Dell Microsoft autopilot issue
  • Mekong500
    • Oct 2024
    • 22
    • Poland
    #61
    However you call it, I meant "unlock" because it won't let me go trough win11 setup because of autopilot. Seriously, you didn't understand?
    Anyway, your file didn't work because company logo is still in fresh win 11. Let's finish this useless discussion
    • volinakis
      • Jan 2021
      • 2874
      • N/A
      #62
      Seriously, "unlock" is something else than removing Autopilot, you are welcome! So ... you didn't figure out yet that you have to reinstall win after bios modification, because marker is already in registry keys? And choose "I don't have internet" when you setup account? Seriously?
      • Mekong500
        • Oct 2024
        • 22
        • Poland
        #63
        I've programmed the chip, soldered it back, erased the drive, insalled fresh OS and it's still the same as before, what means autopilot was not removed
        • volinakis
          • Jan 2021
          • 2874
          • N/A
          #64
          sure, your pc is special, one of a kind! It takes the marker from thin air even is deleted in bios ...
          • Mekong500
            • Oct 2024
            • 22
            • Poland
            #65
            Believe me or not, it added third autopilot_marker and now are three, two invalid and one valid. There is no reason to lie.
            I read the chip after trying new BIOS file, reinstalling OS etc, it's ss of the new BIOS bin file in UEFITool
            • volinakis
              • Jan 2021
              • 2874
              • N/A
              #66
              post bios backup.
                • 21960
                Originally posted by volinakis
                post bios backup.
                And the service tag !
                • Mekong500
                  • Oct 2024
                  • 22
                  • Poland
                  #68
                  ST: DZS4813
                  • Mekong500
                    • Oct 2024
                    • 22
                    • Poland
                    #69
                    Just an info: Today I tried your method with another PC (same model optiplex 7070) and it works as it should, autopilot is removed. I don't know why it doesn't work with the first one
                      • 21960
                      ST: DZS4813
                      try this one.
                      • Mekong500
                        • Oct 2024
                        • 22
                        • Poland
                        #71
                        I just tried this, I installed Win11 Pro and I was able to choose "I don't have internet". Thank you very much for your help
                        • the Benninger
                          • Nov 2022
                          • 189
                          • venezulan
                          #72
                          my answer depends on if you can install a USB keyboard, at the start of the windows installation (right at the part where you decide the country and language) you can open a CMD window pressing (alt+F10) then type OOBE\ByPassNRO enter if all went well you will get a reboot with the (NRO) disabled then continue the installation but this time you can click on (I don't have internet) to create a local account
                          ​I hope this helps you solve your dilemma
                          • ali0robot
                            • Mar 2023
                            • 83
                            • N/A
                            #73
                            Hi all guys,
                            I have the same problem with lots of laptops in my workplace. in some cases when I download the bios bin from this website and reprogram that bios the autopilot page disappears but in some cases, it remains. I couldn't find which part of the bios is important on the Microsoft website. we can't use the option ( I don't have internet). On the other hand, we have to install the Windows Home version.
                            I attached two bios bins one of them is for Dell 7490 and one is for Dell 7390. with the 7390 bios bin autopilot page disappeared but with the 7490 bios bin still, autopilot is active and doesn't let us install Windows as a new account for customers. I would be so grateful if someone can find a difference
                              SMDFlea commented
                              Editing a comment
                              Service tags ???????????
                          • ali0robot
                            • Mar 2023
                            • 83
                            • N/A
                            #74
                            I explained how it works in this thread. It's simple to open bios with UEFITool and see how it can be invalidated an entry, depends by bios platform.
                            Click image for larger version Name:	Screen Shot 2025-02-06 at 21.41.40.png Views:	0 Size:	104.9 KB ID:	3565962
                            Click image for larger version Name:	Screen Shot 2025-02-06 at 21.39.11.png Views:	3 Size:	130.8 KB ID:	3565960
                            this change doesn't make any change in Autopilot, in HxD show invalid but after fresh installation autopilot again appear. even when I change those bit to 13 13 also HxD shows is invalid. I am confuse what change should we make to bypass autopilot in this kind of bios bi. I appreciate volinakis guide for different platform of bios that need just change 3f to 3c. that on work for me on several bios bin
                            • ali0robot
                              • Mar 2023
                              • 83
                              • N/A
                              #75
                              Originally posted by ali0robot
                              Hi all guys,
                              it's sorted, thank you
                              • mikhail64
                                • May 2025
                                • 4
                                • Russia
                                #76
                                I have a Dell Latitude 7220, and after reading this thread, I'm struggling to resolve my issue. When installing Windows, the system prompts for organizational credentials. From what I understand, I need to remove the autopilot_marker and related tags to bypass this.
                                However, the structure of my BIOS dump differs from the solution discussed here. I dumped my BIOS using:fptw64 -bios -d bios.bin
                                I've attached my BIOS dump for reference. Could someone please help me modify it correctly? Any guidance would be greatly appreciated!
                                Thanks in advance.​
                                • Aditya11ttt
                                  Adi
                                  • Feb 2019
                                  • 190
                                  • India
                                  #77
                                  Thanks in advance.​
                                  try
                                  • peste
                                    peste commented
                                    Editing a comment
                                    Please don't help if you don't follow the forum rules.
                                • peste
                                  • Dec 2016
                                  • 13653
                                  • ROMANIA
                                  #78
                                  Thanks in advance.
                                  post S/T, full name and model, motherboard model, etc.
                                  • mikhail64
                                    • May 2025
                                    • 4
                                    • Russia
                                    #79
                                    S/T: D9BHYX2
                                    Full model: Dell Latitude 7220 Rugged Extreme Tablet
                                    Motherboard: 015GKW
                                    • peste
                                      peste commented
                                      Editing a comment
                                      you got the answer above..try...
                                  • ali0robot
                                    • Mar 2023
                                    • 83
                                    • N/A
                                    #80
                                    S/T: D9BHYX2
                                    Motherboard: 015GKW
                                    try and give result
                                    • SuperJames
                                      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                      by SuperJames
                                      This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                      Specs
                                      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                      Backstory
                                      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                      10-23-2023, 04:09 PM
                                    • hazem3636
                                      need Bios Bin file Dell server 220
                                      by hazem3636
                                      hi everyone
                                      i need dump file for dell server r220
                                      i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                      i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                      if anyone has this method please need his supporting .
                                      all the best
                                      EXE file is attched and Original Bin file from the Bios Chip is attached also
                                      and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                      11-05-2022, 06:20 AM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • Ven
                                      Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                      by Ven
                                      Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                      Issue Description:
                                      1. CPU Overheating to 100°C
                                        • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                        • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                        • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                        • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                        • Thermal
                                      02-12-2025, 03:57 PM
                                    • NotEnough
                                      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                      by NotEnough
                                      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                      What I've Tried So Far:
                                      • Reseated the cables.
                                      • Reinstalled AWCC and AlienFX services.
                                      • Attempted BIOS downgrade but no improvement.
                                      • Inspected ribbon cables for damage.
                                      • Explored the possibility of BIOS or
                                      10-19-2024, 01:34 AM
