Thinkpad T15 Gen 1 BIOS
  • anjelics
    • Sep 2014
    • 15
    • Romania
    need BIOS for Thinkpad T15 gen 1, type 20S6, NM-C931
    original bios power up and no image, error 0001
  • hoaca388
    Badcaps
    • Jan 2022
    • 12453
    Re: Thinkpad T15 Gen 1 BIOS
    T15 (type 20S6) Laptop (ThinkPad)
    • anjelics
      • Sep 2014
      • 15
      • Romania
      thanks hoaca388. with your bios power button blinks 3 times when I connect power then no reactions
      • alihomee
        • Dec 2012
        • 1599
        • malaysia
        lenovo T15 gen 1
        notebook turns on with a blank display num lock not working....ori file is attached ...mechine type num is:20S6-CT01WW....mobo code is GT4A0 /GT5A1/GP4A0/GP5A1/GT4A2 NM-C931 rev 1.0
        • alihomee
          • Dec 2012
          • 1599
          • malaysia
          tried this file but no power
          • hoaca388
            Badcaps
            • Jan 2022
            • 12453
            your serial number
            • alihomee
              • Dec 2012
              • 1599
              • malaysia
              your serial number
              non of them '''''
              my serial no is:PF-2JJVCC and type num is:20S6-CT01WW
              • hoaca388
                Badcaps
                • Jan 2022
                • 12453
                non of them '''''
                T15 (type 20S6) Laptop (ThinkPad) - Type 20S6
                • alihomee
                  • Dec 2012
                  • 1599
                  • malaysia
                  tried with this file and got post for one time after that again blank screen/////i tried flashing the chip again and get same result ...it turns on and then display is blank
                  • Canny
                    • Aug 2022
                    • 18
                    • Swaziland
                    looking for bios bin file
                    Lenovo ThinkPad t15
                    type 20S7
                  • Canny
                    • Aug 2022
                    • 18
                    • Swaziland
                    Laptop is charging but does not turn ON
                    Lenovo ThinkPad T15 Gen 1
                    GT4A0_GT5A1_GP4A0_GP5A1_GT4A2_NM_C931_REV_1_0
                    Type 20S7-S4M800
                  • Canny
                    • Aug 2022
                    • 18
                    • Swaziland
                    Type 20S7-S4M800
                    serial number PF-31MZ0E​
                    • robkom
                      • Jul 2022
                      • 27
                      • Poland
                      Hi.
                      Can someone help me? Thinkpad T15 Generation 1 - the laptop turns on, charges the battery, shows no image. I have tried many bios, it does not even turn on on another bios. Only on the original bios it turns on, but as I wrote without an image on the display.
                      The laptop does not go through the POST procedure after turning on. It seems to me that these may be damaged built-in RAM, but first I have to rule out damage to the bios.
                      Could someone check my bios, or maybe someone can post a bios that works properly?
                      Thanks in advance
                      GT4A0/GT5A1/GP4A0/GP5A1/GT4A2
                      NM-C931 REV 1.0
                      Type 20S7-S3EE00
                      serial number PF-22YRXJ​
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12453
                        Originally posted by robkom
                        Hi.
                        Thanks in advance
                        NM-C931 REV 1.0
                        Type 20S7-S3EE00
                        T15 Laptop (ThinkPad) - Type 20S7
                        • robkom
                          • Jul 2022
                          • 27
                          • Poland
                          Thank you, but the laptop on your bios does not respond to the power button. I have already put too much work into it, the laptop is going back to the customer.​
                          • Markus1741
                            • Sep 2020
                            • 985
                            • N/A
                            Lenovo Thinkpad T15 gen 1
                            Serial Number: PF29NYVZ
                            Type Number: 20S6-000SGE
                            Board Number: NM-C931
                            Hello a question is possible to deactivate the 8GB onboard RAM in BIOS in a Lenovo T15 Gen1.
                            Otherwise there is probably no other way to reballing the RAM
                            Thank you​
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1376
                              • France
                              Thank you
                              try that, not sure work
                              • Markus1741
                                • Sep 2020
                                • 985
                                • N/A
                                Thanks for the answer but what exactly should I edit in the file. Well I've never had the problem.​
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1376
                                  • France
                                  ​look here another T15
                                  not work
                                  https://www.badcaps.net/forum/troubl...editing/page17
                                  • anhbanxoi
                                    • Sep 2021
                                    • 180
                                    • VN
                                    Originally posted by Maxpower3
                                    I tried SPD but didn't work. Do you know other method to disable onboard RAM? I'm going to remove RAM IC from motherboard but afraid that it can damage the board because of the black glue underneath .
                                    • to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                      by to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                      I have opened the laptop and identified the main BIOS chip...
                                      10-24-2025, 01:35 AM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • MaxonDomkrat
                                      Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                      by MaxonDomkrat
                                      Hi everyone.
                                      I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                      07-30-2025, 01:27 PM
                                    • 1g0r
                                      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                      by 1g0r
                                      First, the data in brief:
                                      Manufacturer: Lenovo
                                      Model: ThinkPad L15 G3 21C3-0016GE
                                      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                      IC Bios 1: MX77L25650F
                                      IC Bios 2​: MX25L25673G
                                      EC Chip: NPCX997KAABX
                                      So far I've been a silent reader, but now I need your help
                                      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                      01-18-2025, 02:39 AM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
