---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
notebook turns on with a blank display num lock not working....ori file is attached ...mechine type num is:20S6-CT01WW....mobo code is GT4A0 /GT5A1/GP4A0/GP5A1/GT4A2 NM-C931 rev 1.0
tried with this file and got post for one time after that again blank screen/////i tried flashing the chip again and get same result ...it turns on and then display is blank
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hi.
Can someone help me? Thinkpad T15 Generation 1 - the laptop turns on, charges the battery, shows no image. I have tried many bios, it does not even turn on on another bios. Only on the original bios it turns on, but as I wrote without an image on the display.
The laptop does not go through the POST procedure after turning on. It seems to me that these may be damaged built-in RAM, but first I have to rule out damage to the bios.
Could someone check my bios, or maybe someone can post a bios that works properly?
Thanks in advance
Lenovo ThinkPad T15 Gen 1
GT4A0/GT5A1/GP4A0/GP5A1/GT4A2
NM-C931 REV 1.0
Type 20S7-S3EE00
serial number PF-22YRXJ
Hi.
Thanks in advance
NM-C931 REV 1.0
Type 20S7-S3EE00
Thank you, but the laptop on your bios does not respond to the power button. I have already put too much work into it, the laptop is going back to the customer.
Lenovo Thinkpad T15 gen 1
Serial Number: PF29NYVZ
Type Number: 20S6-000SGE
Board Number: NM-C931
Hello a question is possible to deactivate the 8GB onboard RAM in BIOS in a Lenovo T15 Gen1.
Otherwise there is probably no other way to reballing the RAM
Thank you
Thank you
