Dell 15-7570 Bios problem
  • ProSis
    • Jun 2017
    • 87
    • Turkey
    My dell 15-7570 model laptop has a bios problem. It does not display with its own bios file. I get an image with the bios file I found here, but when I write servicetag and save, the image does not appear and it pulls around 1.20A and shuts down.
    Anyone come across and solve it?
    Mainboard : LA-E991P Rev 1.0 ( GPU : N17P-G0-A1 )
    • 22288
    Re: Dell 15-7570 Bios problem
    Post your original bios backup
    • ProSis
      • Jun 2017
      • 87
      • Turkey
      ORG NO SCREEN - 16.0 MB
      BİOS FİLE I FOUND. THERE İS AN İMAGE.
      Problems with the bios I'm getting images from:
      1 ) When I turn off the computer, it starts very late. If I press the power button many times, it just turns on.
      2 ) As long as the bios battery is not installed, the device displays images at every boot.
      but once the bios battery is inserted, it does not display again.
      It pulls to 1.20 and shuts down and there is no image.
      In order for the image to appear again, the bios battery must be removed and the adapter must be disassembled and re-plugged.
      If I insert the bios battery while the adapter is plugged in, it continues to display every time I turn it on and off. but when I remove and plug in the adapter, I can't get an image again.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Look like error hardware.
          • 22288
          The original non working bios you posted is from an Inspiron 15 Gaming 7577 ,the OS it shipped with was Ubuntu
          Service tag: C991QH2 .Is that the service tag on the case ?
          The other bios you posted is also from an Inspiron 15 Gaming 7577 (win 10 OS ) ,its "initialised" which means the ME firmware is dirty, it will not work properly unless the ME firmware is cleaned.
          What do you want, the original ubuntu bios or a different win 10 bios
          • ProSis
            • Jun 2017
            • 87
            • Turkey
            Service tag : C991QH2
            I would be very happy if the original bios is fixed.
            I cleared the me region of the device from which I took the image, but it still behaves the same. ( problem 1 and 2 persists even though the me area has been cleared. )
              • 22288
              try this one.If there`s no change it could be a problem with the RTC circuit.
              • ProSis
                • Jun 2017
                • 87
                • Turkey
                What do I need to pay attention to by checking where especially in the rtc circuit?
                • bouny56
                  • Jan 2023
                  • 68
                  • france
                  Dell Vostro 7570 charging problem
                  Hello
                  my 7570 is not charging
                  Battery detect ok
                  Charger detect ok
                  Test with other new battery same, other charger same ( 90w , 130w , 180w )
                  The batterie stay at the same volt with the charger but don't charge more , same with other battery
                  motherboard : CKA50 LA-E991P
                  Bat dat et clock 3v
                  and bat pres 3v with no battery, 0v with battery
                  Maybe bios problem ?
                  Thx
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Re: Dell Vostro 7570 charging problem
                    Originally posted by bouny56
                    Hello
                    my 7570 is not charging...
                    You must post the Service tag.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • bouny56
                      • Jan 2023
                      • 68
                      • france
                      Hello , thx for answer
                      Service Tag : FBL8242
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        Vostro 15 7570
                        Service Tag: FBL8242
                        • bouny56
                          • Jan 2023
                          • 68
                          • france
                          Originally posted by hoaca388
                          Vostro 15 7570
                          Thanks for your help, i try tomorrow
                          • bouny56
                            • Jan 2023
                            • 68
                            • france
                            Hello, reflash bios, same problem, batterye detect, charger detect but not charging. Change the bp ship same
                            • Matias1997caba
                              Problem with Dell pp35l bios
                              by Matias1997caba
                              Hello everyone! I'm having a problem with the BIOS of a Dell PP35L motherboard (DA0RM5MB8E0 Rev:E Y509R Rev:A00). It powers on, beeps 5 times, then 6 times, but there's no display. The problem is that it has two 16MB BIOS files, and all the ones I found online are 1MB and 4MB. I flashed them anyway, but with those BIOS files, the fan doesn't even turn on. Any help would be greatly appreciated! I've attached the BIOS files. Model: Dell PP35L.. Mother DA0RM5MB8E0 Rev:E Y509R Rev:A00. Service Tag: GRZR9M1...
                              11-26-2025, 08:33 AM
                            • toti24
                              (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                              by toti24
                              dell precision m4600 laptop
                              i7 2760qm
                              8gb ram 750gb HDD
                              intel hd 3000 integraded and nvidia quadro 2000m
                              pleasea bear with me english isnt my language and ill try to be as clear as possible
                              note i live in mexico in a very small town..
                              thank you.
                              laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                              the brick happened when i was installing win 10 using usb.
                              used rufus and officia microsoft.iso
                              it finished copying files from usb...
                              03-06-2022, 08:39 PM
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • Akhlz001
                              by Akhlz001
                              09-20-2025, 07:15 PM
