HP Elitebook 840 G6 bios password
  • saveelektro
    • Mar 2025
    • 7
    • Svizzera
    #241
    Hello everyone, I don't know where else to turn. I have this EliteBook 840 G6—I desoldered the 16MB chip (the one on the back) and used RC Unlocker, but it didn't work. Do I need to desolder the 32MB one near the RAM too? Any help is appreciated, thanks!​
    • Stefan Steff
      • Mar 2024
      • 334
      #242
      No, you not need to desolder the main bios chip.
      Write this EC content and you are good to go.
      P.S.
      Next time write your serial ... the ruels must be respected.
      I write for you now...5CG9427SGQ
      • saveelektro
        • Mar 2025
        • 7
        • Svizzera
        #243
        P.S.
        Thank you so much! At first, it couldn't pass the verification, but after cleaning the chip, everything went smoothly... Sorry about the serial​...
        • buhlev.bg
          • May 2023
          • България
          #244
          Hello dear. I try to remove bios pass on my second hand hp elitebook 840 g6 with SN: 2TK9500B5N . I try a lot of bin files here but laptop not start or start with <<endpoint security problem. Also I try two tools for pass remove but again no results. Please for help. Here is my original bin file with possword.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12257
            #245
            [QUOTE=buhlev.bg;n3717907]Hello dear. I try to remove bios pass on my second hand hp elitebook 840 g6 with SN: 2TK9500B5N . I try a lot of bin files here but laptop not start or start with <
            Unlocked
            • buhlev.bg
              • May 2023
              • България
              #246
              [QUOTE=hoaca388;n3718039]
              Unlocked
              Thanks I will try it today.
              just one question: I have to leave original 32mb bin and replace only 16mb bin from you. Is it correct?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12257
                #247
                [QUOTE=buhlev.bg;n3718232]
                yes
                • djsxn
                  • Aug 2025
                  Hey all,
                  I have an HP Elitebook 840 G6 that has power on auth with 2 users, admin and someone else. Ive tried RC unlocker but had no luck. Does anyone else know what i could try?
                  ProID: 8QL97UP#ABA
                  SN: 5CG9433V6G
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12257
                    #249
                    Originally posted by djsxn
                    Hey all,
                    ProID: 8QL97UP#ABA
                    SN: 5CG9433V6G
                    Post main bios.
                    • buhlev.bg
                      • May 2023
                      • България
                      #250
                      [QUOTE=hoaca388;n3718318]
                      yes
                      Thanks again. It work but I had more problems with the sound. The solution was update the bios after unlock the pass. That is for info if some one have the same problem.
                      Again Thanks for unlocking the pass. I tried a lot of tools and only you help me.
                      It will be interesting for me how you did it.... 🙂
                      • Zayaanali
                        • Aug 2023
                        • 7
                        • Karachi
                        #251
                        HELLO EVERY ONE I NEED BIOS FILE 32MB AND 16MB MY ORIGNAL FILE IS COURRAPT BECAUSE MY CHIP ARE DEMAGE PLEASE PLEASE HELP ME .. SEND ME ONE FILE ALL 840 G6 SUPPORTED
                          • 21637
                          Type the laptop serial number, full name and model, motherboard model, etc.
                          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                          • Zayaanali
                            • Aug 2023
                            • 7
                            • Karachi
                            #253
                            5CG0114GZC THIS ONE SERIAL NUMBER BUT SIR I WANT UNIVERSAL BIOS ALL SUPPORTED 840 G6 .. I HAVE 3 4 BOARD SAME ISSU BIOS ISSU
                            • Lovro25
                              • Jan 2023
                              • 18
                              • Croatia
                              #254
                              Can someone please help with this BIOS? The laptop turns on and shows a picture, but it's extremely slow to boot; it takes minutes to get to the HP logo (without a disk), and with a disk it takes upwards of 20+ minutes to get to the point where the OS boots. I have removed only the main BIOS. If need be, I'll also post the 16 MB BIOS.
                              HP EliteBook 840 G6
                              SN: 5CG9462YR4​
                              • Stefan Steff
                                • Mar 2024
                                • 334
                                #255
                                HP EliteBook 840 G6
                                SN: 5CG9462YR4
                                Try with this cleared dump
                                • Lovro25
                                  • Jan 2023
                                  • 18
                                  • Croatia
                                  #256
                                  Hey, sadly it didn't help; the problem remains. I attached a video. The laptop will stay on this for a long while and then again on the HP logo and then finally boot in to the OS normally.
                                  • Stefan Steff
                                    • Mar 2024
                                    • 334
                                    #257
                                    This attached BIOS file was programmed on several 840G6 laptops.
                                    If this dump doesn't work then MAYBE you have other problem not BIOS...
                                    • Lovro25
                                      • Jan 2023
                                      • 18
                                      • Croatia
                                      #258
                                      Hey, yeah, the problem still remains. Do you maybe have a known good EC BIOS (16 MB) for me to test with, maybe?
                                      • Stefan Steff
                                        • Mar 2024
                                        • 334
                                        #259
                                        Of course...
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
