VPCF13Z1E doesn't work with battery
  • lefos
    • Nov 2013
    • 321
    • Greece
    This one is driving me nuts.
    Its motherboard is MBX-235 but I have found out that it is rather the same with MBX-215 (attached).
    So it works with ac adaptor but doesn't charge the battery at all (checked to other laptop works ok). I have already changed the BQ247553A with no result and the pq2 which was shorted. After changing the pq2 with a new one the laptop doesn't power on at all, I have to short it again in order to power on with ac adaptor. Any suggestions please?
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: VPCF13Z1E doesn't work with battery
    Without shorting PQ2 give voltage of pin 4 of PQ1 and PQ2
    • lefos
      • Nov 2013
      • 321
      • Greece
      I have 19v on both pins.
      • atsio
        • Oct 2013
        • 819
        • Greece
        Give voltage on all pins of PU3
        • lefos
          • Nov 2013
          • 321
          • Greece
          Hello again,
          I have managed to repair the charging problems. Now it charges the battery, powers on with ac adaptor but doesn't power on with battery! Even if you remove the adaptor while working turns off.
          Any ideas please?
          • atsio
            • Oct 2013
            • 819
            • Greece
            Check PQ32
            • dutchgaucho
              • 59
              • The Netherlands
              Hi, facing the same problems you previously did. PQ2 shorted, enable signal on pu3 always high (= charging deactivated). Did you manage to repair this issue? It seems to be a quite easy one, but turns out to be hard. Since you managed to get the bat. charged, what did you do? Tnx
              • lefos
                • Nov 2013
                • 321
                • Greece
                I have suggest to the laptop owner to change the mainboard. I haven't managed to repair this one. Sorry for not being helpful to you.
                • dutchgaucho
                  • 59
                  • The Netherlands
                  Ah, too bad. thanks for your reply anyway. Maybe somebody has a clue. Facing same problem as topic starter. Pq2 was shorted. Replaced it, now don't have voltage on the board. PQ2 has 19v on both Source and Gate but not on the drain. Does anyone have a clue? thanks!!
                  • rookieme
                    • Oct 2014
                    • 397
                    • Greece
                    Hi, similar issue here.
                    The notebook works ok without the battery but with the battery shuts off like cutting the power at the time I connect the battery or after some time.
                    This happens with a new battery also.
                    It is more likely to happen if I benchmark cpu or gpu thus making the system need more power.
                    At all times it worked ok without the battery - the power supply is tested with no fault.
                    Could it be a charging circuit issue [bq24753] that senses increased current and cuts the power?
                    Forgot to mention that the issue also happens with a fully charged battery.
                    To make it power on again I have to remove power, battery and rtc battery.
                    Any suggetions appreciated.
                    • rookieme
                      • Oct 2014
                      • 397
                      • Greece
                      anyone with any idea?
                      • igino
                        • Mar 2013
                        • 6
                        • Trnava
                        i got the same problem, PQ2 was shorted, when replace it, no power. PU3 on ACDET 2,6V high, whitch means adp disconnect. Anybody helps?thanx
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Sometimes doing cmos reset solves this problem in lot of sony mb. have you tried it??
                          • dhs6512
                            Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                            by dhs6512
                            Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                            Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                            Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                            When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                            Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                            When connecting...
                            10-29-2024, 11:04 AM
                          • mkdj
                            ASUS X571 no power : battery issue?
                            by mkdj
                            Mark and model: ASUS X571
                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                            Tests already made:
                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                            - I have removed...
                            07-14-2025, 09:16 AM
                          • pabloroggeri
                            Lenovo V310-15ISK - It doesn't work after changing the battery
                            by pabloroggeri
                            Good guys. I changed the battery to a Lenovo V310-15ISK.
                            The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                            When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                            08-23-2024, 12:01 PM
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                            09-14-2023, 11:10 PM
                          • ferah831208
                            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                            by ferah831208
                            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                            03-18-2025, 01:18 AM
