elitebook 850 G7 password
    Originally posted by caprigtx View Post
    Hello i have the same problem , bios pass . HP elitebook 850 G7
    can you Clear the files for me .
    https://www.badcaps.net/forum/troubl...sting?t=103570
    You MUST:
    Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
    • caprigtx
      caprigtx commented
      Editing a comment
      i have tryed to unlock these file,s , with hp unlocker and Rc unlocker , but no luck , pass is stil there.
    #42
    try
      I have this laptop , motherboard CAMELLIA-6050A3140901-MB-A01(A1) , the motherboard has one flash ic on the side with the cpu and two more on the other side, i have read the one on the first side and tryed rcunlocker on it but after flash i still have the password on. Wich one of those 3 flash memoryes should i read?
      get the main bios which is 32mb size
        Post the serial number.
        Become a Badcaps supporter
        Thanks to all supporters.
          Serial Number 5CG1077RHM .
            Ok , so the saved file from the first ic (MX25l25673G24) has 32.768Kb and i have used rc unlocker on it and everytime i flash it back the unlocked file i still have the password. The other two IC's are 25Q128JVPQ wich i gues it has 4Mb and 25Q80DVIG of 8Mb. I have uploaded the backup file from the 32Mb IC.
              Use this file with Rc unlocker. It's 16 MB.
                I have used RC unlocker on this 16Mb file but i still got the password on . I will upload here both the backup and the unlocked file maybe someone can help me.
                  UNLOCKED
                    It worked thank you, what tool to use in the future or you did it manually?
                      hxd
                        Can you show me how to work with these folders you put?
                          you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                            Hey guys, I'm going crazy here with my Elitebook 850 G7. I've already dumped the 16MB Bios (stored on MX25L12872F), removed the password section by rcunlocker, verified by a hex editor but after flashing back to the IC there was still a password required. I attached both, the locked and the unlocked file and also the dump of the 32MB 25Q256JVEN. Maybe there is also something to do. Could you please give me a hint or check the files? Thanks in advance.
                              Hey guys, I'm going crazy here with my Elitebook 850 G7 (SN 5CG12213X2). I've already dumped the 16MB Bios (stored on MX25L12872F), removed the password section by rcunlocker, verified by a hex editor but after flashing back to the IC there was still a password required. I attached both, the locked and the unlocked file and also the dump of the 32MB 25Q256JVEN. Maybe there is also something to do. Could you please give me a hint or check the files? Thanks in advance.
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                              #57
                              There are cases when both BIOS chips must be patched...
                              Write this main BIOS
                                Thanks a lot, I'll try that in the evening. Best!
                                  hp elitebook 850 g7
                                  prodid 8TP60AV
                                  sn# 5CG11827RS
                                  warranty 3y3y0y
                                  • peste
                                    peste commented
                                    Editing a comment
                                    merged post..
                                  #60
                                  Originally posted by djimy View Post
                                  hp elitebook 850 g7
                                  prodid 8TP60AV
                                  sn# 5CG11827RS
                                  warranty 3y3y0y
                                  Serial Number: 5CG11827RS
                                  Product Number: 8TP60AV
                                  CT Number: PJSAR00WBF42IQ
                                  Description: HP EliteBook 850 G7 Notebook PC
                                  build_id: 20WWCMCT601#SABD#DABD
                                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXguhKhkjhk8mE.Df
                                  MAC Address: 14-CB-19-C5-05-9C
