hp dmi data tool
  • volinakis
    • Jan 2021
    • 2603
    • N/A
    Re: hp dmi data tool
    Originally posted by clrscr
    yes ! i want find frome file bin.
    so you don't get it even from pictures ...
    • clrscr
      • Dec 2020
      • 178
      • sing
      I understand what you're saying, but what software are you using to open that bin file? Can you share it?
      all donations are welcome,
      >>>>> click on this link to donate via PayPal. <<<<<
      • volinakis
        • Jan 2021
        • 2603
        • N/A
        is iHex, the same as HxD but is for OS X. Just search for text in HxD "Ver." and you'll find it.
        • Muhammad Faizan
          • Mar 2022
          • 32
          • 000
          I need this hp serial number
          5CD336CDJ4 DMI DATA
          • peste
            • Dec 2016
            • 12226
            • ROMANIA
            5CD336CDJ4 DMI DATA
            Where do you need this S/N???
            read..https://www.badcaps.net/forum/troubl...before-posting
            • Muhammad Faizan
              • Mar 2022
              • 32
              • 000
              #26
              i need ct number
              • Troystain
                • Nov 2024
                • 10
                • Philippines
                #27
                I want to show the same thing
                I am looking for the same software that can decode MPM information but I guess this is a paid software?
                • rex98
                  • Feb 2023
                  • 1234
                  • Mandaue CEBU, Philippines
                  #28
                  its not paid its free
                  • Fighter
                    Veteran Member
                    • Jul 2017
                    • 36
                    • Pakistan
                    #29
                    Where is the HP DMI checking tool bro???
                    • tktrom
                      • Jul 2022
                      • 69
                      • Bolivia
                      #30
                      open bios dump with UEFITool and search for text "HP_MUD" (no quotes). You'll find it in VSS2 store, view as hex and you'll have there serial, sku, board ID and name of machine.
                      in FactoryConfig you'll find feature byte, in BuiltID you'll have ... let me think ... right! build ID and in HP_OA3 you'll have win key.
                      other way: if your laptop is working and don't have bios dump use Bios Config Utility and in cmd type: biosconfigutility -get:1.txt. you'll find 1.txt. in BCU folder (usually in Program Files(x86)) and you'll see all data there.
                      3rd way: there is a label on bottom cover ...
                      Thank you very much, I was able to do it thanks to your tutorial
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • samstown
                        Apple 076-00236 Genuine Apple Data Migration Tool for MacBook Pro 2016 2017
                        by samstown
                        This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
                        Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
                        Claude...
                        05-09-2024, 02:02 AM
                      • mscottdoran@gmail.com
                        Can anyone identify the classification of this data signal?
                        by mscottdoran@gmail.com
                        Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                        The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                        The boards are powered by a ground referenced...
                        02-08-2025, 11:31 AM
                      • Joe24
                        Maytag Whirlpool Kenmore clothes dryer data bus
                        by Joe24
                        Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                        Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                        I've been over the board looking for...
                        01-13-2025, 06:50 PM
                      • DoOm86
                        Swap nand flash smartphone for data recovery
                        by DoOm86
                        Hello everyone.
                        I would like to know more about the following topic:
                        Nand flash on smartphone for data recovery.
                        I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                        But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                        How does it works? How do I know if data are encrypted or where is the key?
                        I know there are also very expensive external socket where you can put the nand flash in...
                        08-20-2023, 07:10 AM
