Dell Inspiron 14 7437 no power, need schematics
  • sellit
    • Jun 2017
    • 104
    • Latvia
    Got Dell Inspiron 14 7437 with no power, didn't find any shorts. Got 19V on input, 9V after power mosfets. No power on 3.3V, 5V, RAM and CPU chokes. No shorts on chokes. Got 3.2V on Power button.
    Need schematics please.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Inspiron 14 7437 no power, need schematics
    try cmos reset
    • BlueMidnight
      • Jan 2015
      • 489
      Compare the attached schematic to your board to see if it's the right one. The input MOSFETs in the schematic are PU4201 (page 42) and PU4405 (page 44).
      • sellit
        • Jun 2017
        • 104
        • Latvia
        Thanks BlueMidnight, it's correct schematics.
        After input MOSFETs PU4201 PU4405 got correct voltage 19V.
        But after charger MOSFETs PU4406 and PU4407 got 9V on DCBATOUT, is that voltage correct?
        On 3V/5V controller PU4501 VCC got 9V. No voltage on PL4502 and PL4503.
        Injecting 3V and 5V on PL4502 and PL4503 got laptop startup OK.
        Can it be IC PU4501 fault, or ICs VCC is too low?
        • sellit
          • Jun 2017
          • 104
          • Latvia
          Attached picture with voltages I get on PU4501.
          • BlueMidnight
            • Jan 2015
            • 489
            On this board, the BQ24715 (PU4404) doesn't just charge the battery. It also powers the main system rail (DCBATOUT). So the DC jack voltage stops there, and it uses the PU4406/PU4407 MOSFETs to create voltage on DCBATOUT. Anything from 9-20V is fine. And PU4501 can operate on anything from 5-24V.
            The most likely bad components are PU4501 and/or PU4502 and/or PU4503. The first thing I would personally do is test PU4502 and PU4503. They are just 2 MOSFETs in one package and they should be testable just like separate MOSFETs would be.
            I notice that PU4501 has latched PU4503 in the overvoltage protection configuration (with the upper FET turned off but the lower FET turned on with 5V on pin 11 of PU4501). That might mean there's something wrong with PU4503, but could just as easily mean PU4501 is bad, etc.
            • sellit
              • Jun 2017
              • 104
              • Latvia
              Thanks for help. Purchased PU4501, will give an update after replacement.
              • sellit
                • Jun 2017
                • 104
                • Latvia
                Replaced PU4501, made no difference. Purchased PU4502 and PU4503.
                • sellit
                  • Jun 2017
                  • 104
                  • Latvia
                  Replaced PU4502 and PU4503, no difference. The same voltages. Can I inject on some pins voltage to make it work? Like PGood or DRVL1.
                  • mielta
                    • Apr 2015
                    • 368
                    Hi
                    You must check Pgood Pin7 it must be 3.3v it goes to Side 17 from the schematic
                    Q1701
                    • alig
                      • Mar 2015
                      • England
                      Did you fix this
                      • ronelex
                        • Oct 2016
                        • 195
                        • Philippines
                        try replace the filter capacitor on the 5v and 3v line
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 487
                          • somewhere in europe
                          that would have been my suggest, too. it fixed two of these machines already.
                          • AG Electronics
                            • Dec 2016
                            • 13
                            • United Kingdom
                            I can confirm that if all conditions above met. Replacing capacitors in 3V/5V lines resolves no power on laptop.
                            • hirens
                              • May 2022
                              • 177
                              • uganda
                              need bios bin file for dell inspiron 14-7437
                              • mon2
                                • Dec 2019
                                • 14216
                                @hirens, bios requests are in a different part of this forum. See above. Can you repost your request there?
                                • zlr8r
                                  Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                  by zlr8r
                                  hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                  Ill try and give as much info as I can.
                                  Dell Inspiron 17 (7786) Laptop
                                  Service Tag: 5J0NHT2
                                  Bios: 1.9.0
                                  When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                  Then it started getting weirder!
                                  Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                  12-12-2023, 09:31 PM
                                • madura2010
                                  Dell inspiron 3168 (15299-2) no power
                                  by madura2010
                                  Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
                                  But after removing battery, worked perfectly.
                                  next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
                                  But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
                                  Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
                                  01-28-2024, 09:10 PM
                                  DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                  This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                  09-12-2024, 02:15 PM
                                • Scaff
                                  Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
                                  by Scaff
                                  I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
                                  06-08-2025, 01:46 AM
