elitebook 850 G7 password
    • 22190
    Originally posted by caprigtx
    Hello i have the same problem , bios pass . HP elitebook 850 G7
    can you Clear the files for me .​
    https://www.badcaps.net/forum/troubl...sting?t=103570
    You MUST:
    Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.​
    • caprigtx
      caprigtx commented
      Editing a comment
      i have tryed to unlock these file,s , with hp unlocker and Rc unlocker , but no luck , pass is stil there.
  • m.sabry2110
    • Oct 2017
    • 136
    • egypt
    #42
    try
    • thesame
      • Mar 2018
      • 141
      • Romania
      #43
      I have this laptop , motherboard CAMELLIA-6050A3140901-MB-A01(A1) , the motherboard has one flash ic on the side with the cpu and two more on the other side, i have read the one on the first side and tryed rcunlocker on it but after flash i still have the password on. Wich one of those 3 flash memoryes should i read?
    • alfredposadas09
      • Aug 2020
      • 342
      • Philippines
      #44
      get the main bios which is 32mb size
      • hoaca388
        Badcaps
        • Jan 2022
        • 12425
        #45
        Post the serial number.
        ​https://www.badcaps.net/donate
        • thesame
          • Mar 2018
          • 141
          • Romania
          #46
          Serial Number 5CG1077RHM .
          • thesame
            • Mar 2018
            • 141
            • Romania
            #47
            Ok , so the saved file from the first ic (MX25l25673G24) has 32.768Kb and i have used rc unlocker on it and everytime i flash it back the unlocked file i still have the password. The other two IC's are 25Q128JVPQ wich i gues it has 4Mb and 25Q80DVIG of 8Mb. I have uploaded the backup file from the 32Mb IC.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12425
              #48
              Use this file with Rc unlocker. It's 16 MB.
              • thesame
                • Mar 2018
                • 141
                • Romania
                #49
                I have used RC unlocker on this 16Mb file but i still got the password on . I will upload here both the backup and the unlocked file maybe someone can help me.
                • alfredposadas09
                  • Aug 2020
                  • 342
                  • Philippines
                  #50
                  UNLOCKED
                  • thesame
                    • Mar 2018
                    • 141
                    • Romania
                    #51
                    It worked thank you, what tool to use in the future or you did it manually?
                    • alfredposadas09
                      • Aug 2020
                      • 342
                      • Philippines
                      #52
                      hxd
                      • Redooox
                        • Oct 2024
                        • Maroc
                        #53
                        Can you show me how to work with these folders you put?
                        • peste
                          • Dec 2016
                          • 13844
                          • ROMANIA
                          #54
                          you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                          • Sebastian Thomas
                            • Oct 2024
                            • 6
                            Hey guys, I'm going crazy here with my Elitebook 850 G7. I've already dumped the 16MB Bios (stored on MX25L12872F), removed the password section by rcunlocker, verified by a hex editor but after flashing back to the IC there was still a password required. I attached both, the locked and the unlocked file and also the dump of the 32MB 25Q256JVEN. Maybe there is also something to do. Could you please give me a hint or check the files? Thanks in advance.
                            • Sebastian Thomas
                              • Oct 2024
                              • 6
                              Hey guys, I'm going crazy here with my Elitebook 850 G7 (SN 5CG12213X2). I've already dumped the 16MB Bios (stored on MX25L12872F), removed the password section by rcunlocker, verified by a hex editor but after flashing back to the IC there was still a password required. I attached both, the locked and the unlocked file and also the dump of the 32MB 25Q256JVEN. Maybe there is also something to do. Could you please give me a hint or check the files? Thanks in advance.​
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                            • Stefan Steff
                              • Mar 2024
                              • 389
                              • Romania
                              #57
                              There are cases when both BIOS chips must be patched...
                              Write this main BIOS
                              • Sebastian Thomas
                                • Oct 2024
                                • 6
                                Thanks a lot, I'll try that in the evening. Best!
                                • djimy
                                  • Sep 2019
                                  • 8
                                  • dzdz
                                  #59
                                  hp elitebook 850 g7
                                  prodid 8TP60AV
                                  sn# 5CG11827RS
                                  warranty 3y3y0y
                                  • peste
                                    peste commented
                                    Editing a comment
                                    merged post..
                                • bbanana
                                  Father Land
                                  • Oct 2021
                                  • 164
                                  • Vietnam
                                  #60
                                  Originally posted by djimy
                                  hp elitebook 850 g7
                                  prodid 8TP60AV
                                  sn# 5CG11827RS
                                  warranty 3y3y0y
                                  Serial Number: 5CG11827RS
                                  Product Number: 8TP60AV
                                  CT Number: PJSAR00WBF42IQ
                                  Description: HP EliteBook 850 G7 Notebook PC
                                  build_id: 20WWCMCT601#SABD#DABD
                                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXguhKhkjhk8mE.Df
                                  MAC Address: 14-CB-19-C5-05-9C​
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • to5it0
                                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                    by to5it0
                                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                    I have opened the laptop and identified the main BIOS chip...
                                    10-24-2025, 01:35 AM
                                  • marc_ytos
                                    request unlock HP EliteBook 640 G11 password bios
                                    by marc_ytos
                                    Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                    01-11-2025, 06:20 PM
                                  • Nopslide
                                    by Nopslide
                                    04-01-2024, 04:27 PM
                                  • Wutru
                                    HP Elitebook 820 G4 BIOS repair assistance required
                                    by Wutru
                                    Hi guys,
                                    If someone would be able to provide some expertise, I'd be very grateful.
                                    BIOS Corruption - Cause
                                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                    09-06-2025, 10:32 AM
