HP Elitebook 840 G6 bios password
  • lapfix
    • Mar 2020
    • 2778
    • my workshop
    For the 32 Mega the tools RCUnlocker give me this message :wrong chip , try reading and unlocking 16MB chip
    so i read 16MB..unlocked..but the lap not power on now !
    Any help please..thank you
    VIP Moderator
    • Aug 2018
    • 4387
    • Bulgaria 🇧🇬
    • Gadget & motorcycle addicted
    Re: HP Elitebook 840 G6 bios password
    Most probably you didn't program the chip correctly, or didn't solder it properly.
    Program 16MB chip only, or both if doesn't work. Use verification, be careful.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • gtiphil
      • Dec 2021
      • 16
      • uk
      HP 840 G6 bios pw
      Need help with password removal. attached both dumps.
      Is it not possible with RCunlocker to do the dual bios .
      only 1 bios will drag into the unlocker successful.
      (sorry for the double post)
      • Bsolution
        Banned
        • Oct 2021
        • 73
        • punjab
        Re: HP 840 G6 bios pw
        Originally posted by gtiphil
        need help with password removal. Attached both dumps.
        Is it not possible with rcunlocker to do the dual bios .
        Only 1 bios will drag into the unlocker successful.
        feedback
        • gtiphil
          • Dec 2021
          • 16
          • uk
          Thank you Bsolution, working now
          • clrscr
            • Dec 2020
            • 200
            • sing
            please help me remove passwork. elitebook 840 g6
            thanks
              • 25731
              thanks
              • swt
                • Jun 2022
                • 5
                • osw
                Re: HP BIOS unlock tool
                Hi could anyone please help me to remove password from bios HP elitebook 840 G6, Bios chip winband 25Q256JVEN 1938 6923 3K500
                • peste
                  • 16533
                  • ROMANIA
                  the bios is incomplete ... it should have 32GB ... but the password is 16MB ..
                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                  It only takes 1 minute:
                  https://www.badcaps.net/settings/subscriptions
                  • swt
                    • Jun 2022
                    • 5
                    • osw
                    hi, that could be possible as I used ch341 programmer and various version of application for this programmer and depending on the version it was different chip versions to select. I did not know which one I should use. However after some attempts to read bios chip and unlock it with RcUnlocker and unlocker I made my laptop not booting at all. It only blink capslock. Tried to restore bios with usb pen with bios formatted and Windows + V and Windows +B but was not lucky at all. Any suggestions how to restore bios now?
                    • Mazorca
                      • Jan 2017
                      • 463
                      • fishing
                      I know it is beating a dead horse, but always make at least three readings, all starting from scratch, will take about 5 additional minutes, but will save hours of headaches. SWT, do you still have your backup or original unmodified reading? Also, do not rely on a clip, best way is to actually desolder/solder chip. Reflow or solder manually each leg. I personally use a dab of white thermal paste, rubbed in and wiped with alcohol in order to make it easier to read the letters on the chip.
                      • swt
                        • Jun 2022
                        • 5
                        • osw
                        I must confess I have visited guide section and have read it but not good enough. I also tried with de-soldering bios chip but it turned out I had wrong (different dimensions) programmer adapter. So I decided to not play more with opening laptop, un-mounting motherboard and de-soldering & soldering chip bu instead I bought first clip with which I failed to read anything then decided to buy 'chip probe\ line read' for wson8 which is probably not so good option too. But anyway I know I have to do it hard way now. So I wonder if there is standard bios bin file which I can download then modify if required and send to my chip to restore bios. If so could you please advice when I can get it and what is the procedure?
                        • Mazorca
                          • Jan 2017
                          • 463
                          • fishing
                          SOIC chips, the ones that have legs are easier to work with and can be easily desoldered/soldered with a bit of practice, don't forget to clean and re-tin pads. WSON, which your laptop apparently has (pads are under the chip) are way harder, some have little tiny resistors or caps the size of a flea or smaller surrounding them and can be easily shoved when soldering. I myself take those boards to a friend who works on iphone motherboards, takes him one minute or less to take out, about 15 minutes for me to reprogram and another minute to solder back. Assembling laptop usually takes longer. Suggestion: try to download the BIOS from HP website (sp140687) and make a USB recovery drive. I could not extract any BIOSes bins, the option does not show up.
                          This might be what you need, comes in with two sizes: https://www.ebay.com/itm/19392253016...4AAOSwzehgFXQy
                          • swt
                            • Jun 2022
                            • 5
                            • osw
                            Hi Mazorca,
                            I will buy this adapter but it will arrive probably someday next week. However it is not clear for my why should I prepare USB recovery drive. I've done it already with file you suggested and can see under HP/DEVFW/firmware.bin around 30 MB is this bin file. Should I flash directly to chip? Or you want me to try restore bios from USB drive?
                            • Mazorca
                              • Jan 2017
                              • 463
                              • fishing
                              The HP sp140687 should allow you to make the recovery flash drive on another computer. If it does not open, or crashes (on my dell laptop it crashes) go to C:/SWSetup/sp140687 folder and open HpFirmwareUpdRec64.exe. There is no option to copy the embedded bioses to the current laptop. :-(
                              Sorry I had not read everything correctly, try to boot with the flashdrive perhaps? I have never done this.
                              • swt
                                • Jun 2022
                                • 5
                                • osw
                                The thing is that I've already done bios recovery flash drive using this version of Bios and even older but I cannot trigger it to run with neither Windows+V or Windows+B. The Capslock led light constant and nothing else happens. I tried to flash using this probe cable bin files I backuped but none of them apparently work properly now... So I wonder if I can download somewhere good copy of Bios bin file and use it to flash it to chip?
                                • ogre4273
                                  • Mar 2022
                                  • 57
                                  • N/A
                                  hp elitebook 840 g6 computrace
                                  Hello everyone!! can someone remove computrace? It is set on Active. Thank you very much!!
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12710
                                    Re: hp elitebook 840 g6 computrace
                                    Try
                                    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                                    Subscribe to support us. It only takes 1 minute:
                                    • ogre4273
                                      • Mar 2022
                                      • 57
                                      • N/A
                                      Originally posted by hoaca388
                                      Try
                                      Thank you. I will definitely try this.
                                      Just a question. If I updated my bios after dumping the bin file, can I flash it again on the 32mb chip? if so, do I need to flash the other outdated bios bin on the 16mb chip or I'll just let it be and focus on the 32mb one?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12710
                                        Only flash bios file (32MB)
                                        • chriswfrye21
                                          HP 255R G10 – BIOS Admin Password Locked, Cannot Enter BIOS (Need Guidance / SMC.bin Help)
                                          by chriswfrye21
                                          I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
                                          This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
                                          I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
                                          Model: HP 255R 15.6 inch G10 Notebook PC SK...
                                          08-10-2026, 03:49 AM
                                        • Olegst44
                                          Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                                          by Olegst44
                                          I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                                          Device Information:
                                          - Model: Acer Aspire 3 A315-22G
                                          - Motherboard: NB8607G02-MB (Compal LA-J761P)
                                          - BIOS Chip: Winbond W25Q64 (8MB)
                                          - Serial: NXHE7ER00X95002B784S00
                                          Problem:
                                          - BIOS is password protected (Supervisor Password)
                                          - Boot from USB is disabled in BIOS
                                          - After 3 wrong password attempts, system shows Unlock Key Hint
                                          - I have RT809H programmer available
                                          What I need:
                                          1. Clean BIOS dump (password...
                                          04-11-2026, 05:36 PM
                                        • TopPop
                                          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                          by TopPop
                                          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                          12-14-2025, 09:40 PM
                                        • ShadeRunner
                                          [REQUEST] BIOS Password Reset - HP EliteBook 830 G6 - Halt Code: qeh11u1kst
                                          by ShadeRunner
                                          I’m a student currently locked out of the BIOS on my HP EliteBook 830 G6. I bought the laptop second-hand, and the previous owner didn't provide the password. I really need access to the BIOS to change storage settings and boot orders for my studies.
                                          System Details:
                                          • Model: HP EliteBook 830 G6
                                          • Processor: Intel Core i5 (8th Gen)
                                          • Serial Number: 5CG0080LKD
                                          • Halt Code (from 3rd fail): qeh11u1kst
                                          I'm hoping someone here can help me generate an SMC.bin file or provide a master password that works for this generation. Any guidance on how to get back...
                                          03-17-2026, 10:49 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
