HP Elitebook 840 G6 bios password
    Re: Hp elitebook 840 g6 locked bios
    Originally posted by mp3boy View Post
    I am using this method on my own 840 G6. I have successfully removed the password by replicating the changes made in the 32MB unlock file, but HP BCU tool won't program the Product Name and Feature Byte.
    The system is in MPM unlocked mode and I have set the CT, Serial and Build ID using HP BCU.
    WnDMIFit gives a Board Not Supported error and runs in read-only mode.
    Any advice please?
    Problem solved, badly formatted text file, BCU works fine for all fields.
    Notes in case it helps anyone:
    Much easier to backup and restore DMI with BCU if the laptop is bootable into Windows. Run the following in administrative command prompt before and after resetting password:
    Code:
    before flashing any files!!:
    BIOSConfigurationUtility64.exe /Get:data.txt
    after unlock:
    BIOSConfigurationUtility64.exe /Set:data.txt
    power off, battery pull, PoE pi3 with pogo probe worked for read/write 32MB chip without disassembly/soldering. pi4 usb-c did not work - mismatched reads.
    to make unlock file in hex editor (this will erase DMI data and put laptop in MPM mode):
    change 3F (?) to 3C (<) after the following strings:
    52 00 65 00 63 00 6F 00 76 00 65 00 72 00 79 00 53 00 74 00 61 00 74 00 75 00 73 (Recovery Status)
    49 00 44 00 45 00 4B 00 50 00 75 00 62 00 43 00 52 00 43 (IDEKPubCRC)
    6F 00 6D 00 6D 00 6F 00 6E 00 53 00 65 00 74 00 75 00 70 (CommonSetup)
    44 00 65 00 76 00 69 00 63 00 65 00 43 00 6F 00 6E 00 66 00 69 00 67 00 46 00 6C 00 61 00 67 00 73 (DeviceConfigFlags)
    and replace
    26 48 00 70 00 4D 00 70 00 6D 00 00 00 00 00 00 00 00 00 00 00 (HP MPM) with
    26 48 00 70 00 4D 00 70 00 6D 00 00 00 00 23 01 00 02 00 00 00
    start laptop, reboots numerous times, use F10 and apply factory defaults, save and exit
    F10 again, go to Security tab and reset bios security to factory defaults (this step asks for a password if the above step is not done)
      Re: HP Elitebook 840 G6 bios password
      Hi, can help to unlock this please, i try with RCunlocker but not remove lock
        Read the rules before posting:
        Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
        Become a Badcaps supporter
        Thanks to all supporters.​
          Need help with password removal. attached both dumps.
          Is it not possible with RCunlocker to do the dual bios .
          only 1 bios will drag into the unlocker successfu
            Read post #103. SERIAL NUMBER !!!
              hp 840 G6 i7 endpoint security controller problem
              hi i try to unlock the bios on HP 840 Genration 6 i7
              i modifid the 16mb CHIIP but after is coming always the Eror hp endpoint security controller problem
              i try to install clean dump for 32MB too but still same can anybody help me
              i post the original Dump file down .
                Re: hp 840 G6 i7 endpoint security controller problem
                Read post #103 .
                  https://www.badcaps.net/forum/showpo...&postcount=346
                  if you have problem with hp endpoint security controller and password lock use this main and ec it works tested.
                    Help me to unlock this password
                      Read post #105
                        Originally posted by SMDFlea View Post
                        Read post #105
                        i will check, thanks bro
                          hi everyone , after removing bios password im confronted with a "endpoint security controller problem"
                          can anyone help me with a good unlocked flash
                          thanks
                          6050A3022501-MB-A01 - 5CG0360FPX
                            try this one.
                              no still the same error
                                thanks
                                Serial number ?
                                  5CG0360FPX
                                    thanks
                                    CCCC
                                      Hi everyone, I have a 840 G6, SN: 5CG9435S8T that need unlocking. thanks.
                                        Send to you, Try
                                          Still has admin password
