HP Elitebook 840 G6 bios password
  • black0hackers
    • Jul 2020
    • 367
    Re: HP Elitebook 840 G6 bios password
    Originally posted by mesta83
    Hi I need this 840 g6 unlocked please
    try and feeback
    • krogs214
      • Sep 2017
      • 84
      • Philippines
      #82
      hp elitebook 840 g6 please help bios unlock
      anyone can help me Hp elitebook 840 g6 to unlock
      thanks
      • aldopc
        • Jul 2017
        • 468
        • Chilito
        #83
        Re: hp elitebook 840 g6 please help bios unlock
        thanks
        Test and comments
        • yuri3185pcnet
          • Jul 2019
          • 12
          • Philippines
          #84
          Good day everyone..Can someone remove password and computerace on my hp elitebook 840 g6.. thanks your help will much apreciated..
          • peste
            • 13370
            • ROMANIA
            #85
            try...
            • yuri3185pcnet
              • Jul 2019
              • 12
              • Philippines
              #86
              Originally posted by peste
              try...
              good day sir thanks for reply..thanks i tried your file the password is gone but it said device freeze again after an hour..
              • rex98
                • Feb 2023
                • 1289
                • Mandaue CEBU, Philippines
                #87
                unlock this please it has swatlock/computrace. TIA
                SN: 5CG9311TZC
                i managed to unlock the bios password by myself in neo hex editor the 16mb chip. but my problem now is the absolute lock. my patch doesn't work from files i compared here.
                • rex98
                  • Feb 2023
                  • 1289
                  #88
                  SN: 5CG9311TZC
                  so i managed to unlock by myself. its just so easy but complicated now i know how to unlock this model. i just copied the DMI data manually searching the serial, board CT, mac address etc. here's the guide use my bios swat unlocked.
                  i searched the dmi data in unlocked bios then trasfer my dmi to the unlocked ones and now it works.
                  HERE'S THE GUIDE HOPE YOU ALL UNDERSTAND.
                  USE MY BIOS DUMP IN THE ATTACCHMENT HP 840 G6 SWAT UNLOCKED.
                  SERIAL NUMBER BLOCK ADDRESS : 00749807 , 00757cab , 00794cfd , 007a6dc5 , 007a6e89 , 018fd9ee , --> edit and put your serial number in that 6 address
                  SYSTEM BOARD CT BLOCK ADDRESS: 007aaf51 and 018fdaf4 -->edit and put your CT number in that 2 address
                  MAC ADDRESS: 01900040 -->edit and put your MAC ADRESS in that address ITS ENCODED IN UNICODE STRING SO DONT DELETE THE DOT.
                  BUILD ID: 018fe754 -->edit and put your BUILD ID in that address
                  THEN IN FIRST BOOT GOTO BIOS PRESS F10 RESET SECURITY TO DEFAULTS. THEN USE MPM TOOL IN WINDOWS PUT ALL THE DMI FROM YOUR BOARD are LOCATED in THE STICKERS..
                  MAKE SURE YOU FORMAT THE OLD SSD WITH LOCK BEFORE BOOTING TO WINDOWS. I USED HEX EDITOR NEO CRACK.
                  • Elaid02
                    • May 2022
                    • 34
                    • FRANCE
                    #89
                    Hp elitebook 840 g6 locked bios
                    hi badcaps team
                    need remove Password for this bios
                    Here bios attached
                    • kulokutoys
                      • Jun 2010
                      • 132
                      • Phillippines
                      #90
                      Re: Hp elitebook 840 g6 locked bios
                      use RC unlocke, search it in the search option
                      • Elaid02
                        • May 2022
                        • 34
                        • FRANCE
                        #91
                        Idid but still have password
                        • rex98
                          • Feb 2023
                          • 1289
                          #92
                          Originally posted by Elaid02
                          hi badcaps team
                          Here bios attached
                          since you didn't upload the 16mb try this. ON FIRST BOOT RESET SECURITY SETTINGS IN BIOS. THEN PUT THE DMI MANUALLY VIA MPM TOOL.ALL YOUR DMI ARE IN THE BOARD STICKERS.
                          Product Name : HP EliteBook 840 G6
                          System Board CT Number: PHWHN00WBD3I1V
                          SERIAL :5CG9497JF1
                          BUILD ID :19WWCFBT601#SABF#DABF7
                          FeatureByte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
                          give feedback
                          • newstory
                            • Aug 2014
                            • 14
                            • Belgique
                            #93
                            Please need unlock 840 g6
                            SERIAL.: 5CG9500WHD
                            thanks
                              • 21635
                              SERIAL.: 5CG9500WHD
                              thanks
                              https://www.badcaps.net/forum/showpo...54&postcount=3
                              BIOS guides, methods, resources and tools
                              https://www.badcaps.net/forum/showthread.php?t=103526
                              3. Password removal by laptop brand
                              3.6. HP
                              BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required.
                              You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539
                              Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184
                              • rex98
                                • Feb 2023
                                • 1289
                                #95
                                SERIAL.: 5CG9500WHD
                                thanks
                                here's your unlocked EC. its only 16mb for bios password coz you didn't mention including absolute lock.
                                • Elaid02
                                  • May 2022
                                  • 34
                                  • FRANCE
                                  #96
                                  need unlock this bios
                                  here both 16mb and 32mb dump
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12257
                                    #97
                                    RC Unlocker with 16MB chip.
                                    ​https://www.badcaps.net/donate
                                    • Elaid02
                                      • May 2022
                                      • 34
                                      • FRANCE
                                      #98
                                      I did but still have password...
                                      • rex98
                                        • Feb 2023
                                        • 1289
                                        #99
                                        here's your unlocked bios.
                                        next time use any hex editor or rc unlocker.
                                        here's the block address of the g6
                                        0037000 to 00037b40 replace with ff.
                                        • mp3boy
                                          • Mar 2016
                                          • 48
                                          System Board CT Number: ...
                                          SERIAL :...
                                          BUILD ID :...
                                          FeatureByte : ...
                                          give feedback
                                          I am using this method on my own 840 G6. I have successfully removed the password by replicating the changes made in the 32MB unlock file, but HP BCU tool won't program the Product Name and Feature Byte.
                                          The system is in MPM unlocked mode and I have set the CT, Serial and Build ID using HP BCU.
                                          WnDMIFit gives a Board Not Supported error and runs in read-only mode.
                                          Any advice please?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
