Could I get some help reading this schematic?
  • orientalsniper
    • Apr 2013
    • 461
    First off, PQ2 was shorted. So I replaced it with a new one.
    And now PQ2 does not output any voltages in pins 5-8. I think it's not being activated since pin 4 in both PQ2 and PQ1 are on high (18v).
    So I noticed there's some OCP/OVP protection circuit in page 59. I think the relevant parts are PQ35, PR6. But I don't know how to make sure PQ35 is fine since I never tested its kind before, though it passes diode test I think. Also it has 18V in pins 1,3,4,6.
  • dj_ricoh
    • 2073
    • uk
    Re: Could I get some help reading this schematic?
    so your pq2 and pq1 will open with gate from PU3 pin 4 ACDRV#
    if that chip its broken and does not output that voltage for the mosfet you will not have any power.
    replace pu3 then you will have gate for pq2 and pq1
    • orientalsniper
      • Apr 2013
      • 461
      I've replaced PU3 with another one from a broken laptop, so I don't know if it's good or bad. But they had the same readings in all pins, the issue is, it takes me 2 weeks to receive any order from Ebay and I would rather confirm everything else is fine.
      Since both these guys changed PU3, I assumed PU3 was fine:
      https://www.badcaps.net/forum/showthread.php?t=36522
      http://www.reballing.es/viewtopic.php?f=22&t=5358
      I have to add if I short PQ2, computer runs fine with power adapter. Battery remains undetected.
      • orientalsniper
        • Apr 2013
        • 461
        So I had been reading the schematic, would it make sense if I remove PR140 and PR9 and then measure pin4 of PQ1 to check whether ACDRV# is working or not?
        • orientalsniper
          • Apr 2013
          • 461
          SOLVED:
          Replaced PQ2 and resoldered PU3.
          • dj_ricoh
            • 2073
            • uk
            perfect!
            for chips like that pu3 I got a microscope to be 100% sure its soldered.
            glad to see that it came on
            • highpulse
              i hate HP
              • May 2013
              • 1495
              • portugal
              • electronics and music production
              there is a good technique to solder without using microscope . simpe remove all solder frmo the pins with solder wick in both part board and chip itself , leave on a very small amount on the central pin GND (very small , like the amount of solder of a 0,65 mm ball
              give a bit of hot aair to make the bond on the GND , then apply flux on the 4 sides , and with your iron , gently drop a little big of solder in the iron , and pass slowly on the 4 sides with the iron , all pins will be perfectly soldered , without much need of microscope confirm , just with eye view you can notice if well or not well soldered .
              • eccerr0r
                Heat sink plastic pins (intel specific) cracking? Just fakes?
                by eccerr0r
                I'm not sure if this is still pervasive but back in the Socket 775 and on towards a lot of the 115x series, Intel heatsink fans used those nasty to set pin-in-hole retention systems to hold the heatsink on the motherboard. Not only there's a potential to bend and crack the motherboard, I've had a few of these plastic pins blow up and the heatsink falls off. I have this one machine that constantly breaks these pins that I ended up ghettomodding it with screwlocks and a bunch of nylon washers. Not as tight as before but at least the cpu doesn't overheat anymore when the plastic pins crack!...
                12-31-2025, 10:07 AM
              • sparker1
                Bent and broken CPU pins
                by sparker1
                Hello, I have a motherboard that I somehow crushed a bunch of CPU pins on an LGA1200 CPU socket. I am only at hobby skill level for soldering etc but I want to try and repair the board. Is it easier to replace individual pins or the whole socket? I have seen a few youtube videos and people seem to have more success replacing pins than the whole socket. I don't have a BGA fancy heater but have a decent hot air station and a makeshift bottom heater. Any thoughts?...
                02-26-2026, 11:31 PM
              • jkucukov
                Help with Samsung Microwave Cooling Fan Wiring Pins
                by jkucukov
                I have a Samsung Microwave I'm looking to harvest some parts from, specifically the 120V AC motor that keeps the Magnetron cool.
                From the image below, we see 3 pins on the AC motor, with AC Voltage tester all 3 leads measure 120 V with the microwave plugged in and fan not running. With the fan running only pins 2 & 3 measure 120 V.
                What I'm looking to do is wire this motor up on a Air Compressor to keep the motor cool, but I need to know what is the safe way to wire it, (IE wire in pins 2 & 3 with 120 V only to get it to run?)
                Also, as its wired, when...
                11-24-2025, 05:02 PM
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
              • langbaobao
                DIY 3D-Printer WSON8 Pogo Pin Adapter
                by langbaobao
                Hi.
                I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                01-08-2024, 05:58 PM
