Need BIOS for ASUS C523NA
  • computeka
    • Apr 2021
    • 31
    • colombia
    ASUS Bios Need
    MB: C223NA rev 2.2
    ASUS C523NA-DH02
  • hoaca388
    Badcaps
    • Jan 2022
    • 11352
    • Viet Nam
    Re: Need BIOS for ASUS C523NA
    Post your original bios .
    • computeka
      • Apr 2021
      • 31
      • colombia
      she has password to enter.
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        Re: Need BIOS for ASUS C223NA
        Please help me fix this bios, it can not boot. white screen for 2s and looping
        • hoaca388
          Badcaps
          • Jan 2022
          • 11352
          • Viet Nam
          You need install Chrome OS after reflash bios.
          • ajbernasko
            • Mar 2022
            • 229
            • ghana
            I did write the new firmware 1.8V with RT809H i have all power yet black display, battery charges gives me 5V 2.8 amps as was before when backlight comes on 2s and looping
            • hoaca388
              Badcaps
              • Jan 2022
              • 11352
              • Viet Nam
              If flash your original file , will the device show up ?
              • ajbernasko
                • Mar 2022
                • 229
                • ghana
                yes please original bios give me on and off backlight, kind of looping every 3 seconds
                • Bonzas
                  • 468
                  • Indonesia
                  If your chromebook code name babytiger, this bios should work. I've tested this bios
                  • adamgouadma
                    • Jul 2017
                    • 179
                    • setif
                    Try this and let us know the results
                    • mferna14
                      • Jun 2018
                      • 1010
                      Dear Friends., working on ASUS ChromeBook C523NA-BB01T-CB. BIN files works & Display is fine but it's Locked, can someone re-build this BIOS, I would appreciate. Original Bin file is atteched.
                      Model: ChromeBook C523NA-BB01T-CB BABYMEGA D7B-B2G-B4Y-Z9E-A9X
                      Serial #: M5NXCV04T229185
                      CN: D6RB
                      • volinakis
                        • Jan 2021
                        • 2655
                        • N/A
                        CN: D6RB
                        serial provided doesn't fit with serial from bios backup which seems to be from a CX22NA and not C523NA
                        • mferna14
                          • Jun 2018
                          • 1010
                          Dear this is only serial, I re-checked several times which is on at the back sticker of the laptop & from the ASUS Web site, comes up with the same model. Attached is the photo. Can you modify the serial # or trim it to the size if possible & just to inform you I purchased this motherboard from eBay as the original motherboard got dead & now this new one is locked. You know how they sell. This motherboard has been changed, I would not bother about the serial # or model # as long as he modified BIOS is working & Not locked to any Gmail Acc & maily it's out of ASUS warranty. Thanks dear for the help.
Name:	Screenshot 2024-08-21 at 9.10.07 PM.png
                          • LatinMcG
                            • Jun 2015
                            • 70
                            • USA/Puerto Rico
                            CN: D6RB
                            patched w RC unlocker
                            then filled !stable_device_secret area with FF
                            should allow to use new account now.
                            • mferna14
                              • Jun 2018
                              • 1010
                              Thanks Brother., I wrote these bin files to the Chip, all worked but still it is asking for "Device Enrollment". It gives ********@rosebudacademy.com ... Can you pls. look into this, maybe you might have missed something. I did a complete factory restore again but still no luck.
                              • mferna14
                                • Jun 2018
                                • 1010
                                Good Day Dear.,, the problem was with the 64GB NAND Flash Memory eMMC chip. Actually all data was stored on this chip & even after a complete factory restore, this data was never deleted except if I knew the password & then could have done the Power Wash. I replaced with a good chip & restored back to factory default, all works 100% with completely new user. Thanks buddy for all the help, really appreciate.
                                • mferna14
                                  • Jun 2018
                                  • 1010
                                  Hi Friends., Can someone re-build this BIN File as it gives error while restoring back to factory default. I think the CleanME region seems to be corrupted... Thanks in Advance
                                  ASUS Chromebook C523NA-BS01-CB
                                  Serial # M1NXCV22V070048
                                  CN: 5KCF
                                  MFD: 2021-01
                                  • kalilinux25
                                    • Mar 2018
                                    • 2069
                                    • ZAMBOANGA SIBUGAY
                                    CN: 5KCF
                                    MFD: 2021-01
                                    please try this , after flashing you need to install fresh operating system
                                    • mferna14
                                      • Jun 2018
                                      • 1010
                                      kalilinux25​, Dear all works 100% fine..... Really appreciate your help. Thanks
                                      • kalilinux25
                                        • Mar 2018
                                        • 2069
                                        • ZAMBOANGA SIBUGAY
                                        great to help
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
                                        • adnan_u
                                          ASUS ROG Strix B550-I won't POST and cannot enter bios
                                          by adnan_u
                                          Hoping someone can help me? I have the above mentioned motherboard which is currently failing to POST. PC boots up to the ROG logo and remains there with the green QLED lit constantly. Pressing F2 and/or Del keys to enter the bios have no effect. I have tried using Flashback to flash the latest ASUS firmware for this board, this results in an fTPM nv corrupted message and pressing Y or N here restarts the PC putting me back where I started.
                                          I have managed to dump the winbond (w25q256jw18) bios chip using a CH341A chip reader but haven't attempted a manual reflash...
                                          02-14-2024, 08:29 PM
