I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
Thanks.
update I think the battery is bad. It’s does not pull any current when I put power supply probes on it.
Thanks.
