Swap nand flash smartphone for data recovery
  • DoOm86
    • Nov 2022
    • 42
    • italia
    Hello everyone.
    I would like to know more about the following topic:
    Nand flash on smartphone for data recovery.
    I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
    But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
    How does it works? How do I know if data are encrypted or where is the key?
    I know there are also very expensive external socket where you can put the nand flash in order to recover data, but I can't catch up with it as well.
    Thanks for anyone will share info on this topic.
  • Spider1211
    iPhone XS Data recovery from NAND flash
    by Spider1211
    Hey guys, I have an iPhone XS which came in as dead. The phone was not worked on before (I was the first to open it). After diagnosis (Splitting board, etc) it's confirmed to have a shorted PP2v63_NAND line.
    Removed the NAND flash and short is gone on the board. Measuring directly on the NAND, there is about 2 to 15ohm to ground.
    Is there anyway of backing up data externally in such cases (Client has some very important files and no back ups)?
    08-22-2022, 09:22 AM
  • Deeloc
    How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
    by Deeloc
    I have a 1tb WALRAM SSD (Photo)
    Controller SM2259XT2G (photo)
    Samsung memory (photo):
    Part Number K9DVGB8J1B DCK0
    Name V-NAND V6
    Type TLC
    The SSD itself is detected as 1gb, but is not initialized.
    There is a Sata to USB adapter
    A lot of SMI MPTool, did not flash it. compare flash fail (17)
    K9DVGB8J1B is not listed anywhere
    What to flash?​...
    06-05-2024, 08:32 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • Karmet
    MacBook Pro 16" 2019 NAND Swap
    by Karmet
    I couldn't find a post related to this, so if it exists please point me in that direction.
    I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
    I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
    07-24-2023, 10:48 AM
  • Rezid
    Lenovo E14 Gen 2 TPM chip swap for data recovery
    by Rezid
    I have a Lenovo Thinkpad E14 Gen 2 that's not powering on. GE4B0/GE5B0 NM-D011 is the board number. Not interested in fixing the board, but the data on the drive is important. It's not backed up anywhere and unfortunately has bitlocker enabled on it with the recovery key also not being saved anywhere. Does anyone know if it would it be possible to swap the bios chip U2 and the TPM chip UM1 to another working board to get the data back, or would I have to try and fix this board to recover it?
    02-22-2024, 12:49 PM
