Bios Password Dell Latitude 5510
  • Chuy666
    • Aug 2018
    • 7
    • MΓ©xico
    #181
    Originally posted by volinakis
    let it run for 2 mins, it will restart few time without image
    I left it for 6 minutes and it still doesn't work.
    • Markus1741
      • Sep 2020
      • 959
      • N/A
      #182
      Hello try this file .... Good luck ....
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        #183
        put back original bios and see if works, if not, your bios backup is corrupted.
        • Chuy666
          • Aug 2018
          • 7
          • MΓ©xico
          #184
          The backup doesn't work, I don't know what happened, I took out three backupsClick image for larger version
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            #185
            compare them and see if you have 2 identical.
            • Chuy666
              • Aug 2018
              • 7
              • MΓ©xico
              #186
              All three are the same, they have the same hash and I also compared them with the HxD64 program
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                #187
                check soldering
                • farouk_1994
                  • Mar 2021
                  • 399
                  • algeria
                  #188
                  Try this file than replay
                    • 22035
                    Hello you can unlock for me, dell 5410 FDW50 LA-J3819 servuce tag 6NTZL63
                    The service tag is for a Latitude 5510 , not 5410 .Your posts will be moved to the 5510 thread
                    • Rockhardware2
                      • Dec 2018
                      • 5
                      • Togo
                      #190
                      HELLO. Can someone help me fix this file dell latitude 5510 service tag DWM6C93
                      The laptop power on for 5secondes and goes off. Thanks
                      • ELOUALI
                        • Mar 2022
                        • 46
                        • BLANCA
                        #191
                        hello everybody
                        thanks in advance
                        please help me need to repair the dump
                        DELL 5510 i5 10310U
                        FDW50 LA-J381P Rev:1.0(A00) 2020-02-27
                        service tag 553FN13
                        thank you very much
                        Sincerely​
                        • m.sabry2110
                          • Oct 2017
                          • 134
                          • egypt
                          #192
                          Originally posted by ELOUALI
                          hello everybody
                          thanks in advance
                          DELL 5510 i5 10310U
                          service tag 553FN13
                          thank you very much
                          Sincerely​
                          try
                          • ELOUALI
                            • Mar 2022
                            • 46
                            • BLANCA
                            #193
                            Originally posted by m.sabry2110
                            try
                            thank you very much for your valuable response
                            after diagnosis I was able to notice that there is a problem with the processor​
                            • futadmytro
                              • Aug 2020
                              • 66
                              • Сполучені Штати
                              #194
                              Hi
                              Could someone help to deactivate absolute?
                              • futadmytro
                                • Aug 2020
                                • 66
                                • Сполучені Штати
                                #195
                                Originally posted by futadmytro
                                Hi
                                st 5d9n373
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12369
                                  #196
                                  st 5d9n373
                                  Deactivate absolute.
                                  ​https://www.badcaps.net/donate
                                  • futadmytro
                                    • Aug 2020
                                    • 66
                                    • Сполучені Штати
                                    #197
                                    Works perfect!!!!
                                    Thank you!
                                    • Benon
                                      • Oct 2019
                                      • 5
                                      • South Africa
                                      #198
                                      Hi Everyone can someone please help me to unlock this bios bin for dell 5510 FDW50 LA J38p
                                      thanks in advance
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12369
                                        #199
                                        thanks in advance
                                        How come your bios is only 8MB ?
                                        • Benon
                                          • Oct 2019
                                          • 5
                                          • South Africa
                                          #200
                                          They 2 Chips I dont know wich one to read they is the 16mb one!
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
                                            DELL Latitude 5510 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5510...
                                            09-06-2024, 09:10 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
                                            09-07-2024, 02:20 AM
