Dell XPS 9310 GDA30 LA-J143P bios repair please
  • hoaca388
    Badcaps
    • Jan 2022
    • 12432
    #61
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by zzzac
    file attached
    thanks
    xps 13 9310
    • ZZZAC
      • Oct 2013
      • 14
      • England
      #62
      Originally posted by hoaca388
      xps 13 9310
      Thanks, unfortunately with Moderna TGL file i get 3,6 error
      • hoaca388
        Badcaps
        • Jan 2022
        • 12432
        #63
        What error code is 3.6 ?
        • ZZZAC
          • Oct 2013
          • 14
          • England
          #64
          Front light flashes 3 amber 6 white is the dell error for corrupt bios
          I also have the same issue with the TGL R file
          • hoaca388
            Badcaps
            • Jan 2022
            • 12432
            #65
            Change a blank bios chip and try again.
            • crowat
              • Dec 2022
              Has anyone solved the 2 amber, 4 white blink code (memory failure) via a bios flash? Reading through the posts, it seems a lot of people tried in this thread, but no conclusive results.
              Thank you!
              • Rockman1987
                • Jan 2021
                • Catalonia
                #67
                Hi guys!
                My laptop also gets stuck on the startup logo, but none of the USB ports work either, and it doesn't want to charge the battery through either of the two ports. Maybe my bios is corrupted?
                Motherboard model: GDA30 LA-J143P
                RegModel: P117G
                Service Tag: FT53DB3
                Thanks!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12432
                  #68
                  Originally posted by Rockman1987
                  Hi guys!
                  RegModel: P117G
                  Thanks!
                  XPS 13 9310
                  • Rockman1987
                    • Jan 2021
                    • Catalonia
                    #69
                    XPS 13 9310
                    XPS 13 9310_ModenaTgl_ v3.1.0.rar
                    XPS 13 9310_ModenaTgl_R v3.1.0.rar
                    What is the difference between the two? And which one do you recommend I try first?
                    Using MEAnalizer, I only see differences in the USB Type C Physical parameters.
                    Thanks hoaca388!
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12432
                      #70
                      Thanks hoaca388!
                      One version is Modena, one version is Modena R
                      • himmon
                        • Aug 2016
                        • 16
                        Hello Guys,
                        Please can you help me with a new clean bios dump for my laptop? I will 100% be donating to help keep a great site like this going.
                        My laptop has the 3 Amber/ 6 White flashes. What had previously happened when it was working was both USB ports stopped detecting any devices in Windows with unknown device after plugging in a Wacom dongle. So I reflashed a new bios from Dell as there was a newer one in support assist and then that was that, bricked! The Dell logo comes up, laptop charges but none of the many recovery options work.
                        I got a WSON8 Pogo pin line probe from Amazon and was luckily able to read and dump the dead bios with Neo programmer first try luckily.
                        Here are some of the details.
                        Intel i7-1185G7 11th Gen UHD+ 16GB Ram 1TB HD, 2020/12/16 Model Made in Taiwan
                        NOT a 2in1 just the normal touchscreen one.
                        Service Tag: CHHM7C3
                        Bios Chip XMC QH256BXiQ
                        Please let me know if you need any other numbers needed as I’m a complete novice at this. Noticed a whole bunch of numbers on the inside of the aluminum back cover next to a QR code if needed?
                        Many thanks all.
                        • Markus1741
                          • Sep 2020
                          • 981
                          • N/A
                          #72
                          Originally posted by himmon
                          Hello Guys,
                          Please let me know if you need any other numbers needed as I'm a complete novice at this. Noticed a whole bunch of numbers on the inside of the aluminum back cover next to a QR code if needed?
                          Many thanks all.
                          Hello try this file ...
                          • himmon
                            • Aug 2016
                            • 16
                            Thank you very much Markus, I will give it a try.
                            • himmon
                              • Aug 2016
                              • 16
                              Hello Markus, unfortunately, didn't work.
                              I detected IC with NeoProgrammer, successful.
                              Erased IC, success.
                              Write IC with your new bios, success,
                              Verified IC, success.
                              Disconnected NeoProg,
                              Reconnected the battery, won't turn on, and nothing is on display now.
                              Held the power button for 12 seconds, but nothing. Tried the CTRL and ESC and plugin power, but nothing.
                              All that happens if I press the power button, the orange LED on the front illuminates. If I let go of the power button, the orange LED goes off. If I tap power a few times, it flashes the orange LED a few times at the same time as pressing power.
                              • Markus1741
                                • Sep 2020
                                • 981
                                • N/A
                                #75
                                Erased IC, success.
                                Hello, try these...
                                You can also try these from hoaca388, they are ME Clean, good luck...
                                https://www.badcaps.net/forum/showpo...0&postcount=68
                                • himmon
                                  • Aug 2016
                                  • 16
                                  Tried the other bios you attached, exact same result, won't turn on, orange LED when the power is pressed. With my original broken bios, the screen was on with the Dell logo with 3 and 6 flashes.
                                  Do I need to give any more info than just other than the service tag, not sure where to find the motherboard model number etc if that helps? With neoprogrammer, takes about 5 mins to flash and 5 mins to verify using black CH314A. Detects the IC chip exactly. When reading the IC again, it has definitely written a lot of data instead of just all FF FF FF, etc.
                                  Thank you very much for your help so far.
                                    • 22233
                                    XPS 13 9310_ModenaTgl_ v3.1.0.rar Tiger lake
                                    XPS 13 9310_ModenaTgl_R v3.1.0.rar Tiger lake refresh
                                    • himmon
                                      • Aug 2016
                                      • 16
                                      Hello SMDFlea,
                                      Thanks for confirming they're for Tigerlake which I have as its an 11th Gen i7,
                                      So I could just try flash either of those? My Service Tag: CHHM7C3
                                      But I assume you don't need that when I flash either one of those bios that may work as it'll ask me to confirm the service tag if it boots?
                                      Cheers
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12432
                                        #79
                                        Hello Guys,
                                        Many thanks all.
                                        Try version 1.0.3
                                        • himmon
                                          • Aug 2016
                                          • 16
                                          Hello hoaca388,
                                          Thank you for this new bios, so far this is looking way more positive but still some problems.
                                          After erasing and flashing this bios, the laptop now switches on and goes through the red green blue screen test for about 3 cycles, then switches off, reboots, comes back on, and shows the Dell screen but is stuck. Left it for 5 minutes.
                                          So I tried holding power to force turn off. Then pressing F12 or F2 repeatedly and immediately when pressing the power button turns the dell screen logo and keyboard backlight on and off every time I press either F12 or F2. The front LED is constantly flashing white on and off during all of this.
                                          Should I try disconnecting and reconnect the battery or maybe bios problem still?
                                          Really appreciate all your time with this.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
