La-e541p
    La-e541p
    LA-E541P schematic plz
    Re: La-e541p
    plz plz plz ...
      Re: La-e541p
      As far as i know, this schematic has not yet publicly available.
        Re: Lenovo 320S-14
        Hello together,
        does anyone have schematic for this Laptop/Mainboard?
          Re: Lenovo 320S-14
          Originally posted by joby91 View Post
          Hello together,
          EDIT. Its available on some paid sites .
            Re: Lenovo 320S-14
            Where is have links?
              Re: La-e541p
              I have bought the schematics right now. i should recieve email with the pdf until tommorow and i will upload it here
                Re: La-e541p
                Thanks for being so generous
                  Re: La-e541p
                  Thanks,man !
                    Re: La-e541p
                    Thank you for sharing sir.
                      Re: La-e541p
                      Thank you
                        Re: La-e541p
                        Here are the schematics for la-e541p
                        Thanks a lot!!!
                          Re: La-e541p
                          Thank youuuuuuu.
                          I will see that what is this BAA70L (PU801).
                          It is in short circuit
                            Re: La-e541p
                            Thank you!
                            Much appreciated!
                              Re: La-e541p
                              thank you m8!!
                                Re: La-e541p
                                thank youuuu
                                  Re: La-e541p
                                  Tnks
                                    Lenovo IdeaPad FLEX 5-1570 81CA totally dead
                                    Hi, Does anyone have the boardview for Lenovo IdeaPad FLEX 5-1570 81CA LA-E541P. Schematics is posted but I need little help finding the components. The motherboard in this is CIUYA/SA/SB/SD LA-E541P. I am not getting max voltage on pin 1 of this chip PU703 ISL88739HRZ, getting only 2.254, is this voltage correct for the chip to operate??? Before this there is a resistor PR729 392K, I want the location of this resistor. Any help will be greatly appreciated. Thanks
                                      Re: La-e541p
                                      I found the resistor & across this, on both ends I am getting 2.25 volt & on the other end it 19V which is correct. The resistor value is correct 392K. The N-Channel MOSFET PQ740, Drain I am getting 19 volts & on the Gate there should be a high voltage but here the volts fluctuates from .25 to .75, bouncing up & down & zero volts on source. Here I should get nearly 24 volts. Any tips will be a great help.
