Bios unlock for DELL LATITUDE 7420
  • korchi071
    • Apr 2025
    • 4
    • Україна
    #401
    Originally posted by hoaca388
    Latitude 7420
    Service Tag: G5S5LN3​
    Thank you so much! Everything works
    • Viktor-x
      • Oct 2023
      • 6
      • Украина
      #402
      Hello, my BIOS chip is damaged, I bought a new one but it needs a firmware update.
      Which one can I use?
      Dell latitude 7420
      ST: DQPK6G3
      LA-K371P REV: 3.0 ​(a02)
      • peste
        • Dec 2016
        • 12953
        • ROMANIA
        #403
        Dell latitude 7420
        ST: DQPK6G3
        LA-K371P REV: 3.0 (a02)
        post the contents of the bios chip even if it is corrupted..
        • Viktor-x
          • Oct 2023
          • 6
          • Украина
          #404
          yes
          • hoaca388
            Badcaps
            • Jan 2022
            • 11886
            #405
            yes
            Latitude 7420
            Service Tag: DQPK6G3​
            • trepachka
              • Oct 2022
              • 432
              Hello, I have this Latitude 7420 laptop with bios lock. Please, help me unlock it.
              Latitude 7420
              ST: 1DQ46M3
              Thank you.
              • lapfix
                • Mar 2020
                • 2742
                • my workshop
                #407
                Latitude 7420
                ST: 1DQ46M3
                Thank you.
                1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
                Good luck.
                • trepachka
                  • Oct 2022
                  • 432
                  I am not sure what happened. I reflashed the bios chip and computer is not switching to 20V. I checked the issue and PL201 coil (part of PU200) is measuring only 20 ohms which indicates a short to me. I will address this first, then report whether the password is gone.
                  • trepachka
                    • Oct 2022
                    • 432
                    Ok, I reflashed the bios. On 1st boot computer fan runs at full spead. On 2nd boot the keyboard backlight comes on along with the charging light. Then, the whole thing turns off and repeats the cycle.
                    I soldered the original bin and the computer boots with the password. Can you rework your bin file for me to try again?
                    Thanks.
                    • lapfix
                      • Mar 2020
                      • 2742
                      • my workshop
                      #410
                      Try again the same unlocked file , don't forget to disconnect cmos and Hdd/SSD
                      • trepachka
                        • Oct 2022
                        • 432
                        I tried many bin files. The one that actually worked is located in post # 169:
                        https://www.badcaps.net/forum/troubl...ude-7420/page9
                        • lapfix
                          • Mar 2020
                          • 2742
                          • my workshop
                          #412
                          Weired !! i just unlock your file .. is it the original one !
                          • trepachka
                            • Oct 2022
                            • 432
                            Yes. I reflashed the bios chip with the original content and the computer booted with the admin password again. I then located this particular bios file, had the bios chip reflashed and the computer booted without the password. I just had to update the service tag as it was empty per instructions.
                            No worries. Thanks for your assistance.
                            • jackx
                              • May 2020
                              • 216
                              • casa1
                              #414
                              THANK YOU FOR all help
                              • mthxld
                                • Aug 2021
                                • Poland
                                #415
                                Hi, can you remove the BIOS password?
                                Board model: LA-K371P rev : 3.0 (A02)
                                Service Tag: 76TF4M3
                                Thanks in advance!
                                • lapfix
                                  • Mar 2020
                                  • 2742
                                  • my workshop
                                  #416
                                  Thanks in advance!
                                  1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.Good luck.
                                  • tareqtareq
                                    • 13
                                    • jordan
                                    #417
                                    BIOS PASS PLEASE UNLOCK
                                    ST JGQS6D3
                                    • peste
                                      • Dec 2016
                                      • 12953
                                      • ROMANIA
                                      #418
                                      ST JGQS6D3
                                      try..
                                      • mahlon simwnaja
                                        • Nov 2022
                                        • 82
                                        • south africa
                                        #419
                                        GOOD DAY
                                        Pease help fix TPM problem on this BIOS file .
                                        Board N0 : LA-K371P rev : 3.0 (A02)
                                        SN : 423K7G3
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11886
                                          #420
                                          Originally posted by mahlon simwnaja
                                          GOOD DAY
                                          SN : 423K7G3
                                          This is a topic of DELL LATITUDE 7420
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 7420 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7420 boardview and 7420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7420...
                                            09-07-2024, 01:30 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                            09-07-2024, 03:40 AM
