bios for lenovo y540-15irh (81sx)
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    #61
    Originally posted by CirebeaTiberiu
    File open error
    File bios is ok.
    • CirebeaTiberiu
      • Aug 2021
      • 22
      • Romania
      #62
      File open error
      I can't open this file in RT809F
      • JelloC19
        • Apr 2024
        • 3
        • Deutschland
        #63
        Greetings from Germany, thanks to this thread i was able to fix my Laptop with the bios posted in here (Version 44ww). In my first attempt to downgrade with the normal installer i bricked my device, now i want to use the CH341a and need to shrink the bin file of the installer so that i can write to the chip manually. I want to install the Version 27WW. and was hoping some could shrink it for me. Thanks in Advance.
      • JelloC19
        • Apr 2024
        • 3
        • Deutschland
        #64
        Oh of course SMDFlea her is my model number "lenovo legion y540-17irh" and my Serial number "PF1VZCGZ"
          • 21679
          Post the corrupt backup as well please
          • JelloC19
            • Apr 2024
            • 3
            • Deutschland
            #66
            SMDFlea Okay its not corrupted though, i want to downgrade so that undervolting is unlocked again. And thank you very much for your help! ^^
            • winix
              • May 2023
              • 5
              • Nigeria
              #67
              I need help with my legion Y540, it powers on with keyboard light and it's also charging.
              I have programmed eventually all the bios file in this thread, each giving different symptoms
              • peste
                • Dec 2016
                • 13420
                • ROMANIA
                #68
                post the original bios of the laptop even if it is corrupted,​post the S/N,the motherboard model, the full name and model of the laptop,etc.
                • Rysiu001
                  • Apr 2022
                  • 3
                  • Poland
                  #69
                  Originally posted by peste
                  Re: bios for lenovo y540-15irh (81sx)
                  bios extracted from the Lenovo site update
                  DMI 632000 - 633FFF
                  I changed dmi and the laptop now does not turn on in any bios. Previously, it didn't turn on with the button, only after plugging in the power supply
                  • peste
                    • Dec 2016
                    • 13420
                    • ROMANIA
                    #70
                    Click image for larger version  Name:	dataurl629094.png Views:	0 Size:	365 Bytes ID:	3481940
                    you wrote the DMI information in another interval... if you write it correctly it will work.. try again.. make a copy of the original bios before writing..
                    • Rysiu001
                      • Apr 2022
                      • 3
                      • Poland
                      #71
                      I changed these sections
                      • peste
                        • Dec 2016
                        • 13420
                        • ROMANIA
                        #72
                        maybe you didn't solder the bios chip well.. something happened, maybe you blew some resistance around the chip with the hot air from the blower.. check..
                        • Rysiu001
                          • Apr 2022
                          • 3
                          • Poland
                          #73
                          It's hard to say because I don't have boardview,
                          should your bios work without any changes?
                          • peste
                            • Dec 2016
                            • 13420
                            • ROMANIA
                            #74
                            Click image for larger version  Name:	dataurl953613.png Views:	0 Size:	365 Bytes ID:	3482366
                            Click image for larger version  Name:	dataurl847938.png Views:	0 Size:	365 Bytes ID:	3482365
                            yes... you don't make any more changes... it works even without DMI... but you will get a message to this effect every time you turn on the laptop... remove the bios chip from the board before writing... this is if the problem is the bios and you write it correctly..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                            • krogs214
                              • Sep 2017
                              • 84
                              • Philippines
                              #75
                              Hi can you guys clear me this bios
                              Lenovo Y540 15irh
                              Sn no. PF149W79
                              • shiyab
                                • Sep 2023
                                • 1592
                                • india
                                #76
                                Lenovo Y540 15irh
                                Sn no. PF149W79
                                hi try new file
                                • krogs214
                                  • Sep 2017
                                  • 84
                                  • Philippines
                                  #77
                                  Originally posted by shiyab
                                  hi try new file
                                  thank you
                                  • underbreak
                                    • Aug 2023
                                    • 12
                                    • France
                                    #78
                                    Hi everyone ! I buy recently a Y540-15IRH 81sx for gaming, was perfectly fine for month, then i updated everything with Vantage and they apparently updated the bios. Unfortunatly, after restart, i can't get any post on display, it's black, no backlight.
                                    The keyboard light up for 5 sec with fan at low speed, then stop, after 60 sec the laptop turn fan to max speed, i can heard a this time the windows boot intro sound, then it shut down after 10 sec.
                                    I already tryed to reflash the bios via a CH341a with almost all bios i found of this model on the forum, but no sign of life...
                                    I put here my old dump, if anyone can get me a clean bios that work, i would be very grateful ! TY
                                    • volinakis
                                      • Jan 2021
                                      • 2872
                                      • N/A
                                      #79
                                      post serial no, according to rules of this forum
                                      • underbreak
                                        • Aug 2023
                                        • 12
                                        • France
                                        #80
                                        Hey, Oups my bad here he is : PF2JYVLN
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
