HP Elitebook 840 G6 bios password
  • mp3boy
    • Mar 2016
    • 48
    Re: Hp elitebook 840 g6 locked bios
    Originally posted by mp3boy
    I am using this method on my own 840 G6. I have successfully removed the password by replicating the changes made in the 32MB unlock file, but HP BCU tool won't program the Product Name and Feature Byte.
    The system is in MPM unlocked mode and I have set the CT, Serial and Build ID using HP BCU.
    WnDMIFit gives a Board Not Supported error and runs in read-only mode.
    Any advice please?
    Problem solved, badly formatted text file, BCU works fine for all fields.
    Notes in case it helps anyone:
    Much easier to backup and restore DMI with BCU if the laptop is bootable into Windows. Run the following in administrative command prompt before and after resetting password:
    Code:
    before flashing any files!!:
    BIOSConfigurationUtility64.exe /Get:data.txt
    after unlock:
    BIOSConfigurationUtility64.exe /Set:data.txt
    power off, battery pull, PoE pi3 with pogo probe worked for read/write 32MB chip without disassembly/soldering. pi4 usb-c did not work - mismatched reads.
    to make unlock file in hex editor (this will erase DMI data and put laptop in MPM mode):
    change 3F (?) to 3C (<) after the following strings:
    52 00 65 00 63 00 6F 00 76 00 65 00 72 00 79 00 53 00 74 00 61 00 74 00 75 00 73 (Recovery Status)
    49 00 44 00 45 00 4B 00 50 00 75 00 62 00 43 00 52 00 43 (IDEKPubCRC)
    6F 00 6D 00 6D 00 6F 00 6E 00 53 00 65 00 74 00 75 00 70 (CommonSetup)
    44 00 65 00 76 00 69 00 63 00 65 00 43 00 6F 00 6E 00 66 00 69 00 67 00 46 00 6C 00 61 00 67 00 73 (DeviceConfigFlags)
    and replace
    26 48 00 70 00 4D 00 70 00 6D 00 00 00 00 00 00 00 00 00 00 00 (HP MPM) with
    26 48 00 70 00 4D 00 70 00 6D 00 00 00 00 23 01 00 02 00 00 00
    start laptop, reboots numerous times, use F10 and apply factory defaults, save and exit
    F10 again, go to Security tab and reset bios security to factory defaults (this step asks for a password if the above step is not done)
    • jcc2505
      • Apr 2023
      • 19
      • Tijuana
      #102
      Re: HP Elitebook 840 G6 bios password
      Hi, can help to unlock this please, i try with RCunlocker but not remove lock
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #103
        Read the rules before posting:
        Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
        Become a Badcaps supporter
        Thanks to all supporters.
        • VIEN
          • Aug 2023
          • 5
          • vietnam
          #104
          Need help with password removal. attached both dumps.
          Is it not possible with RCunlocker to do the dual bios .
          only 1 bios will drag into the unlocker successfu
            • 20971
            Read post #103. SERIAL NUMBER !!!
            • abrahim110
              • Nov 2021
              • 9
              hp 840 G6 i7 endpoint security controller problem
              hi i try to unlock the bios on HP 840 Genration 6 i7
              i modifid the 16mb CHIIP but after is coming always the Eror hp endpoint security controller problem
              i try to install clean dump for 32MB too but still same can anybody help me
              i post the original Dump file down .
                • 20971
                Re: hp 840 G6 i7 endpoint security controller problem
                Read post #103 .
                • rex98
                  • Feb 2023
                  • 1280
                  • Mandaue CEBU, Philippines
                  #108
                  https://www.badcaps.net/forum/showpo...&postcount=346
                  if you have problem with hp endpoint security controller and password lock use this main and ec it works tested.
                  • kamkooltech
                    kamkooltech
                    • Jun 2019
                    • 110
                    • nigeria
                    #109
                    Help me to unlock this password
                      • 20971
                      Read post #105
                      • kamkooltech
                        kamkooltech
                        • Jun 2019
                        • 110
                        • nigeria
                        #111
                        Originally posted by SMDFlea
                        Read post #105
                        i will check, thanks bro
                        • roli1980
                          • Nov 2020
                          • 46
                          #112
                          hi everyone , after removing bios password im confronted with a "endpoint security controller problem"
                          can anyone help me with a good unlocked flash
                          thanks
                          6050A3022501-MB-A01 - 5CG0360FPX
                          • binoyroy
                            • Sep 2017
                            • 51
                            • bangladeah
                            #113
                            try this one.
                            • roli1980
                              • Nov 2020
                              • 46
                              #114
                              no still the same error
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11787
                                #115
                                thanks
                                Serial number ?
                                • roli1980
                                  • Nov 2020
                                  • 46
                                  #116
                                  5CG0360FPX
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11787
                                    #117
                                    thanks
                                    CCCC
                                    • mesta83
                                      • Nov 2015
                                      • 75
                                      • merseyside
                                      #118
                                      Hi everyone, I have a 840 G6, SN: 5CG9435S8T that need unlocking. thanks.
                                      • minhdigital
                                        • Nov 2022
                                        • 756
                                        • Vietnam
                                        #119
                                        Send to you, Try
                                        • mesta83
                                          • Nov 2015
                                          • 75
                                          • merseyside
                                          #120
                                          Still has admin password
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
