lenovo legion 5-15ach6h bios request
https://www.badcaps.net/donate -
I asked them to program the ic with the bios version of my notebook
IT8227E-192 CXA (NOT BGA) for my notebook legion 5-15ach6h
notebook serial PF2YWDN8
mainboard : nm-d562 (see picture)
What if they arrive blank ? may i program it without desoldering again ? or with a wrong firmware ?Comment
Great ! Thank you ! It took some tries to program it right with my ch341, but it finaly succeed.
I was able to boot the laptop with this file .
There is still a major issue, that sometime it boot, and most of the time not: just some led are on, but no fan, no screen, no boot . I ll try to flash again once it start, but I suspect another issue.
Will see...Comment
Hi
Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU
SN PF2YWDN8
mainboard : nm-d562 rev 2.0
notebook power led on (white), keyboard changes color in loop, no screen (not even backlight), no caps lock light, no boot
i changed the IT8227E-192 CXA (was shorted) with a new one from aliexpress, (i hope they programmed it)
Im an engineer, but this is new to meComment
Hi guys,
TL;DR – I’m trying to get into electronics repairs and bought a couple broken laptops. A couple start but get into a short boot loop before Caps Lock becomes responsive.
Here’s one of the little troublemakers:
Make: Lenovo
Model: Legion 5 15ACH6H – Type 82JU
Motherboard: NM-D562 Rev 3.0
S/N: PF3D52R7
Bios Chip: Winbond W74M12JWZPIQ
Symptoms:
- Boot loop with no image.
- Esc+Caps Lock key LEDs lit, with Caps Lock unresponsive.
- Fans spin at the start of each loop.
- There’s voltage on every rail.
- No shorts that I could find, but not really an expert; just getting started.
- Pictures and exported BIOS attached; hope it helps.
Obs.:
- I went trough the guides and failed miserably both on Linux and Windows in my attempts to extract the correctly sized BIOS from the packager. I did try following the guide in the forum, which took me to a guide in Github, which led me to seek ChatGPT for extra help (and ended in a loop myself with the damn thing), all while a day and a half passed and the .bin is still not the correct size.
Attached () you’ll find:
- photos of the cursed board
- the .exe packager taken from Lenovo for my serial
- the decompressed.bin taken through Linux wih the “help” of ChatGPT
- the BIOS.fd I managed through Windows 11 (VM through Linux)
I’d love to understand the process, as I’d raher do the fishing myself than just eat he fish, but this one is driving me nuts as no instructions I’ve seen matched the straightforward result expected from following them. =/
Apologies for the wall of text. =)Attached FilesLast edited by MagicHertz; 09-18-2025, 07:06 AM. Reason: And... noticed the extra "1" in the model as well... sighComment
Hi guys,
Make: Lenovo
S/N: PF3D52R7
Symptoms:
Obs.:
Apologies for the wall of text. =)Comment
Thanks, qayyum786!
I faced two issues with the flash - first, flashrom didn't manage to backup two identical bins; which didn't bothered me since the laptop is currently in bricked state, so that bios wouldn't do me any good.
But, the worst part was the failure to flash the chip with the bios you provided. Any idea what could cause this? Is the chip itself damaged and the reason for the laptop to be bricked in the first place?
flashrom v1.6.0 (git:v1.6.0) on Linux 6.16.7-2-cachyos (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Found Winbond flash chip "W25Q128.W" (16384 kB, SPI) on ch341a_spi.
Reading old flash chip contents... done.
Updating flash chip contents... Erase/write done from 0 to ffffff
Verifying flash... FAILED at 0x0004025e! Expected=0xfc, Found=0xec, failed byte count from 0x00000000-0x00ffffff: 0x3fc
Your flash chip is in an unknown state.Comment
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by HammyCheesyHello all,
I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
Type: 30BB
Model Number: S03600
S/N: MJ07N68C
Things I have tried:
1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
2. Attempted to boot with just a single CPU...-
by sugih1211hi admin and all. can please give a clean boot bios bin for lenovo legion 5-15ach hy56w hy66w hy76w nm-d931 rev 1.0 cause my legion on but no display. thanks very much.
- Loading...
