Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
  • AYsys
    • Sep 2025
    • 7
    • Deutschland
    Hello dear forum members,
    I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
    I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
    Nothing was flashed here — the BIOS was only backed up.
    I created the backup using a CH341A Black programmer and NeoProgrammer.
    When reading the BIOS chip, I disconnected the battery and then reconnected it afterwards.
    However, the device no longer starts.
    Now neither of the two devices works. The one that was flashed with the backup does not react at all to the power button. If I connect the power adapter without the battery, the LED on the power button blinks white 3 times and then nothing else happens.
    Thank you in advance — it would be great if both devices could be brought back to life. They’re not the newest models anymore, but they have always served me well.
    • 22755
    Type the laptop serial numbers, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • AYsys
      • Sep 2025
      • 7
      • Deutschland
      Hello SMDFlea,
      thank you, for your support.
      This is the device from which I created (and uploaded) the BIOS backup, and it no longer starts after the backup.
      Lenovo X1 YOGA Gen4
      Type 20QG-S5250Z
      S/N : PF-1C610G
      Mainboard:
      PSL10P97747
      FRU:01YU380
      • hoaca388
        Badcaps
        • Jan 2022
        • 12644
        Originally posted by AYsys
        Hello SMDFlea,
        Lenovo X1 YOGA Gen4
        Type 20QG-S5250Z
        S/N : PF-1C610G
        Mainboard:
        PSL10P97747
        FRU:01YU380
        X1 Yoga 4th Gen Laptop (ThinkPad) - Type 20QG
        • AYsys
          • Sep 2025
          • 7
          • Deutschland
          Hello Hoaca388,
          thank you for your support.
          Unfortunately, nothing has changed. It's still the same as before. After pressing the power button, the BIOS chip receives 3.3 V at its VCC pin; before that, there is no voltage present at the BIOS chip.
          • t77b
            • Nov 2025
            Hallo AYsys, did you find a Solution? Is this the right chip you are trying to read? I found out that there are Two Chips I guess the W25Q256JV can only be the UEFI Chip because of it´s size - 32MB. But this one is not easy to read, because i think the CH341A Programmer will not work because the clamp will not hold - thats my guess - i didn´t try it. But i have the problem, that my Laptop is locked by a supervisor password and i am looking for any solution.
            Maybe someone can help me?
            • AYsys
              • Sep 2025
              • 7
              • Deutschland
              Hi t77b,
              I couldn’t save the mainboard. I probably either applied the wrong voltage with the programmer or damaged another component while attaching it. You can replace the mainboard with this one: 01YU392. You can find it among the spare parts at Lenovo. The price currently varies and is now double what I paid, 45€. I could hardly believe it at first. After I received the mainboard, I ordered two more and successfully installed them. Good luck!
              • t77b
                • Nov 2025
                Hi AYsys, thanks for your message. Can you tell me, which the right chip is? The one beside the NVME Slot or the one under the heatsink beside the fan?
                Thank you
                • AYsys
                  • Sep 2025
                  • 7
                  • Deutschland
                  Hi t77b,
                  the chip on the cooler fan is probably the BIOS chip. According to my research, the Winbond chip is the one responsible for Thunderbolt.
                  • t77b
                    • Nov 2025
                    Hi Aysis, thanks for your answer. Yeah i found it - thank you. And it is so disapointing... the one is a WSON design Chip not a SOP - so i cant use my USB reader :-(
                    • to5it0
                      by to5it0
                      10-24-2025, 01:35 AM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • HotSaladMan
                      Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                      by HotSaladMan
                      *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                      Model : Lenovo ThinkBook 14S Yoga ITL
                      S/N : MP28JT19
                      MFG Date : 2022/02/09
                      Factory ID PRC4
                      MO : MPNXB26080FX
                      MTM : 20WE001US
                      MODULE FCC ID : PD9AX201NG
                      IC : 1000M-AX201NG
                      BOARD INFO
                      FLV34 LA-KO51P
                      REV : 1B 2020-08-24
                      Bit of Info
                      Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                      chip id, so i would always uncheck the id check, so it would bypass the error
                      i did in fact make...
                      11-07-2024, 07:46 AM
                    • beogeek
                      Lenovo Yoga Slim 7 14APU8 Bios Request
                      by beogeek
                      I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                      Attached is the bios dump in the state I received it...
                      10-24-2024, 12:54 PM
