Dell Latitude 5400 bios request
  • olexky
    • Mar 2025
    Originally posted by U_pasta
    According to the description in your notebook's documentation, the service tag is a no-vpro.
    According to your motherboard diagram, the no-vpro processor uses two bios:
    uc5 8mb
    uc6 16mb
    You need to join the two files to assemble the biosrom.bin.​
    No, it is just one chip.
    • U_pasta
      • May 2020
      • 12
      • Brazil
      #202
      This quote is not for your case, it is for a Latitude 5400 non-vpro.
      In your case #199, the bios is vpro 32mb, already sent.
      Did you test it? Can you give me feedback on the test?
      • hongsangkt
        • May 2025
        • kon tum
        #203
        Hello everyone? Can anyone help me with this bios?. This is the original bios, now it won't turn on. I only know the machine information is: currently can't turn on the power.
        Dell 5400
        Serial: unknown
        Service tag: unknown
        Motherboard: EDC41 LA-G891P Rev: 1.0 (A00)
        File :​
        • davidebeatrici
          • Dec 2020
          • 86
          • Italy
          #204
          Dell Latitude 5400 that doesn't POST and keeps rebooting. UC6 unpopulated, UC5 is a GD25B256D.
          Service tag: 86KT733
          • davidebeatrici
            • Dec 2020
            • 86
            • Italy
            #205
            Originally posted by minhdigital
            Send to you
            Tried this one, but same behavior unfortunately.
            https://streamable.com/e/tclrk8
            Fan at max speed, keyboard backlight and caps lock indicator always on except when it fully restarts.
            • davidebeatrici
              • Dec 2020
              • 86
              • Italy
              #206
              Originally posted by hoaca388
              Latitude 5400
              Same with this one. I have also tried replacing the ME region in the original dump as explained at https://winraid.level1techs.com/t/gu...lization/31277.
              The processor is not getting warm and the coil near it has no voltage. The RAM voltage is OK. Battery doesn't appear to be charging.
              Any ideas?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11728
                #207
                Any ideas?
                Latitude 5400
                Service Tag: 86KT733​
                • davidebeatrici
                  • Dec 2020
                  • 86
                  • Italy
                  #208
                  Thank you.
                  Unfortunately I see no changes, but I have extra information: when I connect the battery and turn on the computer, after a while the LED on the front shows the following sequence: 2 amber, 1 white
                  According to Dell's manual this indicates CPU failure... can we exclude a BIOS issue or do you want to provide another binary I can test?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11728
                    #209
                    Thank you.
                    No, focus on finding hardware problems.
                    • davidebeatrici
                      • Dec 2020
                      • 86
                      • Italy
                      #210
                      Thank you, your BIOS is working perfectly (and probably the other ones I flashed too).
                      The issue was indeed the CPU, which was actually being supplied with ~1V but appeared to be dead. I solved it with a proper reflow.
ID:	3638842 Click image for larger version
                      I hope this is helpful for anyone in the same situation.
                      And, for reference, here are some thermal images before the fix:
ID:	3638847 Click image for larger version
ID:	3638846 Click image for larger version
ID:	3638845 Click image for larger version
ID:	3638844 Click image for larger version
                      • OmanCloud
                        • Aug 2023
                        • 17
                        • Oman
                        #211
                        Dell Latitude 5400
                        Service Tag (S/N) 4S34X33
                        MB Part number LA-G891P
                        BIOS IS LOCKED
                        PLEASE ANY ONE HELP
                        HERE IS MY BIOS LOCKED
                        • peste
                          • Dec 2016
                          • 12786
                          • ROMANIA
                          #212
                          Originally posted by OmanCloud
                          Dell Latitude 5400
                          BIOS IS LOCKED
                          PLEASE ANY ONE HELP
                          try...
                          • OmanCloud
                            • Aug 2023
                            • 17
                            • Oman
                            #213
                            Originally posted by peste
                            try...
                            Same
                            • LBTT1121
                              • Nov 2024
                              • 524
                              • Việt Nam
                              #214
                              Dell Latitude 5400
                              BIOS IS LOCKED
                              PLEASE ANY ONE HELP
                              try and feedback
                              • david19
                                • Oct 2021
                                • 4
                                • Vietnam
                                #215
                                Dell Latitude 5400
                                Service Tag (S/N) HCMRYY2
                                BIOS IS LOCKED
                                PLEASE ANY ONE HELP
                                HERE IS MY BIOS LOCKED - THANKS IN ADVANCE​
                                • OmanCloud
                                  • Aug 2023
                                  • 17
                                  • Oman
                                  #216
                                  Originally posted by david19
                                  Dell Latitude 5400
                                  BIOS IS LOCKED
                                  PLEASE ANY ONE HELP
                                  Try and Give Feedback
                                  • david19
                                    • Oct 2021
                                    • 4
                                    • Vietnam
                                    #217
                                    worked but wrong SERVICE TAG. many thanks
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11728
                                      #218
                                      Dell Latitude 5400
                                      BIOS IS LOCKED
                                      PLEASE ANY ONE HELP
                                      Unlocked
                                      • ingenieroedu
                                        • May 2023
                                        • 69
                                        • Colombia
                                        #219
                                        Hello everyone, help me remove the password from this laptop.
                                        Motherboard model:
                                        DELL Latitude 5400
                                        Motherboard: EDC41 LA G891P Rev 1.0 (A00) 2019-03-28
                                        Service Tag: G40RF13​
                                          • 20865
                                          Motherboard model:
                                          DELL Latitude 5400
                                          Read the bios guides password topic, you might find a way to unlock it yourself, depending on what the suffix is ->
                                          BIOS guides, methods, resources and tools
                                          https://www.badcaps.net/forum/troubl...rces-and-tools
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • DavidChunco
                                            Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                            by DavidChunco
                                            Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                            - Receive help from Dell Support (it is out of warranty).
                                            - Disconnect machine from AC power and battery overnight.
                                            - BIOS recovery process
                                            - Connected external display via HDMI
                                            - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                            03-15-2025, 11:00 AM
                                          • Loli Popu
                                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                            by Loli Popu
                                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                            12-13-2024, 08:29 AM
