Asus GA401Q only working from battery
  • dr.thodt
    • Apr 2016
    • 83
    • Netherlands
    I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
    The battery status is 255%, also with a brand new battery.
    The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
    If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
    There's a light bulb in series with the mains lead which flashes when the 19.5V fals back to 0V.
    I tried to skip both mosfets at the DC jack to see what that did: nothing.
    I injected 19V from a bench power supply which put a solid 19.5V on the mainrail, but no 5VDC or 3.3VDC was found. Data out and Data in on the bios chip generated one spike on the scope when I pressed the power button.
    I'm ran out of options. Hopefully somebody can give me a tip.
    Regards.
  • mon2
    • 14632
    Test the voltage to ground on the smbus scl and sda pins on the charger ic. Sometimes the battery area has an esd protection device that dies from an esd transient. This causes issues.
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • reformatt
      A2337 not working with flat battery
      by reformatt
      Looking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
      So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
      Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,...
      10-12-2023, 04:36 PM
    • dhenion
      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
      by dhenion
      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
      The original board was:
      ASUS X510UNR REV 3.0 A
      The replacement board is:
      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
      01-30-2024, 01:45 PM
    • rob777
      Asus TUF won’t run off battery
      by rob777
      I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
      I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
      Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
      Thanks....
      05-27-2025, 07:07 PM
