dell g5 5587 bios
  • peste
    • Dec 2016
    • 14052
    • ROMANIA
    Originally posted by Tkashy
    i have a dell laptop g5 there was a power surge I took it to a technistion who missed it and flash the bois no fix I took it to a new one who said I need a rebuild of my bois can anyone help and what inf do u need I have my service tag 3m1dxs2 my
    post S/T full name and model, motherboard model,,etc.
    post the contents of the bios chip even if it is corrupted..
    • Robin45
      • Sep 2023
      • 5
      • Ukraine
      I have a DELL G5 5587 (LA-E994P). When power is applied, there is no initialization, and the fans spin at full speed.
      I’m attaching a backup of the BIOS.
      Serial number: J6VQ9S2.
      • yoboytips
        • Oct 2025
        • 5
        • USa
        I am hoping someone can kindly assist me. I am in need of an original BIOS dump file for a Dell G5 5587 laptop with the following specifications:
        • Motherboard: LA-E993P
        • BIOS Chip: Winbond W25Q80BV ( 1MB)
        • Required File Size: 1.0 MB
        The main issue is that I currently do not have access to the official Dell support website to download the recovery file.
        I would be extremely grateful if anyone could share a known working and clean BIOS dump for this specific model. Thank you in advance for your time and help.
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peste
        • Dec 2016
        • 14052
        • ROMANIA
        post S/T,etc.
        • yoboytips
          • Oct 2025
          • 5
          • USa
          Originally posted by peste
          post S/T,etc.
          It won't let me. When I attach a file, it says the upload failed. You are not allowed to upload files with the extension
          • volinakis
            • Jan 2021
            • 2888
            • N/A
            #26
            use an archiever (zip, rar). W25Q80BV is not bios chipset, is for thunderbolt.
            • yoboytips
              • Oct 2025
              • 5
              • USa
              #27
              Okey,thanks
              • yoboytips
                • Oct 2025
                • 5
                • USa
                #28
                post S/T,etc.
                service tag : HZVL9S2
                motherboard : DDK51 DDK52 DDK53 LA-E994P REV 1.0
                winbond W25Q80BV (1mb)
                I’d appreciate your help if you have time and opportunity. Thanks in advance!
                • m1ch43lzm
                  • Mar 2019
                  • 1188
                  • Peru
                  #29
                  Wrong chip, this is most likely USB-C PD controller firmware
                  Main BIOS chip on any modern laptop is 16MB or more, look for W25Q128 or GD25B127D or equivalent chip with 25*128 in the name
                    • 22424
                    Thunderbolt firmware. Search for the word ARC PARM or DROM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
                    • capoplays
                      Help with BIOS update on Dell G15 5515 after chip replacement
                      by capoplays
                      Hey everyone,
                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                      When I check the BIOS using the F12 menu Flash...
                      10-24-2025, 06:53 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • Sathsul
                      Dell Latitude 5431 issues with dumping bios
                      by Sathsul
                      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                      10-28-2025, 07:49 AM
