HP BIOS unlock tool
  • tim9
    • Feb 2021
    • 11
    Re: HP BIOS unlock tool
    Originally posted by tim9
    Oh BIOS is empty, I think that's the issue. I am not able to read the chip now , It seems damaged. My programmer reads another Winbond chip but not this one.
    I have old bios 1.13 backup. I am attaching here.
    Requested information :
    Model : HP EliteBook G3 Touch i5 6200
    Logic Board : 6050A2892401-MB-A01
    nvm
    Actually I was able recover it using old backup.
    • tim9
      • Feb 2021
      • 11
      Originally posted by peste
      try this..
      nvm
      • Andriux212
        • Sep 2014
        • Lithuania
        #743
        hi who can help me unlock HP elitebook 840 G4 bios ?
        • peste
          • 12371
          • ROMANIA
          #744
          post the content of the other bios chip ...
          • Andriux212
            • Sep 2014
            • Lithuania
            #745
            Here other bios bin
            • peste
              • 12371
              • ROMANIA
              #746
              Here other bios bin
              try..
              • SallyB
                • Nov 2020
                • 8
                • England
                #747
                Tried the Mazzif software with HP Elitebook 830 G6 but password is still there. The chip I programmed is 256Mb but the bin file is 32Mb, is that where the password is stored or is it somewhere else. I see there may be a 16Mb file too but if that is the case I don't know which chip I need to program. Does anyone have a clean Bios dump and a picture of the 16Mb chip location please. I have attached the Mazzif unlocked file. Thank you.
                • peste
                  • 12371
                  • ROMANIA
                  #748
                  post the content of both 16MB and 32 MB bios, look for the bios chip on both sides of the motherboard.
                  • SallyB
                    • Nov 2020
                    • 8
                    • England
                    #749
                    Thanks for the reply. I managed to locate the 128Mb chip on the other side of the motherboard. I have removed and tried the HPunlocker tool and replaced but still locked.
                    Looks like mazzif tool does not work on this one
                    I have attached both files, could someone please remove the password. Thanks.
                    • RethoricalCheese
                      • Mar 2013
                      • 1517
                      • Estonia
                      #750
                      If you would have read a bit more, you would know that Mazzif tool works on very old laptops and the tool in first post works up to G5 with varying success.
                      I don't think my methods won't work on your laptop so I'll leave it up to peste
                      • peste
                        • 12371
                        • ROMANIA
                        #751
                        try..
                        • SysGhost
                          • Mar 2021
                          • 12
                          • Sweden
                          #752
                          A neat tool that has helped me a few times.
                          I do wonder though. Would it be possible to get a Linux version of this tool? I just had to go through the process of installing windows just to use this one tool. I tried with wine but that would not work at all.
                          If you'd provide some code I might even be able to help to port it to linux.
                          • amr soliman
                            • Oct 2015
                            • 116
                            • egypt
                            #753
                            tested on probook 430 g6 and work
                            than you very much
                            • vinh1812
                              • Mar 2021
                              • vietnam
                              #754
                              Great, thanks author very much. HP 840 G1, G2 good job.
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                #755
                                I actually always use it on linux myself (slightly modified to get it working there). Next month I can finally continue developing it. Will keep you in mind and share you the linux version.
                                • Stylishh11
                                  • Mar 2021
                                  Have this kind of issue for my HP 820 G2 laptop, and I am not able to finish BIOS verification.
                                  Software - CH341H ver. 1.34
                                  Proggramer - CH341H
                                  CHIP - W25Q128FV
                                  Help, for now after erase I have black screen.
                                  , after programming
                                  • munir100
                                    • Dec 2018
                                    • 178
                                    • uae
                                    #757
                                    Originally posted by rethoricalcheese
                                    first check this site to see if your hp is supported for the great tool mazzif has made.
                                    http://mazzifsoftware.blogspot.com/p...os-unlock.html
                                    if your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
                                    For that you need an spi programmer like ch341a or raspberry pi with flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios ic.
                                    When you have your dump, just drag and drop your file on my hpunlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
                                    Just program the new file on your bios ic.
                                    This unlocker should work on all elite, elitebook, probook and maybe some other series hp laptops.
                                    For those of you who need to unlock large amounts of laptops, i recommend adding a registry entry:
                                    Code:
                                    computer\hkey_classes_root\*\shell\hpunlocker\command
                                    then modify that string adding
                                    Code:
                                    "c:\*location-of-exe*\hpunlocker.exe" "%1"
                                    this way you just need to right click your locked file and select hpunlocker.
                                    If there are any issues, please do let me know so i can improve this tool.
                                    sir this tools very good i c hack many laptop model hp 640 g1 hp 640 g2 hp 820 g1 hp 820 g2 hp 725 hp 745 hp zbook 15 g1 hp zbook17 g3 many more.........u r grade sir
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1517
                                      • Estonia
                                      #758
                                      bv and fv are same
                                      • Arch801
                                        • Feb 2021
                                        • Italy
                                        #759
                                        This tool not work on HP elitebook 8770w , and Mazzif tool with shotgun ,show error this motherboard model is not supported.
                                        Regards Devid
                                        • Akintunde
                                          • Mar 2017
                                          • 154
                                          • Nigeria
                                          #760
                                          Regards Devid
                                          Try this bios file and report
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
