Need Schematic for Asus X200CA REV 2.1
  • angel-boy
    • 550
    • Romania
    the power jack was broken , make a short circuit, i power the board with 19v but no power, no battery charge. I was able to recharge the battery, now laptop starts on battery
    I edit a photo from internet with my voltage , i did not find schematic for this model , possible that A5 KNA 9P0503 is good , but is no vontage on command pin.
  • mesersmith
    • 35
    • România
    Re: Need Schematic for Asus X200CA REV 2.1
    Please, write down the entire code on the moderboard.
    • angel-boy
      • 550
      • Romania
      this is the code.... X200CA main board rev 2.1 pcb made in china
      • mesersmith
        • 35
        • România
        See if this schematic is what you need.
        • angel-boy
          • 550
          • Romania
          but i have a Asus X200CA REV 2.1
          • rajeshkumar
            • Oct 2014
            • 44
            • india
            hiiii frnd i ma also need thise schematic if u have as soon as reply
            thanxx in advance
            • angel-boy
              • 550
              • Romania
              any help ? i need that schematic, laptop start on battery , but not on charger,
              • angel-boy
                • 550
                • Romania
                help ?
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  BQ25A voltage?
                  • angel-boy
                    • 550
                    • Romania
                    ok , i will check . tks
                    • avgjm
                      • Sep 2015
                      • 14
                      • Philippines
                      Hello! I have the same problem here. I have an asus x200ca and the power voltage is flactuating, what might be the cause of this problem??
                      Im a newbie member here ... thank you Godbless
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3587
                        • slovakia
                        here often fails one of two base power mosfets, or transistor on driver to them
                        • minou23amine
                          • Feb 2016
                          • russia
                          hello, did any one found the solution to the problem? or at least the schematic for Asus x200ca?
                          • blondinchen
                            • May 2016
                            • vienna
                            No schematic for Asus X200ca ? :-( :-( :-(
                            • polytek
                              • Dec 2013
                              • 496
                              • TUNISIA
                              hi,
                              replace the first two mosfet: P0903BEA N-Channel
                              here the datasheet of the mosfet:
                              • medusa
                                • Apr 2009
                                Thanks to all. Had similar fault, which has been helped with above posts.
                                • mkdj
                                  ASUS X571 no power : battery issue?
                                  by mkdj
                                  Mark and model: ASUS X571
                                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                  Tests already made:
                                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                  - I have removed...
                                  07-14-2025, 09:16 AM
                                • dhenion
                                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                  by dhenion
                                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                  The original board was:
                                  ASUS X510UNR REV 3.0 A
                                  The replacement board is:
                                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                  01-30-2024, 01:45 PM
                                • rob777
                                  Asus TUF won’t run off battery
                                  by rob777
                                  I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                  I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                  Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                  Thanks....
                                  05-27-2025, 07:07 PM
                                • Iherduleikgemz
                                  Asus FX505DY - Battery not charging - BQ24780S
                                  by Iherduleikgemz
                                  Hello everyone
                                  I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                  I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                  01-13-2025, 03:54 PM
                                • dr.thodt
                                  Asus GA401Q only working from battery
                                  by dr.thodt
                                  I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
                                  The battery status is 255%, also with a brand new battery.
                                  The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
                                  If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
                                  There's a...
                                  12-20-2024, 08:23 AM
