HP BIOS unlock tool
Re: HP BIOS unlock tool
Hi everyone, quick question: I'd like to avoid to desolder chip, since laptop si still under warranty for 6 months. For that, I'd like to dump EPROM with a clip (may not work, of course, since chip is still soldered).
First, did you have success with an in-circuit reading? Second, do you know where I can purchase a clip, but not an SO type, but a QFN type? (QFN-8)?
Thanks !Comment
i has do it by myself: replace EC bios file (non pass) from another laptop, password is remove, but there are is problem when it turn on even when i clear ME Region Main bios.
display showing
"HP Endpoint Security Controller Problem
There is a problem with the HP Endpoint Security Controller on the unit
Please contact HP Inc. to have the unit serviced "
Can you fix it to use for another Laptop bios password
thanks you!Comment
Here is it Sir. Original Main and Ec bios file add below
display showing
thanks you!
First you would want to flash back both original files, just to see if that error disappears.
let me know if it disappears, then I will try to patch correctly.Comment
Try this and let me know if it works or has any issues. Flash only EC bios.
You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.Attached FilesComment
You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.Comment
Nice. Do not use the same file on another laptop, you will brick it. Make copies of both chips, just in case and just send the EC file here. It's a bit tricky to get it correct.Comment
Hello friend I need your help please, I have this equipment with password
HP Elitebook 840R G4 I tried to clean the file with the tool that you published on the 32mb chip, but it did not work apparently the password is on the 16mb chip you. could you check it please.Comment
https://www.youtube.com/watch?v=9T57ktw8n3YDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
if it works enter the DMI information ... proceed as in the video ..
https://www.youtube.com/watch?v=9T57ktw8n3YComment
Nah, this still needs main bios mod only. This should work fine and without needing any messing around with DMI.Attached FilesComment
I did it with my new and improved tool which I have not published yet (because automatic unlocks on newer models is a bit more tricky than it seems. Still needs more improving and testing).
Old tool had a few bugs with certain bios dumps and your bios dump was an example of that.Comment
46 / 5000
Resultados de traducción
Ok, I'll keep an eye on the new version, thanks.Comment
Can you make patch (unlock) password for my HP 840 G5.
This is EC file...Attached FilesComment
Be sure to reset security settings to factory default.Attached FilesComment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by KesavanHello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
Attached my backup file
SERIAL NO: 5CG4300CNT...-
- Loading...
