Dell Latitude 5400 bios request
    Originally posted by U_pasta View Post
    According to the description in your notebook's documentation, the service tag is a no-vpro.
    According to your motherboard diagram, the no-vpro processor uses two bios:
    uc5 8mb
    uc6 16mb
    You need to join the two files to assemble the biosrom.bin.
    No, it is just one chip.
      This quote is not for your case, it is for a Latitude 5400 non-vpro.
      In your case #199, the bios is vpro 32mb, already sent.
      Did you test it? Can you give me feedback on the test?
        Hello everyone? Can anyone help me with this bios?. This is the original bios, now it won't turn on. I only know the machine information is: currently can't turn on the power.
        Dell 5400
        Serial: unknown
        Service tag: unknown
        Motherboard: EDC41 LA-G891P Rev: 1.0 (A00)
        File :
          Dell Latitude 5400 that doesn't POST and keeps rebooting. UC6 unpopulated, UC5 is a GD25B256D.
          Service tag: 86KT733
            Originally posted by minhdigital View Post
            Send to you
            Tried this one, but same behavior unfortunately.
            https://streamable.com/e/tclrk8
            Fan at max speed, keyboard backlight and caps lock indicator always on except when it fully restarts.
              Originally posted by hoaca388 View Post
              Latitude 5400
              Same with this one. I have also tried replacing the ME region in the original dump as explained at https://winraid.level1techs.com/t/gu...lization/31277.
              The processor is not getting warm and the coil near it has no voltage. The RAM voltage is OK. Battery doesn't appear to be charging.
              Any ideas?
                Any ideas?
                Latitude 5400
                Service Tag: 86KT733
                Become a Badcaps supporter
                Thanks to all supporters.
                  Thank you.
                  Unfortunately I see no changes, but I have extra information: when I connect the battery and turn on the computer, after a while the LED on the front shows the following sequence: 2 amber, 1 white
                  According to Dell's manual this indicates CPU failure... can we exclude a BIOS issue or do you want to provide another binary I can test?
                    Thank you.
                    No, focus on finding hardware problems.
                      Thank you, your BIOS is working perfectly (and probably the other ones I flashed too).
                      The issue was indeed the CPU, which was actually being supplied with ~1V but appeared to be dead. I solved it with a proper reflow.
ID:	3638842 Click image for larger version
                      I hope this is helpful for anyone in the same situation.
                      And, for reference, here are some thermal images before the fix:
ID:	3638847 Click image for larger version
ID:	3638846 Click image for larger version
ID:	3638845 Click image for larger version
ID:	3638844 Click image for larger version
                        Dell Latitude 5400
                        Service Tag (S/N) 4S34X33
                        MB Part number LA-G891P
                        BIOS IS LOCKED
                        PLEASE ANY ONE HELP
                        HERE IS MY BIOS LOCKED
                          Originally posted by OmanCloud View Post
                          Dell Latitude 5400
                          BIOS IS LOCKED
                          PLEASE ANY ONE HELP
                          try...
                            Originally posted by peste View Post
                            try...
                            Same
                              Dell Latitude 5400
                              BIOS IS LOCKED
                              PLEASE ANY ONE HELP
                              try and feedback
                                Dell Latitude 5400
                                Service Tag (S/N) HCMRYY2
                                BIOS IS LOCKED
                                PLEASE ANY ONE HELP
                                HERE IS MY BIOS LOCKED - THANKS IN ADVANCE
                                  Originally posted by david19 View Post
                                  Dell Latitude 5400
                                  BIOS IS LOCKED
                                  PLEASE ANY ONE HELP
                                  Try and Give Feedback
                                    worked but wrong SERVICE TAG. many thanks
                                      Dell Latitude 5400
                                      BIOS IS LOCKED
                                      PLEASE ANY ONE HELP
                                      Unlocked
                                        Hello everyone, help me remove the password from this laptop.
                                        Motherboard model:
                                        DELL Latitude 5400
                                        Motherboard: EDC41 LA G891P Rev 1.0 (A00) 2019-03-28
                                        Service Tag: G40RF13
                                          Motherboard model:
                                          DELL Latitude 5400
                                          Read the bios guides password topic, you might find a way to unlock it yourself, depending on what the suffix is ->
                                          BIOS guides, methods, resources and tools
                                          https://www.badcaps.net/forum/troubl...rces-and-tools
