dell 3420 cyborg-L14 mb 203068-1 help me with this bios
  • kreine
    • Mar 2019
    • 9
    • rizal
    #81
    [QUOTE=SMDFlea;n3520390]
    Originally posted by kreine
    That is the bios chip. It has no legs on it, the chip type is WSON8. You will not be able to read it if you only have a SOP8 clip,which is designed for chips with legs that stick out. If you can`t desolder the chip you could buy and use a WSON8 pogo adapter.
    here is my new read dump file. hope you can unlock it. tia
    latitude 3420, cyborg-L14 MB TGL 203068-1
    ST: 77ZHV93
    • kreine
      • Mar 2019
      • 9
      • rizal
      #82
      i already did it.. thanks fo the guide here...
      • rex98
        • Feb 2023
        • 1280
        • Mandaue CEBU, Philippines
        #83
        [QUOTE=kreine;n3521815]
        ST: 77ZHV93
        use this tool. the instructions is in the description. https://www.badcaps.net/forum/troubl...l-8fc8-patcher
        • kawaiistore
          • May 2021
          • El Salvador
          #84
          This bios does not let me turn on the machine. Apart from that, I know that it is locked but when I press the button it only shows an orange charging LED and when I release it the LED turns off.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11806
            #85
            You must post :
            1. Model
            2. Service tag , please write down.
            3. Backup bios ( even if it is broken )
            • lazybigyan
              • Mar 2017
              • 79
              • Nepal
              #86
              Originally posted by surazbashyal
              Re: dell 3420 cyborg-L14 mb 203068-1 help me with this bios
              I had this backup from cyborg-L14 mb 203068-1. It is in dead condition. When I rewrite this bios with tested ok one, it always gets stuck with manufacturing mode and It returns back to same dead condition when i insert service tag and restart the laptop. Anyone can solve this problem???
              How did you get out of this problem? I have a laptop with same issue help me out.
              Thanks in advance
              • kawaiistore
                • May 2021
                • El Salvador
                #87
                Originally posted by hoaca388
                You must post :
                1. Model
                1 dell 3420
                2 4wt4t93
                • markoclick1993
                  • Apr 2020
                  • 3
                  • Románia
                  #88
                  This file from other laptop
                  Thank you! Working for me!
                  • lazybigyan
                    • Mar 2017
                    • 79
                    • Nepal
                    #89
                    Dell Latitude 3420 cyborg-l14 mb tgl
                    203068-1
                    ST:- 2DWT1B3
                    Lapto was dead. after programme new bios display has come. after save the the laptop model no and service tag laptop goes same condition as dead as no power. plz help with me
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11806
                      #90
                      1 dell 3420
                      2 4wt4t93
                      Latitude 3420
                      Service Tag: 4WT4T93​
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11806
                        #91
                        203068-1
                        ST:- 2DWT1B3
                        Latitude 3420
                        Service Tag: 2DWT1B3​
                        • jucaroni
                          • Jan 2021
                          • Colombia
                          #92
                          Could you help me fix the following bin, no video, no fan, caps LED always on. I attached a backup and computer data. Thank you very much for your help
                          203068-1
                          ST: JJT3Q93​
                          • lazybigyan
                            • Mar 2017
                            • 79
                            • Nepal
                            #93
                            Latitude 3420
                            Bios work before select model and write the service tag. After out of the manufacture mode Laptop does not turn on. What should I do? Please help. Thanks in advance.
                            • Zibbo
                              • Mar 2017
                              • 203
                              • Zimbabwe
                              #94
                              Is it not giving TPM chip error?
                              • luisvalenzuelajr
                                • Jun 2015
                                • 54
                                • Brasil
                                #95
                                good afternoon! Please remove your password and return it to the original.
                                ST: jvmrpt3
                                Dell latitude 3420
                                MB 203068-1​
                                • peste
                                  • Dec 2016
                                  • 12872
                                  • ROMANIA
                                  #96
                                  ST: jvmrpt3
                                  Dell latitude 3420
                                  MB 203068-1​
                                  try..
                                  • luisvalenzuelajr
                                    • Jun 2015
                                    • 54
                                    • Brasil
                                    #97
                                    Originally posted by peste
                                    try..
                                    Thank you for your attention, the password has been removed but the LOGO is still changed.
                                    • luisvalenzuelajr
                                      • Jun 2015
                                      • 54
                                      • Brasil
                                      #98
                                      any help please
                                      • luisvalenzuelajr
                                        • Jun 2015
                                        • 54
                                        • Brasil
                                        #99
                                        I need to fix this BIOS, the notebook won't turn on. My backup is attached. Dell Latitude 3420, MB 213276-1, ST DB8XWT3.
                                        • luisvalenzuelajr
                                          • Jun 2015
                                          • 54
                                          • Brasil
                                          #100
                                          any help please
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • sammus540
                                            Dell Vostro 3420 BIOS Password Removal
                                            by sammus540
                                            I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                                            And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                                            03-28-2024, 06:33 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
