Re: Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Prov
Guys, never mind I got the values of these caps. The larger 4 caps are .01MF 25V & the smaller caps is 220PF 25v... My package for the .01 was not the exact pack, I installed the smaller pack & all worked fine. Audio is perfect. Thanks though
Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Provisor
ThanksLeave a comment:
BoardView V1.3 not work.Leave a comment:
thank youLeave a comment:
https://www.badcaps.net/forum/showthread.php?t=102194Leave a comment:
Thanks for your hard work!Leave a comment:
Hello, i have some problems to open the brv file... i just downloaded openboardviewer, do i need some plugins? ThxLeave a comment:
Hi whizkidz,
Inspecting the logic board I found this bad looking smd component just under the display connector, but I haven't schematics, can you help me please identify it to be proper changed? This A2337 show image in LCD but has no backlight at all and no detect internal camera
@slimmy182, I have the exact same problem, same SMD. MAy you share on what you did to remedy this or what you did to fix this issue?
I'm fresh out electronics and this is my first repair. Any advice would be appreciated.Leave a comment:
Greetings gentlemen! Can you please tell me, is it possible to visually find somewhere ("punch", calculate) the serial number of the device only on the motherboard (board model 820-02016) from M1 (without a laptop case, model A2337)?
On the board I see markings in only one place, but instead of 12 characters (as it should be), there are several rows of 9 and 4 (I attach the photo), which, as it were, does not look like a serial number.
P.S. Please forgive me for my English!Leave a comment:
thanks for sharing,hard work,,regardsLeave a comment:
the lastest OBV will open them?Last edited by piernov; 12-21-2022, 06:22 AM.Leave a comment:
openboardview, does not like the board file, how do i open it another way?Leave a comment:
Thanks!Leave a comment:
Thank you so much for allLeave a comment:
33uF
16V
20%
TANT
CASE-T
128S00009Leave a comment:
Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View...
Channel: Schematics and Boardviews
by roshonhi does anybody have Macbook Air A2337 Schematic & boardview – 820-02899 or know what board is the same thank you
Channel: Schematic Requests ONLY!
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by mkdjHello everyone,
About me, my goal and the equipment I (don't) have:
I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
About my issue and my goal:
A friend of mine has a MacBook Air M1 A2337 that does not... -
by spwoofHello everyone,
I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...-
10-05-2024, 08:02 AM -
- Loading...
