while verifying voltages, I noticed one of the PSU BJTs is getting excessively hot and the voltage is dropping out on the 15V rail. Not sure that's actually an issue (I don't have everything plugged in, so maybe something is saturating on the positive end and dragging that rail down and the BJT overheating is cutting out).
    But, figure I need to buy some NP capacitors from mouser anyway, so might as well replace these. They're a H669A and H649A. Pretty "meh". They test fine out of circuit, but I can't really put a load on them and test that way.
    I suck at finding alternatives for transistors (I've had a few blow on me cause I missed some piece). But, it LOOKS like from some googling, the Toshiba TTA004 (https://www.mouser.com/ProductDetail/757-TTA004BQ) and TTC004 (https://www.mouser.com/ProductDetail/757-TTC004BQ) should work? Or should I just risk an ebay/alibaba purchase of some of the same 649 and 669 parts?
    Thanks! Attaching service manual that I grabbed off BA's site.
  • jinu_j
    Boston Acoustics Soudware Subwoofer PowerSupply
    by jinu_j
    Hi Folks
    I am looking for help to trouble shoot my Boston Acoustics Soundware X subwoofer power PCB. The Circuit diagram is attached. I have checked the voltage across C3 (there is no capacitor as this is 240V board). The voltage i get is about 318V so i am assuming that the circuit behind that is working properly. But now I am not sure how to proceed. The circuit on the Left-hand side of the circuit is on a separate PCB that's soldered onto the board using the connector CN4 shown in the circuit diagram. So its difficult to trouble shoot components on that.
    There...
    08-20-2023, 02:08 AM
  • rustinjust
    Please help, subwoofer connected to tv, read description below
    by rustinjust
    I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
    Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
    Is there a way of...
    10-28-2023, 07:09 AM
  • rustinjust
    Please help, where can I get a remote for my subwoofer?
    by rustinjust
    I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
    Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
    Is there...
    10-28-2023, 03:43 AM
  • jinu_j
    How to test Subwoofer Amplifier with only a multimeter
    by jinu_j
    Hi Folks
    Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
    Problem
    I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
    Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
    Any advice would be appreciated...
    08-29-2024, 02:05 AM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
