La-e541p
  • mferna14
    • Jun 2018
    • 1046
    Re: La-e541p
    Another know how.. I remove PQ712, I get all the voltage on the Gate of PQ740 which is 24.5V a true voltage out here meaning ISL88739HRZ is working fine, but as soon I solder PQ712 the voltages drop again. PQ712 is not short & I also checked PQ707 (Protection) all seem to be fine. Do you think I should replace PQ712??? I also check PQ705 & PQ305 (Charging MOSFETs) & the surrounding caps., all seem to be fine. I removed the resistor PR913 to check if any short further but still the same. So there is something going on before this resistor. How come voltage is dropping???
      • 22103
      Re: La-e541p
      This is the schematic requests section. If you want help start a new thread in the main forum, as always .
      • Adiktus
        • Jan 2020
        • 13
        • Philippines
        Re: La-e541p
        Originally posted by joby91
        Here are the schematics for la-e541p
        Greate help man thx
        • doktorkomputer
          • Aug 2016
          • 66
          • Poland
          Re: La-e541p
          Thx
          • alterr333
            • May 2019
            • 44
            • México
            Re: La-e541p
            Thank you mate!!
            Big CHEERS!!!
            • naseee
              • Nov 2016
              • 104
              • india
              #26
              boardview
              • Rickkap
                • Aug 2015
                • 139
                Thank you
                • almirsilvestre
                  • Jun 2020
                  • 45
                  • Brasil
                  #28
                  Re: La-e541p
                  Thank you very much...may God bless you eternally and may you have much wisdom.
                  • almirsilvestre
                    • Jun 2020
                    • 45
                    • Brasil
                    #29
                    Originally posted by naseee
                    boardview
                    Tahnk you so much...May God continue to bless you and give you much kindness and wisdom
                    • alterr333
                      • May 2019
                      • 44
                      • México
                      #30
                      Re: La-e541p
                      THANK YOU BROTHER! Deserve a big jarof beer!
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                      • atunguyd
                        Acer x163w Monitor PSU schematic
                        by atunguyd
                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                        03-05-2025, 02:08 PM
                      • Thetechdude
                        MSI Ventus RTX 4080 16G Broadview schematic needed
                        by Thetechdude
                        Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                        I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                        Thanks.
                        07-15-2025, 11:15 AM
                      • ianpoultonknights
                        Zenbook Flip 15 UX562AI schematic
                        by ianpoultonknights
                        Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                        06-26-2025, 02:41 PM
                      • Adv10119
                        Need help please! schematic for LA-9982P rev 3.0 (A02)
                        by Adv10119
                        Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                        I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                        I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                        01-31-2024, 01:18 AM
