Dell Bios Need LA-K662P REV 1.0
FIRST : delete this Universal BIOS Backup ToolKit from your computer 🤬
Second : the dump you posted is 16 mega and this lap require 32 mega ..so you destroy your original dump now.
Try bios of post #29 and give feedback....no Universal BIOS Backup ToolKit
​Comment
and for the file in #29 it have Initialized ME and i dont think it work with my laptop
and this is the bios that i flash and found in a bios collection but it have Initialized ME and because of that it have tpm issue and long boot and no miceAttached FilesComment
First i already deleted Universal BIOS Backup ToolKit dont worry about it
help need clean me
laptop restarted after update bios
service tAGE IS : HJKYLF3
THANKSAttached FilesComment
Service Tag: HJKYLF3​Attached Files↵
​https://www.badcaps.net/donateComment
ST: 3PRKZK3
EX: 8088330243
bios vs: 1.31.0
There is a tpm error.
My nvdia display card is not visible.
The mousepad works fine in the bios, but it freezes on the windows screen.
I had a Hub replacement, after the replacement I need to clean the ME region, help, I will be grateful.
Model DELL G15 5510
MFGYR:2021
ST: FKP0ZH3
EX: 33903094935
Service Tag: FKP0ZH3Attached Files↵
ST: 3PRKZK3
EX: 8088330243
bios vs: 1.31.0
Also what should I do to reset the ME region.
I would be very happy if you could support me. I really need help with this. Thank you in advance for your support
​Attached FilesComment
ST: 3PRKZK3
EX: 8088330243
bios vs: 1.31.0
Service Tag: 3PRKZK3​Attached Files↵
First of all, thank you for your help; While waiting for your support, I tried another bios that I found, but it did not trigger at all. I loaded the bios that you sent, still the same, then I loaded the original bios that I had backed up, still no results, only when I press the power button, the battery light flashes, there is no other movement on the computer, what could be the reason for this? Or where did I make a mistake?
The laptop is working fine, but when the power button is pressed, it takes a long time to reach the logo screen.
original bios file and service tag attached ,please fix biosAttached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
