How to troubleshoot a dead psu?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    If i can get a free 600w ocz psu that is completely 100% dead (not even 5vsb), would it be worth trying to fix? What could go wrong?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: How to troubleshoot a dead psu?
    free is good!
    might still be in warrenty too.
    if not its a way to learn.
    ocz has been very good to deal with on bad ram.
    • G McAtasney
      • Oct 2010
      You could start with the fuse,usually the first casualty,and chase it down the line after that----diodes,electrolytics,etc.,If you've got the time you'll get the experience.An AVOmeter is the basic requirement and if all else fails you'll have a supply of spares:
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Whenever i see 5vsb missing i usually just scavenge it for parts. But for this one, it might actually be worth trying to fix it.
        A working TV? How boring!
        • everell
          • Jan 2009
          • 1514
          If 5vsb is missing, it is an easy fix
          If 5vsb circuit has pwm chip, the circuit is easy to fix.
          If 5vsb circuit has 2 transistor circuit, it is easy to replace!
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Its a ocz stealthxstream i think. It looks like the one in the oicture at neweg. But its been discountinued. I can see why. Most of the reviews: it died within a month
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              FSP quality!
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                yah people love to say "oh fsp is really high quality" but besides their 300w models (which they unfortunateyl made like 20 diff versions of, i think theyre shoddy. jonnyguru has a couple that came doa because the fan wires were soldered to the wrong point on the mobo. the 2nd one did too!
                so the ocz power supplies are made by fsp. that explains a lot. when i get it home (probably friday) i will post pics and model info and test it more thoroughly...does anybody know what goes wrong with these power supplies? i thought ocz was at least decent?
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  +1
                  Just fixed a 250W HiPro PSU last week with a TOP switch design for 5vsb. It had a shorted diode that supplied auxiliary power to the PWM controller. It actually took me longer to look through my bags of scrap parts and decide on a suitable replacement than to diagnose the problem.
                  @ Shovenose: for starters, measure 5vsb voltage with your multimeter. Is it completely dead (0v) or is there some small residual voltage present?
                  Either way, open up the PSU and get some pictures. Or else be prepared to see the "this thread is worthless without pictures" smileys .
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    i did say it might take a few days!
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      review:
                      http://www.hardwaresecrets.com/article/451
                      • BigTroll
                        • Sep 2010
                        • 1317
                        • LAMBDA SOND
                        i have a 600watt stealth extreme, runs nice and cool, it doesn't get used much though, and yes the newegg reviews scared me. anyways i would go and try and RMA it
                        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          At least that one has pretty good regulation and well controlled ripple.
                          • Novgorod
                            Asus Strix Z270i Gaming dead DIMM troubleshoot
                            by Novgorod
                            Hi!
                            I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
                            What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
                            07-13-2024, 02:35 PM
                          • mmartell
                            How to troubleshoot dead power brick
                            by mmartell
                            I have an adjustable power supply having a selectable voltage from 15v to 24v. It was sold as a universal soundbar power supply.
                            It has been outdoors in the elements powering a set of outdoor bluetooth rock speakers until recently when it stopped working. (ya ya I know...)
                            I opened it and it looks like there was some liquid ingress but I can't find any shorted silicon and the fuse is not blown. I measure about 160v dc after the bridge rectifier but nothing at the main cap. I suspect the power ic is not running. Obviously there is no voltage on the secondary either....
                            02-05-2024, 06:45 PM
                          • dropfry
                            Dead t480s, trying to troubleshoot. May have found something.
                            by dropfry
                            Hello. I have a lenovo that will not show any indication of life. No led, sound or anything really. So I took the motherboard out and started testing points according to the advice in this thread: https://www.badcaps.net/forum/showthread.php?t=102409
                            PU201 is Showing 6v
                            VREG3/5 show a high value (around 20v) for a split second then drop down very quickly. Hold around 1v but then continue to drop to zero. One is showing .2v.
                            Fuse PF1 is showing very low voltage (which according to the thread deals with docking and is expected)
                            09-29-2023, 02:38 AM
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • kotel studios
                            Compaq series PDP-124P PSU - dies after a split second
                            by kotel studios
                            Hi
                            I am quite baffled at this PSU that came out from an dead HP d530 (asus P4SD). Tested all the common failed components, all are fine. D2/3 are both fine. Not shorted in any way. Recapped the whole 5VSB board and the PSU came "back" from the dead (earlier there was a short from neutral to earth, went away disassembly). Now even with 5 load HDD's it's still turning off after a split second. All diodes seem to be fine. Caps are OST, which IMO rarely die. There is 3.3v on PS_ON and 5V on 5VSB. Removed most of the glue there was (pictures don't show it). The traces that look...
                            12-19-2024, 01:15 PM
