Can anyone identify the classification of this data signal?
  • mscottdoran@gmail.com
    • Feb 2025
    • 13
    Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
    The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
    The boards are powered by a ground referenced 24vdc, and data is transmitted to the board via a ground referenced single data wire (not a twisted pair). CE Electronics calls this their “Micro Comm data network”. It generally works extremely well and has relatively short transmission lengths (a few hundred feet, depending on the height of the building).
    I have an email in to their tech support, but haven't heard back from them yet.
    I was wondering if anyone on this forum could identify the data signal from the oscilloscope waveform. It appears to me to be a lower frequency square carrier wave carrying packets of higher frequency “data” square waves. Is this just pulse code modulation using a square carrier wave instead of a sine carrier wave, or something different? It's about 2.4 volts peak to peak above ground.
    Thanks, Matt
    • 31305
    does the 24v come from a mains transformer?
    maybe it's some type of powerline remote control.
    not wifi-plugs or the scope wouldnt catch it
      • Jul 2011
      • 6070
      I could be wrong but to me it looks like noise of some kind because it is not consistent in nature
      I once worked on a machine that had some kind a switching power supply that buss type of control chip in it and just before it went out it causing havoc on the machine not powering things on correctly or turning things off and unfortunately you could not just buy the ic chip you had to buy the hole switching power supply for it but there was nothing wrong the switching power supply it self with out that special ic chip in it worked just fine
      I wondering if you might have the same issue with a switching power supply that has some kind of buss system on it
        • Feb 2025
        • 13
        I have attached the relevant areas of the schematics. The building 3 phase 480vac powers the elevator controller, it is then transformed down to single phase 120vac, which is again stepped down and full wave rectified to unfiltered 24vdc. The unfiltered 24vdc gets plugged into the car and hall fixture driver board, and is filtered at the driver board to a steady 24vdc with about 200-300 mVac ripple. This filtered 24vdc goes to each floor's serial hall fixture as power. Each floor's serial hall fixture has a unique address that can be set by an onboard dip switch. Not 100% sure but the data signal must activate the board at whatever address the driver board sends out in order to turn on a floor output and sink some of the 24vdc power to ground through the fixture's LED thus illuminating the hall arrival lantern.
        I can definitely see noise getting on the data signal as it is not a shielded twisted pair, but rather just a single 18awg copper wire run down the elevator shaft bundled with other high voltage ac wires (about 120vac max). The manufacturer tech support doesn't see this as a problem though, and in my experience it usually isn't.
          • Jul 2011
          • 6070
          Are there any filtering capacitor or capacitors on the 24 volts circuit because the circuit diagram does not show it that is why I am asking
          The only thing that comes to mind is that there might be issue with the Dlink circuit that it is transmitting a signal when it should not be
          On rare occasions I seen issues with buss link modules do weird things so do not rule it out I sure that it is rare but I weird things happen before
            • 31305
            maybe one of the nodes on the network is fucked and glitching the line.
              • Jul 2011
              • 6070
              I was thinking the same thing
                • Feb 2025
                • 13
                Yes there is a big filtering cap on the driver board. I don't have a board level schematic, but I have attached a picture of the board from the MCE elevator controller website:
                  • Jul 2011
                  • 6070
                  I would check the big filtering capacitor with a ESR meter to see if the resistance has gone high compared to a new one the same value
                    • Feb 2025
                    • 13
                    yeah, I think this is most likely the case too. It’s only four cars and eleven stops so 44 potential culprits, lol!
                      • Feb 2025
                      • 13
                      That’s a good idea, I’ll check that out next week, Thanks
                      • vlady carp
                        Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
                        by vlady carp
                        Hello, colleagues!
                        I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
                        What I've done so far:
                        • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
                        • The original processor is beyond repair, and I wasn't able to extract the dump.
                        • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
                        01-16-2025, 02:08 AM
                      • devsigner
                        identify capacitor for MacBook Pro with rare logic board 820-02037-06
                        by devsigner
                        Hi
                        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
                        resistance tests show a rising resistance value, indicating a capacitor.
                        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
                        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
                        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
                        11-28-2025, 01:39 PM
                      • thesame
                        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                        by thesame
                        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                        02-27-2024, 04:31 AM
                      • silver60618
                        Lenovo Legion 7 - Help Identify IC
                        by silver60618
                        Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                        I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                        Any help would be appreciated...
                        07-02-2025, 12:16 PM
                      • chth96
                        How can I identify varistor which have been blew up?
                        by chth96
                        I mistakely pluged 100v japanese retro game console to 220v outlet.
                        So It seems that glass fuse and varistor have been blew up.
                        I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                        Is there any way to identify varistor type in my sega saturn PSU?
                        Any reply would be appreciated.
                        EDIT:
                        It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                        11-26-2023, 08:52 AM
