Could I get some help reading this schematic?
  • orientalsniper
    • Apr 2013
    • 461
    First off, PQ2 was shorted. So I replaced it with a new one.
    And now PQ2 does not output any voltages in pins 5-8. I think it's not being activated since pin 4 in both PQ2 and PQ1 are on high (18v).
    So I noticed there's some OCP/OVP protection circuit in page 59. I think the relevant parts are PQ35, PR6. But I don't know how to make sure PQ35 is fine since I never tested its kind before, though it passes diode test I think. Also it has 18V in pins 1,3,4,6.
  • dj_ricoh
    • 2073
    Re: Could I get some help reading this schematic?
    so your pq2 and pq1 will open with gate from PU3 pin 4 ACDRV#
    if that chip its broken and does not output that voltage for the mosfet you will not have any power.
    replace pu3 then you will have gate for pq2 and pq1
    • orientalsniper
      • Apr 2013
      • 461
      I've replaced PU3 with another one from a broken laptop, so I don't know if it's good or bad. But they had the same readings in all pins, the issue is, it takes me 2 weeks to receive any order from Ebay and I would rather confirm everything else is fine.
      Since both these guys changed PU3, I assumed PU3 was fine:
      https://www.badcaps.net/forum/showthread.php?t=36522
      http://www.reballing.es/viewtopic.php?f=22&t=5358
      I have to add if I short PQ2, computer runs fine with power adapter. Battery remains undetected.
      • orientalsniper
        • Apr 2013
        • 461
        So I had been reading the schematic, would it make sense if I remove PR140 and PR9 and then measure pin4 of PQ1 to check whether ACDRV# is working or not?
        • orientalsniper
          • Apr 2013
          • 461
          SOLVED:
          Replaced PQ2 and resoldered PU3.
          • dj_ricoh
            • 2073
            perfect!
            for chips like that pu3 I got a microscope to be 100% sure its soldered.
            glad to see that it came on
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              there is a good technique to solder without using microscope . simpe remove all solder frmo the pins with solder wick in both part board and chip itself , leave on a very small amount on the central pin GND (very small , like the amount of solder of a 0,65 mm ball
              give a bit of hot aair to make the bond on the GND , then apply flux on the 4 sides , and with your iron , gently drop a little big of solder in the iron , and pass slowly on the 4 sides with the iron , all pins will be perfectly soldered , without much need of microscope confirm , just with eye view you can notice if well or not well soldered .
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
              • langbaobao
                DIY 3D-Printer WSON8 Pogo Pin Adapter
                by langbaobao
                Hi.
                I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                01-08-2024, 05:58 PM
              • Spoonicks
                Samsung 2233SN no CFL backlight
                by Spoonicks
                Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
                Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
                I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
                Following the guide I tested the following:
                The transformer...
                07-01-2023, 11:10 AM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • electrocute
                Lenovo Yoga 3 14 (NM-A381) not powering on
                by electrocute
                Laptop: Lenovo Yoga 3 14 (80JH)
                Logic Board: BTUU1 NM-A381 REV:1.0 2014-11-17
                Issues:
                • not powering on
                • bottom of the laptop getting hot
                Background:
                Laptop not turning on. On-board voltage from AC adapter was jumping between 3V (do not recall correctly) and 4.xV, and the fan spinning/stopping on its own.
                Initial readings:
                Code:
                PL202=4.12V  10.5 Ω   .010V drop  Hot Area
                PL201=1.06V  44.1 kΩ  .320V drop  Hot Area
                PL401=0V    55.4 Ω   .143V drop
                PL801=0.04V  71 Ω    .050V drop
                PL301=0V    112 Ω
                10-28-2021, 10:44 AM
