dell 3420 cyborg-L14 mb 203068-1 help me with this bios
  • khawaja0007
    • Nov 2019
    • 24
    • uae
    #61
    HI PLEASE clear bios password latitude 3420
    203068-1
  • shiyab
    • Sep 2023
    • 1452
    • india
    #62
    203068-1
    try unlock
    • maykol27
      • Oct 2022
      • 7
      • bolivia
      #63
      please build this bios no boot
      ST: FYZHWL3
      EX: 34767206967
      Badcaps Electronics Repair Forum & Schematic Search
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        #64
        ST: FYZHWL3
        EX: 34767206967
        Service Tag: FYZHWL3
        Write the first one Latitude 3520_CyborgLTgl_CY_64 v1.8.0
        • javieromex
          • Apr 2016
          • 76
          • México
          #65
          Can you help fix this Bios? (I tried the one on post #49 but did not work). Mine turns on but no video.
          Board: 213267-1
          ST: 3810KS3
          EX: 7015782963
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            #66
            Board: 213267-1
            ST: 3810KS3
            EX: 7015782963
            Try
            • kreine
              • Mar 2019
              • 9
              • rizal
              #67
              pls help me unlock latitude 3420, cyborg-L14 MB TGL 203068-1
              ST: 77ZHV93
              THANKS!
              • peste
                • Dec 2016
                • 12786
                • ROMANIA
                #68
                ST: 77ZHV93
                THANKS!
                post the original content of the bios chip
                • kreine
                  • Mar 2019
                  • 9
                  • rizal
                  #69
                  ST: 77ZHV93
                  THANKS!
                  Sorry here it is
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11732
                    #70
                    Sorry here it is
                    File's corrupted.
                    • kreine
                      • Mar 2019
                      • 9
                      • rizal
                      #71
                      Originally posted by hoaca388
                      File's corrupted.
                      is there any bios bin compatible to may latitude 3420? pls help...
                        • 20873
                        What model is your programmer and software version. What is the chip part number that you backed up, the file doesn`t look right, it`s like the 1MB USB-C firmware saved as 32MB ? . If you have used the programmers Auto-detect setting choose the chip manually instead, and look for the chip in the support list
                        • kreine
                          • Mar 2019
                          • 9
                          • rizal
                          #73
                          im using ch431a to read , software asprogrammer v2.1.0.13, the chip is winbond 25Q80DV... i read it manually with 256mb setting
                            • 20873
                            Ah, that`s where you`ve gone wrong. The 25Q80DV chip is 8 Mega bits - 8Mb = 1MB (Mega Byte) . The chip is 1MB and you chose a 256MB chip manually, so the programmer read it and padded it out. I hope you didn`t erase that chip. Leave it alone and look for the right one..
                            • kreine
                              • Mar 2019
                              • 9
                              • rizal
                              #75
                              [QUOTE=SMDFlea;n3519690]
                              i did not erase it... what should i do?
                                SMDFlea commented
                                Editing a comment
                                By choosing the chip manually you told the programmer that the 1MB bios chip is 32MB, when it isn`t. Find the 32MB chip ,choose Auto-detect.If it doesn`t recognise the chip by the part number that is on it then manually choose a different 32MB (256Mbit) chip in the list.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11732
                              #76
                              [QUOTE=kreine;n3519706]
                              Find the chip with the number 256.
                              • kreine
                                • Mar 2019
                                • 9
                                • rizal
                                #77
                                [QUOTE=hoaca388;n3519707]
                                so i need to replace it with 256? or i can used 64 or 128?
                                  • 20873
                                  [QUOTE=kreine;n3519720]
                                  No, you`re getting mixed up. Find the chip in the red circle in the picture, tell us what part number is on it , and post some pictures of it.
                                  • kreine
                                    • Mar 2019
                                    • 9
                                    • rizal
                                    #79
                                    [QUOTE=SMDFlea;n3519758]
                                    my bad im so sorry... im looking at the wrong winbond ic.. sorry
                                    here it is... 25R256JVEN
                                      • 20873
                                      [QUOTE=kreine;n3520248]
                                      That is the bios chip. It has no legs on it, the chip type is WSON8. You will not be able to read it if you only have a SOP8 clip,which is designed for chips with legs that stick out. If you can`t desolder the chip you could buy and use a WSON8 pogo adapter.
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • sammus540
                                        Dell Vostro 3420 BIOS Password Removal
                                        by sammus540
                                        I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                                        And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                                        03-28-2024, 06:33 PM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                        11-02-2024, 04:19 AM
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
