bios for lenovo y540-15irh (81sx)
  • peste
    • Dec 2016
    • 13439
    • ROMANIA
    Re: bios for lenovo y540-15irh (81sx)
    Originally posted by brontobyte
    i already solved. Thanks
    how did you solve it??
    • brontobyte
      • Jul 2021
      • 85
      • Romania
      i used one bios dump downloaded from this thread.
      • REPARE76
        • Oct 2021
        • france
        Hello
        Which file did you use to solve your problem please?
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Originally posted by REPARE76
          Hello
          Yes indeed, it must be shown with a quote or post number, because it could be in help for someone else.
          Become a Badcaps supporter
          Thanks to all supporters.
          • rex98
            • Feb 2023
            • 1289
            • Mandaue CEBU, Philippines
            The original bios dump i use works and boot but after i shutdown it doesn't boot anymore like dead but when i reset the CMOS it boots up ang working fine intel uhd and nvdia are detected and running fine in stress test. the only problem with the bios dump original is that when i shutdown it becomes stone dead no lights, cmos needs to be reset to turn on again.
            CAN SOMEONE FIX THIS PLEASE.
            • rex98
              • Feb 2023
              • 1289
              #26
              HELLO EVERYONE
              I have some issues with this machine:
              lenovo Y540-15irh 81sx
              s/n PF1468B6
              This laptop is not turning on after restart. Only keyboard backlight and black screen. It takes a few minutes to be able to turn on again.
              Video card is performing good. Good temperature and performace.
              I attached bios dump.
              i also have same problem what bios did you use?
              • rex98
                • Feb 2023
                • 1289
                #27
                i dont know if this is EC or something i just found this at back of the board and read the contents. maybe this is the problem help please
                • coxep89151
                  • Jun 2023
                  • 3
                  Corrupted bios Lenovo Y540-15IRH
                  My laptop stopped working after changing some bios settings. Laptop starts but only black screen (not gpu related issue). I would appreciate if someone knowledgable could help me fix the bios file or at least tell me where to look. I already have a CH341A Programmer and familiar with how it works.
                  Original unmodified bios file: https://*******.com/u/TWW*******
                  I do not remember exactly what I changed or which change caused the issue. I played with the following settings in the bios before it went bad:
                  Intel SGX
                  Intel PTT key
                  Secure boot
                  I already tried to reset CMOS. I used this https://forums.lenovo.com/t5/Gaming-...5026109?page=1 guide, see step 5. No change.
                  I also flashed the bios with latest bios version from Lenovo website. I trimmed the downloaded bin file by comparing the start and end of the hex offsets with the original bin file. Still no change.
                  • peste
                    • Dec 2016
                    • 13439
                    • ROMANIA
                    #29
                    Re: Corrupted bios Lenovo Y540-15IRH
                    Intel SGX
                    Intel PTT key
                    Secure boot
                    try post #10..
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #30
                      My laptop stopped working...
                      Read the rules before posting:
                      Originally posted by piernov
                      You MUST:
                      • Post under a related thread if it exists
                      • Provide the full machine model number and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                      • Name your thread with model numbers and request
                      • Provide a BIOS/EC dump if possible
                      • Attach files directly to your post instead of linking to external websites
                      • coxep89151
                        • Jun 2023
                        • 3
                        try post #10..
                        It did not work. Laptop power button keeps blinking, no screen and fans working normally. Keyboard backlight also works.
                        Btw I did have to trim the bin file from post #10 because the file was too large. I trimmed the last bit of the bin file by comparing it to the old dump in HxD. Don't know if this is the right way to do this.
                        • peste
                          • Dec 2016
                          • 13439
                          • ROMANIA
                          #32
                          try this ..the last update from the site..you are right the bios from post #10 is longer...
                          DMI DMI 632000 - 633FFF
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #33
                            The attached dump in post #10 is now fixed.
                            • Thunder1986
                              • Feb 2015
                              • 25
                              • Hungary
                              #34
                              help me please!
                              Not POST since bios setting. It works with the bios shared in comment 10, but the SN and Windows key are lost. Can someone fix this bios for me?
                              Br
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #35
                                Originally posted by Thunder1986
                                help me please!
                                Br
                                bios extracted from the Lenovo site update
                                DMI 632000 - 633FFF
                                Replace the DMI block (from your bios backup to the bios attached in post #10) using above offsets .
                                • Thunder1986
                                  • Feb 2015
                                  • 25
                                  • Hungary
                                  #36
                                  Thank You!
                                  • Pryrex
                                    • Sep 2023
                                    • 5
                                    • England
                                    #37
                                    Need help unbricking Lenovo Legion Y540-15IRH
                                    Hello everyone! I'm in big trouble!
                                    Three days ago I had to force shut down the laptop by pressing the power button and after that the laptop would not start. Keyboards lights and backlight on, fans on for a while but laptop won't boot at all.
                                    I have therefore tried to use CH314a programmer in order to write the bios onto the bios chip. First time I tried using a bhcn26ww already trimmed file I found on the internet but no response. 2nd try I have tried to trim the latest file myself, bhcn45ww and after I have successfully written the file on the chip, the laptop won't even turn on the keyboard lights or backlight anymore! Next, I have tried to reuse the bhcn26ww file from earlier to see if anything changes and I have returned to the main problem: laptop would not boot but at least the keyboards lights and fans are working again. After that, I have tried writing the bhcn38ww and bhcn44ww bin files that i have found on this forum onto the chip but it seems that nothing works.
                                    Would you be able to give me the right bin trimmed file please or guide me through what I would have to do further? I'm in a bad spot and I really need this laptop to not die on me.
                                    Bios chip: GD25B127DSIG
                                    Also this is the bios file that i read before i have made any modifications on to the chip:
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12278
                                      #38
                                      Re: Need help unbricking Lenovo Legion Y540-15IRH
                                      Post the laptop's serial number, your error may be due to the hardware.
                                      • Pryrex
                                        • Sep 2023
                                        • 5
                                        • England
                                        #39
                                        Sure thing!
                                        S/N : PF146AJ4
                                        Thank you lots!
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12278
                                          #40
                                          Sure thing!
                                          S/N : PF146AJ4
                                          Thank you lots!
                                          Legion Y540-15IRH Laptop (Lenovo) - Type 81SX FROM LENOVO HOME PAGE
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • 1g0r
                                            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                            by 1g0r
                                            First, the data in brief:
                                            Manufacturer: Lenovo
                                            Model: ThinkPad L15 G3 21C3-0016GE
                                            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                            IC Bios 1: MX77L25650F
                                            IC Bios 2​: MX25L25673G
                                            EC Chip: NPCX997KAABX
                                            So far I've been a silent reader, but now I need your help
                                            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                            01-18-2025, 02:39 AM
