bios for lenovo y540-15irh (81sx)
  • Pryrex
    • Sep 2023
    • 5
    • England
    #41
    Re: Need help unbricking Lenovo Legion Y540-15IRH
    Unfortunately I've just tried it and it still has the issue..
    Do you think it could be because when I tried it this time I had the integrated battery disconnected and I've powered up the laptop only from the AC?
    Other than that, is there anything left that I could try?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12272
      #42
      If the error is due to bios then with the file I posted it should work.
      • Pryrex
        • Sep 2023
        • 5
        • England
        #43
        Understood... I guess the only thing left to do is to get it to a repair service and see what's their diagnose.. Thank you very much for the help though!
        • madjid911
          • Dec 2016
          • 408
          • France
          #44
          Originally posted by peste
          Re: bios for lenovo y540-15irh (81sx)
          bios extracted from the Lenovo site update
          DMI 632000 - 633FFF
          thank you it worked for me, following a dead mosfet on the graphics card, the laptop no longer turned on, I changed the mosfet, it turned on but did not display the startup logo and stuck on a screen empty, with this new bios it worked it starts with the logo, accesses the bios, but with lines on the screen, like the graphics card was dead or will die, can we have a bios without the graphics card enablement function?
          • madjid911
            • Dec 2016
            • 408
            • France
            #45
            If it helps anyone, I tried to heat the graphics card to do a reflow with a reballing machine, but that didn't change anything, I changed the bios to the latest version, still the same , display traits, I see very little what is marked on the screen, but I tried to change the bios settings, and I found Graphic Device in the bios settings, so I changed Discrete Graphics by Switchables Graphics, I now have a very clean display.
            Click image for larger version  Name:	407379488_681306707470892_5102048882236623459_n.jpg Views:	0 Size:	84.5 KB ID:	3165678
            • bouny56
              • Jan 2023
              • 64
              • france
              #46
              DMI 632000 - 633FFF
              Hello , i try your to file and add my dmi , but same problem , blinking white power button, fan turn but no display.
              My original bios
              mb : nm-c221
              model : 81SX
              sn : PF2E0JZ7
              I check resistance and voltage, seem to be good
              did you think of hardware problem ? or maybe try an another bios ?
              Thx
              • hoaca388
                Badcaps
                • Jan 2022
                • 12272
                #47
                My original bios
                mb : nm-c221
                model : 81SX
                sn : PF2E0JZ7
                Thx
                PF2E0JZ7
                • bouny56
                  • Jan 2023
                  • 64
                  • france
                  #48
                  Originally posted by hoaca388
                  PF2E0JZ7
                  Hello, thanks for your help. Same symptom 3 reboot and always white blink
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12272
                    #49
                    Find hardware isues, this file was solved by someone else.
                    • kaptenson
                      • Jan 2024
                      • 4
                      • Magyarország
                      #50
                      Hi all!
                      I did the ch341a programming successfully, thanks for help!
                      Only one little problem: I tried everything, but the keyboard backlight is not working.
                      The Lenovo Vantage shows it's ON or OFF, and all other fn keys working..
                      This problem started when I turned off and on the laptop again and again before the bios programming. I tried turning on and off with power button and with NOVO button, too.
                      Does someone know the bin file contain the keyboard firmware/driver or what should I do? I tried everything.
                      - Lenovo Hotkey installed
                      - Lenovo Vantage installed
                      - all driver installed in Windows update (even the optional ones), in Intel Driver & Support Assistant and in Lenovo Vantage
                      There is a video on youtube, I already tried everything what's in it.
                      https://www.youtube.com/watch?v=eOugF4RSXOk
                      Please help, thanks.
                      Lenovo Legion Y540-15irh-pg0
                      Model name: 81SY
                      MTM: 81SY00CRHV
                      S/N: PF1XDEEL
                      Bios version: bhcn45ww
                    • kaptenson
                      • Jan 2024
                      • 4
                      • Magyarország
                      #51
                      DMI 632000 - 633FFF
                      Can you help me with motherboard numbers?
                      In the System Information the "baseboard product" is "INVALID" and the "baseboard version" is "No DPK".
                      What is the address of these datas? Or should I find in this interval "DMI 632000 - 633FFF"?
                      • peste
                        • Dec 2016
                        • 13436
                        • ROMANIA
                        #52
                        use the HxD program (you can find it for free).. insert the laptop bios and the bios from the Lenovo website into it and transfer this interval from the laptop bios to the one on the website (copy-paste)...
                        • kaptenson
                          • Jan 2024
                          • 4
                          • Magyarország
                          #53
                          I already did the copy+paste. And I just realized the product name is false in bios. It should be "lenovo legion y540-15irh-pg0", and now it's "lenovo legion y540-15irh". Can there be a connection between keyboard backlight and the false product name/missing baseboard version?
                          Anyways, if there is not relation between these two things, the keyboard's backlight still not working.
                          • kaptenson
                            • Jan 2024
                            • 4
                            • Magyarország
                            #54
                            I repared today the keyboard backlit. The cable had slipped out of the socket. Now it's working.
                            Thank you all!
                            • CirebeaTiberiu
                              • Aug 2021
                              • 22
                              • Romania
                              #55
                              Hello guys
                              Can you help me with this bios please?
                              Laptop starts but no more image
                                • 21679
                                Originally posted by CirebeaTiberiu
                                Hello guys
                                Post the serial number https://www.badcaps.net/forum/troubl...before-posting
                                • CirebeaTiberiu
                                  • Aug 2021
                                  • 22
                                  • Romania
                                  #57
                                  Originally posted by SMDFlea
                                  Model 81SX
                                  S/N PF1YP173
                                  MTM 81sx0074RM
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12272
                                    #58
                                    Model 81SX
                                    S/N PF1YP173
                                    MTM 81sx0074RM
                                    Laptop Legion Y540-15IRH (Lenovo) - Loại 81SX
                                    • CirebeaTiberiu
                                      • Aug 2021
                                      • 22
                                      • Romania
                                      #59
                                      TY hoaca but when i select file in programator sais FILE OPEN ERROR
                                      • CirebeaTiberiu
                                        • Aug 2021
                                        • 22
                                        • Romania
                                        #60
                                        File open error
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
