HP BIOS unlock tool
  • gmorb
    • Sep 2017
    • 38
    Originally posted by Brianmathews99
    Re: HP BIOS unlock tool
    I apologize I should have given more information from the beginning
    Hp spectre x360
    Df0013dx
    Here you go
    • poppay
      • May 2021
      • 7
      • serbia
      #1622
      hi
      I need a clean bios file and if someone can extract it from the old bios feature byte? because I did everything according to the instructions with hp unlocker and there is no password, but I have red letters and a countdown after turning on the laptop and I managed to insert all the parameters into the bios serial, sku..... but I only need the FEATURE BYTE, I can't find it anywhere
      HP elitebook 860 G10
      • Menoslag
        • Jun 2025
        • 7
        • Chile
        #1623
        Hi friend, need unlock password bios.
        Model: HP CW1501LA AMD
        Motherboard Model: DAG7BJMB8C0 REV C (G7B)
        Original 16MB BIOS file included
        • Sidqi Januar Riadi
          • Dec 2024
          • 27
          • INDONESIA
          #1624
          I hope this helps
          • poppay
            • May 2021
            • 7
            • serbia
            #1625
            can someone read the feature byte??
              • 22001
              Type the laptop serial number, full name and model, motherboard model, etc.
              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
              • poppay
                • May 2021
                • 7
                • serbia
                #1627
                I already sent all that, download the txt document that I attached and everything is written there...
                  • 22001
                  Everything is written there...
                  You MUST:
                  • Read BIOS guides, methods, resources and tools
                  • Try the method at BIOS guides, methods, resources and tools before requesting help
                  • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                  • Use search function in case someone already answered your request
                  • Post under a related thread if it exists
                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                  • Name your thread with model numbers and request
                  • Provide a BIOS/EC dump if possible
                  • Attach files directly to your post instead of linking to external websites
                  • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                    • 22001
                    https://partsurfer.hp.com/?searchtext=5CG3361WXG
                    476J6S6b7B7H7M7R7W7m7saBapaqauawb8bUcAeMfPfXguhKhkjhk8mEmVn7nVngpDpTpnpqprqMqkqz.en
                    • poppay
                      • May 2021
                      • 7
                      • serbia
                      #1630
                      thanks for this,
                      but I already did it through hp part surfer and found that code, but when I enter it in the bios, it won't record it, it says that the code is not appropriate, I also tried via BCU but unsuccessfully, after restart there is still no feature byte in the bios.
                      so I just wanted someone to read it from the bios that I attached (both chips are read in the bios and EC and saved there in rar format) if this code that you, like me, found through the hp site and the one that is actually in the bios file are the same, then I don't know what else to do... but if it's a coincidence a code from the bios different from the one from the HP site would be great, because then there are high chances that the input will be successful and the "red counting" will be solved
                      • poppay
                        • May 2021
                        • 7
                        • serbia
                        #1631
                        as a rule, this should not be in the txt file 🙂
                        Serial Number : 5CG3361WXG
                        Product Number : 6V8V9AV
                        Description : HP EliteBook 860 G10
                        build id : 23WWWGBZ601#SABD#DABD
                        feature byte: ??
                        ct PRTTR00WBIJ07F
                        MAC2 X644ED7C64EC2
                          • 22001
                          feature byte: ??
                          ct PRTTR00WBIJ07F
                          MAC2 X644ED7C64EC2
                          Try this bios and see if it will let you enter the feature byte again
                          • salim5566
                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                            by salim5566
                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                            06-26-2025, 03:25 PM
                          • to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                            by to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                            I have opened the laptop and identified the main BIOS chip...
                            10-24-2025, 01:35 AM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • m1ch43lzm
                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                            by m1ch43lzm
                            Hi everyone
                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                            There's also an extra OTP Secu.R...
                            09-06-2025, 05:47 PM
