Bios Password Dell Latitude 5510
    Re: Bios Password Dell Latitude 5510
    Originally posted by trunguntilyou View Post
    i cannt deactivate Absolute
    Try this file than replay
      work perfect ! Thanks a lot
        Hello! Could someone be kind enough and free these from passward restraints ? Would be nice if somebody remnove the password so the laptop is functional again ? Thank YOU very much!
        edit: ST: 5THSK63 ( 5THSK63-8FC8 )
        Hello! Help me please to unlock bios 5510 - 8FC8. Thank you
        Hello everyone !
        Could someone help to delete the password 8CF8 ?
        Dell 5510
        Serial : 5SF0S73
        Service Tag : 12602195391
        Board : HD7XV
          Originally posted by Genova View Post
          Hello everyone !
          Dell 5510
          Serial : 5SF0S73
          Board : HD7XV
          Dump isn't good read and post` again
            Oupss sorry ! Attached the good version
              1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode
                The described method works first time! Thank you !
                Can you help with this other 5510 8CF8 bios ?
                Dell 5510
                Serial : 8280S73
                Service Tag : 8280S73
                Board : HD7XV
                  try
                    Once again, it works perfectly. Many thanks again for your help.
                        Can anyone remove administrative password from this BIOS dump.
                        Here is more info:
                        Dell Latitude 5510, Intel Core 10th Gen
                        Reg Model: P80F
                        Reg Type: P80F002
                        System Number: 3C3F373-8FC8
                        BIOS chip:
                        XMC QH128AHIG
                        BIOS dump done via CH341A using NeoProgrammer 2.1.0.19, IC manually set as: W25Q128xV
                        Thank you in advance!
                        edit
                        Just reading earlier posts here.... Or do I need to make a dump from the other chip next to XMC QH128AHIG? Atm I'm away from that laptop
                        edit #2
                        Sometimes I feel so stupid, think I did everything wrong above 🙄 I'll try tomorrow to read dump from WSON8 chip next to QH128AHIG.
                          Here is more info:
                          Reg Model: P80F
                          Reg Type: P80F002
                          BIOS chip:
                          XMC QH128AHIG
                          edit
                          Post the other dump 8mb from the other chip
                            I will, probably tomorrow, thank you!
                              Here is some additional info/data related to my post 133 here.
                              Here is the dump from XMC QH64AXIQ, auto-detected as XM25QH64A via NeoProgrammer 2.2.0.10:
                              Updated info, Copy -> Paste from post 133 and some more:
                              Reg Model: P80F
                              Reg Type: P80F002
                              Motherboard:
                              FDW50 LA-J381P
                              Rev:1.00(A00)
                              edit
                              Just to be on the safe side, did a dump of XMC QH64AXIQ using Colibri 1.0.1.61, Colibri "recognized" chip as GD256Q64 8Mx8, guess it'll fit.
                                Could anyone chime in to help me removing administrative password from BIOS of this ^^^^ laptop? Or am I doing something wrong.... Help
                                  Try this unlocked file ....
                                    Thanks a lot man, it worked like a charm!
                                    I've used NeoProgrammer 2.2.0.10 + CH341A Black to flash+verfy XMC QH64AXIQ using modified/unlocked dump you've attached above. Soldered back chip to the board, then disabled Absolute and exit from the manufacturing mode same as post #128.
                                    Months ago gave WSON8 adapter to my friend, almost forgot about it, he's out of the country atm. So had to use what I have under my hands to make improvised adapter for CH341A Black, a little bit of precise leg bending, soldering.... and it worked no problem. Maybe pics below could help someone in the same situation like me, sometimes you have to use whatever you have.
                                    For anyone wondering... that copper wire under the chip on pic #3 is to take away the heat a bit, not sure how much chip will heat up while flashing, beter to be safe than sorry.
                                    Markus1741 I owe you, if ever life gets you here where I am just send PM, nice domestic barbecue is at least what you can expect, same thing I'm going to get for this this weekend from a relative I've did this job for He bought this BIOS locked laptop dirty cheap somewhere in Germany iirc.
                                      Nice to hear that I could help you.
                                      Congratulations on your fine soldering work, you just have to know how to help yourself.
