HP BIOS unlock tool
Every donation made will go towards server fees and maintenance costs. -
Re: HP BIOS unlock tool
the biosinfo.bin was dumped from the larger chip and the biosinfo.bin was dumped from the winbond chip hope that helps and thanks for the reply.
hope you can sort thisAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
try this one i have just read it again thanks also i am using asprogrammer v 1.380.Attached FilesComment
thanks againAttached FilesComment
it is not good even now..check with the HxD program the copy you send..enter the copy of your bios and a correct copy of the laptop bios (find on the forum) in the HxD program and make the comparison ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
this one
bios extracted from the HP site updateAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi everyone.
In the UEFITool, I am trying to empty my first padding in the BIOS region. After extraction, I use the HxD program and use the "Fill selection" command to replace all data with FF. Next, I replace the padding with the modified file. But for some reason, the file sizes differ and I can not rebuild my bios file due to the size difference.
Can anyone guide me on the problem?Comment
Hi everyone.
Hi everyone.
Elitebook 840 G6.
Any help in unlocking would be appreciated. I have attached the bios files.Comment
hi everyone, ok I need some help so here goes..I have a hp 850 g1 which has an administrator password and just below that in the bios there are two more users. I have bought a ch341a and I also have the hp unlock.exe..i have desoldered the larger of the two chips that are on the board. I think I may have bought the wrong sop8 chip socket as attached because it's the 150mil version but my bios chip doesn't seem to fit in it causing my ch341a to produce ff and ffff when trying to detec. do I need the 200mil? also the chip I have is 25q128a 13eco 99chn 42005 and is 8 pin what is the more reliable software that will have this chip number in its database that actually works or confirmed working with a hp 850 g1? I have about 300 of these laptops to work on.Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by mohamedbalwehello everyone
i need bios dvr DS-7204HQHI
motherboard code 80303-p rev 2.2
The attached file is lock pass...07-14-2025, 06:02 AM -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by KesavanHello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
Attached my backup file
SERIAL NO: 5CG4300CNT...-
- Loading...
