Bios Password Dell Latitude 5510
  • didouche1200
    • Oct 2016
    • 352
    • 82679911441
    #81
    Re: Bios Password Dell Latitude 5510
    No display
    • lapfix
      • Mar 2020
      • 2585
      • my workshop
      #82
      there's another chip that you ust upload
      • didouche1200
        • Oct 2016
        • 352
        • 82679911441
        #83
        8m bit
        • farouk_1994
          • Mar 2021
          • 385
          • algeria
          #84
          Originally posted by didouche1200
          8m bit
          Try and commet back
          • paul13
            • Jul 2020
            • 12
            • ukraine
            #85
            please unlock my bios
            • partner
              Banned
              • Feb 2023
              • 53
              • BR
              #86
              Try!
              • paul13
                • Jul 2020
                • 12
                • ukraine
                #87
                password is in bios region? is it correctly if I will change bios region?
                • paul13
                  • Jul 2020
                  • 12
                  • ukraine
                  #88
                  Originally posted by partner
                  Try!
                  this work! thank you!
                  • paul13
                    • Jul 2020
                    • 12
                    • ukraine
                    #89
                    Try!
                    work but i cannt deactivate Absolute...
                    • volinakis
                      • Jan 2021
                      • 2643
                      • N/A
                      #90
                      with new bios you had to deactivate Absolute, write service tag, save, then press alt+F to exit manufacturing mode.
                      • paul13
                        • Jul 2020
                        • 12
                        • ukraine
                        #91
                        in this bios enable, disable and permanently disable is not active and i cannt change
                        • volinakis
                          • Jan 2021
                          • 2643
                          • N/A
                          #92
                          man, write back bios provided by partner and your motherboard will be in manufacturing mode. Press F2, disable Absolute, write service tag, save, restart, then press alt+F to exit manufacturing mode.
                          • paul13
                            • Jul 2020
                            • 12
                            • ukraine
                            #93
                            these items are not active! they are written in gray!
                            • volinakis
                              • Jan 2021
                              • 2643
                              • N/A
                              #94
                              can't be grayed if you are in factory mode, you have full acces on ALL bios settings. what you don't understand is that you have to write again unlocked bios provided by partner.
                              • paul13
                                • Jul 2020
                                • 12
                                • ukraine
                                #95
                                I haven't pressed Alt+F yet, This is the first inclusion after the firmware
                                • lapfix
                                  • Mar 2020
                                  • 2585
                                  • my workshop
                                  #96
                                  Latitude 5510
                                  Service Tag: BHSZZ53
                                  For the steps to do , follow post 92.
                                  https://www.badcaps.net/forum/showpo...8&postcount=92
                                  • paul13
                                    • Jul 2020
                                    • 12
                                    • ukraine
                                    #97
                                    Originally posted by lapfix
                                    Latitude 5510
                                    This work!!! Thank you!!!
                                    • volinakis
                                      • Jan 2021
                                      • 2643
                                      • N/A
                                      #98
                                      you just have to reset bios to factory settings in factory mode. I did this many times and worked.
                                      • mohibr
                                        • Aug 2012
                                        • 12
                                        Please could someone help me with this bios from a Latitude 5510 (FDW50 LA-J381P), i need to change the service tag, can i just edit it with HxD or is there another way?
                                        Or if someone could please clean the bios for me so that after flash i can set the service tag, there is no password, only need to change the service tag, many thanks.
                                        Last edited by Vesko356; 07-25-2023, 11:18 AM. Reason: Rules violation. Attached bios removed.
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria πŸ‡§πŸ‡¬
                                          #100
                                          Your request doesn't meet the rules. Deliberately changing ID numbers (including VIN, IMEI and so on) is illegal and not condoned or encouraged in any way or for any reason here.
                                          You may contact an official Dell representative office for further resolution of the matter by presenting proof of purchase/ownership.
                                          Originally posted by piernov
                                          3. Password removal by laptop brand
                                          DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices. The information given here is for personal use only, ie. you accidentally set a password on your own machine, you forgot the password you set a long time ago or you mistyped the password when setting it and cannot get in again.
                                          Note that a device bought locked might also have been stolen if the previous owner cannot give the correct password. This is especially common with business-grade equipment (Lenovo ThinkPad…) that employees sneak out or do not return.
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5510 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5510...
                                            09-06-2024, 09:10 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
                                            09-07-2024, 02:20 AM
                                            09-07-2024, 12:10 AM
