Lenovo Yoga C740-14IML MB NM-C431 REV 1.0 BIOS REQUEST
  • ub6ib969
    • Jul 2010
    • 198
    I require a clean BIOS for the Yoga C740-14IML motherboard NM-C431 REV 1.0, I have attached the dump. Thank you for all your help in advance.
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: Lenovo Yoga C740-14IML MB NM-C431 REV 1.0 BIOS REQUEST
    Originally posted by ub6ib969
    hi,
    i require a clean bios for the yoga c740-14iml motherboard nm-c431 rev 1.0, i have attached the dump. Thank you for all your help in advance.
    here you go
    • ub6ib969
      • Jul 2010
      • 198
      Thank you will try and post
      • ub6ib969
        • Jul 2010
        • 198
        thank you however it didn't work. Unit powers on fans spin however no post. please review again. thanks
        • hoaca388
          Badcaps
          • Jan 2022
          • 11806
          Yoga C740-14IML Laptop (Lenovo)
          • lapfix
            • Mar 2020
            • 2733
            • my workshop
            If bios posted by hoaca388 didn t work than try mine
            • ub6ib969
              • Jul 2010
              • 198
              It worked! however the unit is unable to boot into windows due to the security keys and bitblocker being enabled. can this be salvaged from the original bios?
              • lapfix
                • Mar 2020
                • 2733
                • my workshop
                I Think no , in this case i proceed to formate my HDD
                • lngcs
                  • Jul 2011
                  • 69
                  Hi please help me clean me. i attempt to open the bios with me analyzer keep crashing. also programmed post #6 bios got display but back to no display after ssd is plugged in. Check ssd is in perfect health. i've attached the old bios.thanks
                  • Orlin Saravia
                    • Jun 2023
                    • 16
                    • Nicaragua
                    Originally posted by qayyum786
                    here you go
                    hi, in case there is no video, even having reprogrammed the bios, do you know what I can do?
                    • bumper1
                      • Jul 2014
                      • 76
                      • Poland
                      I used bios from post #6 to test and it's working. But when I copy from old bios DMI (I tried area 0x00 522 000 - 0x00 524 000, or biger 0x00 520 000 - 0x00 524 000 ) It doesn't work (black screen). What area should I copy?
                        • 21022
                        Post your backup.. and the laptop serial number
                        • bumper1
                          • Jul 2014
                          • 76
                          • Poland
                          S/N: PF1BFT9B Thanks for help.
                            • 21022
                            try
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              I used bios from post #6 to test and it's working. But when I copy from old bios DMI .
                              Here DMI and Win key
                              Cliquez sur l'image pour la voir en taille r?elle   Nom : 		DMI LENV.jpg  Affichages :	4  Taille :		521,9 Ko  ID : 			3325725
                              decode with Xor
                              Cliquez sur l'image pour la voir en taille r?elle   Nom : 		decode.jpg  Affichages :	3  Taille :		565,1 Ko  ID : 			3325726
                                • 21022
                                I think the problem was he added his DMI to the bios at post 6, and that bios has the Debug section (9C) .His DMI 7C ,the 2 don`t play well together.To copy his DMI to the bios at post 6 he would have had to include the debug section as well 520000 - 523FFF
                                .The bios at post 5 has no debug section as its a virgin bios,only the DMI needed copying to it 522000 - 523FFF
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1226
                                  • France
                                  ok LBDG, good to know
                                  thanks
                                  • bumper1
                                    • Jul 2014
                                    • 76
                                    • Poland
                                    decode with Xor
                                    Great trick. I will remember it.
                                    try
                                    ​It is working now! I see I have different SN then on the bottom cover. Maybe someone already played with this bios. I'm finishing job for weekend. I wiil test it more in monday and report.
                                    • bumper1
                                      • Jul 2014
                                      • 76
                                      • Poland
                                      Laptop still works. Owner said that probably motherboard was replaced earlier (so there is different SN on the cover). I tried to replace 520 000 - 524 000 before my post, but no screen, mayby I did it wrong.
                                      So for the future cases. Should I copy it all with LBDG, or do I need clean LBDG section everytime?
                                      • jj.ww
                                        • Jan 2023
                                        • 21
                                        Hello Can i have help removing password from this dump
                                        SN:PF21VWFM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • HotSaladMan
                                          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                                          by HotSaladMan
                                          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                                          Model : Lenovo ThinkBook 14S Yoga ITL
                                          S/N : MP28JT19
                                          MFG Date : 2022/02/09
                                          Factory ID PRC4
                                          MO : MPNXB26080FX
                                          MTM : 20WE001US
                                          MODULE FCC ID : PD9AX201NG
                                          IC : 1000M-AX201NG
                                          BOARD INFO
                                          FLV34 LA-KO51P
                                          REV : 1B 2020-08-24
                                          Bit of Info
                                          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                                          chip id, so i would always uncheck the id check, so it would bypass the error
                                          i did in fact make...
                                          11-07-2024, 07:46 AM
                                        • beogeek
                                          Lenovo Yoga Slim 7 14APU8 Bios Request
                                          by beogeek
                                          I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                                          Attached is the bios dump in the state I received it...
                                          10-24-2024, 12:54 PM
                                        • baaligoga
                                          Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                          by baaligoga
                                          Good day, everyone!
                                          I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                          I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                          05-20-2023, 09:48 AM
