HP BIOS unlock tool
  • kapishona
    • May 2018
    • 11
    • Georgia
    #501
    Re: HP BIOS unlock tool
    Originally posted by SMDFlea
    Are you using a clip ? ,if you are you can attach the power adapter then try to make another backup.
    dump in chip alsou is damaged because i write damaged dump
    • peste
      • Dec 2016
      • 12822
      • ROMANIA
      #502
      Originally posted by kapishona
      ok so how i can recover it may be my programmer working badly
      https://www.youtube.com/watch?v=DWWigscuQDY
      • kapishona
        • May 2018
        • 11
        • Georgia
        #503
        yes thanks i know , but my programer read half of dump and i not check it , and can you help ?
          • 20938
          What programmer do you have, is it a CH341A
          • kapishona
            • May 2018
            • 11
            • Georgia
            #505
            CH341A and gq4x
              • 20938
              Your bios backup has the first 16MB written twice ,rather than the full 32MB. The CH341A has some alternative software , AsProgrammer,NeoProgrammer and Colibri.All available on the forum if you search.
              Post the 16MB bios backup if it has the second chip ?.
              • kapishona
                • May 2018
                • 11
                • Georgia
                #507
                on the board W25Q256 32bm and W25Q128
                • N0f3ar
                  • Oct 2016
                  • 51
                  • Bulgaria
                  #508
                  Originally posted by peste
                  make a copy on both chips and try this.
                  hi i have tried but the result was blackscreen and full speed fan
                  i have writed back original bioses and again black screen and full speed fan
                  hp elitebook 840 g5
                  can you help?
                  thank you
                  • peste
                    • Dec 2016
                    • 12822
                    • ROMANIA
                    #509
                    hp elitebook 840 g5
                    can you help?
                    thank you
                    post the original bios
                    • N0f3ar
                      • Oct 2016
                      • 51
                      • Bulgaria
                      #510
                      i have only 32 mb chip backup , the small one (i forget to make backup)
                      • peste
                        • Dec 2016
                        • 12822
                        • ROMANIA
                        #511
                        try..
                        • N0f3ar
                          • Oct 2016
                          • 51
                          • Bulgaria
                          #512
                          try..
                          16mb is the same as this you gave me before
                          do i have to write it again ?
                          • N0f3ar
                            • Oct 2016
                            • 51
                            • Bulgaria
                            #513
                            tried again full speed fan
                            • peste
                              • Dec 2016
                              • 12822
                              • ROMANIA
                              #514
                              you have two chips, one 32MB and one 16MB on your laptop, write both chips with what I posted ... the 32MB with 32MB and the 16MB with 16MB.
                              • N0f3ar
                                • Oct 2016
                                • 51
                                • Bulgaria
                                #515
                                [QUOTE=peste;999560]you have two chips, one 32MB and one 16MB on your laptop, write both chips with what I posted ... the 32MB with 32MB and the 16MB with 16
                                do i have to write the 16 mb chip everytime i write 32 mb
                                i have written 16 mb with this you send me 1st time (it is the same as this you send me now, i have compared it with hex editor)
                                • N0f3ar
                                  • Oct 2016
                                  • 51
                                  • Bulgaria
                                  #516
                                  I tried many times i only get full speed fan after 15-20 seconds
                                  I do not know what to do
                                  • pingaroon
                                    • Nov 2019
                                    • 121
                                    #517
                                    Hi, I have an 840 G3 but I think I have burnt the WSON chip by using too much heat from hot air station.
                                    This board has gold pads above and below the bios chip area which are connected to the WSON pins, so question is, could I replace the burnt WSON chip with a standard SOIC8 chip by soldering onto these gold pins ?
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1518
                                      • Estonia
                                      #518
                                      Yes
                                      • OskarB98
                                        • Aug 2018
                                        • 75
                                        • Sverige
                                        #519
                                        Can someone please help me with my 840 G3 BIOS?
                                        It has a BIOS Password, will attach original BIOS-file.
                                        I tried the Unlocker tool but I only get ''failed to execute script HPunlocker''
                                        https://easyupload.io/q0jffa
                                        • danito
                                          • Jun 2016
                                          • 948
                                          • Romania
                                          #520
                                          Try
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • mohamedbalwe
                                            BIOS FOR DS-7204HQHI OR UNLOCK PASS FOR THIS FILE
                                            by mohamedbalwe
                                            hello everyone
                                            i need bios dvr DS-7204HQHI
                                            motherboard code 80303-p rev 2.2
                                            The attached file is lock pass...
                                            07-14-2025, 06:02 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
