please fix bios not touch screen, slow display. surface laptop 3 intel m1098028-008
MS Surface no touchscreen after cleaning ME Firmware **FIX**
Every donation made will go towards server fees and maintenance costs.Comment
I'm starting to write here because there seems to be a touchscreen issue, and I'm not sure whether it's hardware- or firmware-related.
I have a Surface Pro 7, S/N 045507704153, model 1866. Everything works except the touchscreen. I'm getting the classic error code 10: STATUS_DEVICE_DATA_ERROR. The UEFI BIOS appears to be unlocked (no password, and I can enter and read information normally).
I tried cleaning the ME region following the information in this post (thank you so much!) and other guides from the BadCaps forum, but I'd appreciate your help and opinion to understand if I'm facing a hardware issue:- Desoldered and successfully read the full BIOS (about 16MB file, attached)
- Cleaned the ME region (seems to have worked correctly)
- Reflashed the entire chip after blanking
- The system booted, and I noticed some ! warnings on UEFI modules inside Windows Device Manager. Windows requested a reboot
- After the reboot, a “system update” occurred—it looks like Windows reflashed the ME region again, updating the BIOS
Final boot into Windows: unfortunately, still no touchscreen.
I really want to avoid desoldering the BIOS chip too many times, as I'm concerned about wearing it out, and the PCB isn't happy about it either. That's why I'm asking for your help—should I focus on a hardware issue at this point?
The flat connector to the touchscreen side of the display looks fine. I don't know if the display was working previously, since I received the Surface already opened. However, the chip on the touchscreen PCB is marked "1866", so I believe it's the correct one for this Surface Pro 7 model.
Can anyone help or maybe take a look at my BIOS dump to see if there's any chance the touchscreen can be brought back to life?
I also checked the touchscreen PCB and the voltages seem to be okay—but I'm not 100% sure how to verify that properly.
Thank you so much in advance!
NB: before starting to dig in ME cleaning procedure, I followed all suggested update steps like starting from W11 recovery, manual update drivers, all but no touch back to life...
Attached Filesif you find these attachements useful please consider making a small donation to the site
try this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello SMDFlea
thank you for your firmware but touch still doesn't work. I still have same problem, also I bought a touch pcb (used, but should be compatible) and same result: Status_device_data_error and no touchComment
do I expect that after inf install, a reboot should start a "system update"? because i tryed to install via .inf and rebooted, but nothing. I forgot to mention that entering in UEFI bios also touch does not work.
update: i tried to remove by had from device manager all related to touch, hope to trigger a firmware update but nothing, I still have the same problem and no touch working
Hello Everyone
just to share my experience so far, on what I've done on my Surface 7 Pro model 1866 (i5 8GB ram 128GB ssd just to be clear):
- tried about 10 - 12 different firmware present here and in Surface 7 Pro bios thread, no luck
- tried to mix my dump with different extracted cleaned bioses, without luck
results was from having no SSD recognized (boot only with usb pen), to some corrupted ME (0.0.0.0) version, to unable to flasy UEFI and / or ME on windows reboot
The "best" result i have is a mixed firmware where i can flash UEFI and ME firmware succesfully after windows reboot, but stuck on Touch firmware, not able to flash (it tryes but istantly reboot on flash attempt).
What I was trying to do is to force a re-flash of touch firmware, hoping mine is somehow broken and a reflash (downgrade? maybe) can restore the right touch functionality.
One thing is "strange". I noticed a difference between the electronics and the information on firmware dump (every dump i found to be honest):
here the touch RESET GPIO is declared as GPIO port D pin 14, where
on the schematics the RESET port D 13, not D 14. Could be this the difference?
However I tried immediatly to build a firmware with only this modification and no luck
Keep trying but I'm running out of ideas.
For sure the hardware is good, i tryed another pcb digitizer and no luck, it should be something on the motherboard.
Regards All
Hi everyone! please help me! I followed the steps but still can't touch,surface laptop model1769,thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
look into bios settings - Advanced - System Options, if your laptop is touchscreen capable you'll find it there, check the box.SMDFlea Does this procedure work with HP 840 G6, I have an 840 g6 motherboard that is not touchscreen enabled by default and would love to enable it----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
not available that way but I know it is something to do with the bios file because I have seen files that can enable a non touch board to a touchscreen especially on HP 840 G3Comment
are you sure you have touch panel? Bios is detecting the hardware on POST and the option enable/disable will be in System options. If you don't have touch panel of course the option will not pop up in system options. Dxe drivers for touch panel are in every bios, so if you have a touch panel POST will detect it as hardware and use the dxe driver for it to work.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I have a Surface Pro 6 that previously had a locked BIOS password. A member of the blog helped me to successfully unlocked it, but now the touchscreen no longer works. It's completely missing from Device Manager, and it doesn't respond even in UEFI/BIOS.
Can someone help me to fix it? I attached both the original and the unlocked BIOS dumps if needed.
Thanks in advance!
S/N: 054415285253Attached Filesif you find these attachements useful please consider making a small donation to the site
TRyAttached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? - Loading...
